Old Mar 01, 2015, 02:28 PM
StayQuiet is offline
Find More Posts by StayQuiet
United States, SC, Boiling Springs
Joined Jul 2011
Question
My first "real" scratch build
After building several available kits, doing a bit of "kit bashing" (Sig MidStar 40 conversion to twin electric power), and building from published plans (redrawn in CAD and laser cut for accuracy), I've decided to jump into the deep end, so to speak, and try my hand at designing my own plane.
Not being an aerodynamics genius, I'm using a set of 3-views of an Avro 625 Avian monoplane (as seen in Flying Models - July 2000 issue) as a basis for general layout. However, my design will be shoulder wing vs. low wing, and a simple box-style fuselage for simplicity, both in design and construction. I plan on incorporating something I've been thinking about for awhile in the design - a modular wing mounting system, that allows different wing designs (flat bottom, semi-symmetrical, symmetrical) with varying amounts of dihedral to change the flight characteristics of the model, without the need to re-design (and build) a fuselage to match the wing shape.
There are two rather important questions I'm still unsure of, though:
1) how do you estimate the weight of a model design that has yet to be built? The size of the motor, battery, and ESC have to be determined. I know construction and design will make a difference in the finished weight, and plan on building as light as possible while maintaining integrity.
2) how do you determine proper CG? I'd hate to go through all the design and build process, only to end up tail heavy and crash on the maiden flight. (The CG is not noted on the 3-views)
Some design goals - 48" wingspan with 8 1/4" constant chord, fuse length of 34". Aiming for somewhere around a 450 watt motor for power.
Thoughts? Am I on the right path, or about to walk off a cliff?
StayQuiet is offline Find More Posts by StayQuiet
Old Mar 01, 2015, 02:56 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
The Avian, that brings back memories, must have been around '89-'90 I built a flew one, from a plan if I remember right.
Still in my build log book, (worth doing one),
44.5" span
38oz flying
600 brushed motor
Olympus belt drive
7 cell Nicad pack.
A CG Calculator is always a useful tool -- http://adamone.rchomepage.com/cg_calc.htm
eflightray is offline Find More Posts by eflightray
Old Mar 01, 2015, 03:12 PM
Joined Jul 2011
Very pretty bird!
Your link to the CG calculator lit up my anti-virus software, though.
Build Log Sterling Coursair F4U - My First Scratch Build sharkman Scale Kit/Scratch Built 46 Jul 27, 2015 10:33 PM
Build Log Vickers FB5 "Gunbus" My First Scratch Build hammerd Scale Kit/Scratch Built 159 Jul 23, 2015 02:59 AM
Build Log My first large scale scratch build Shadow-D Scale Kit/Scratch Built 22 May 14, 2015 11:44 PM
Discussion My first P-51 Mustang!!! My first scratch build!! Rain1dog Beginner Training Area (Aircraft-Electric) 18 Nov 22, 2014 08:21 AM
