Old Oct 01, 2013, 07:16 PM
tee681 is offline
Find More Posts by tee681
FlyBoy
United States, NY, Batavia
Joined Apr 2010
Help!
direct drive ailerons
Does anybody have good pics. of direct drive ailerons and how to install the servo ?
tee681 is offline Find More Posts by tee681
Old Oct 02, 2013, 12:52 PM
Free is offline
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
Take a look at this. This is Jamie Hick's "Fancy Foam" Raptor.
http://static.rcgroups.net/forums/at...95-IMG1317.jpg
Free
Free is offline Find More Posts by Free
Old Oct 03, 2013, 01:27 PM
aerolite is offline
Find More Posts by aerolite
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
I emailed this thread to Jamie. Maybe he can chime in with some help. Jamie has done a lot with direct drive servos, and is trying to get me to try them! I'll may have to cave in and give them a try..................especially since I can get him to help me set them up.
aerolite
aerolite is offline Find More Posts by aerolite
Old Oct 03, 2013, 02:06 PM
jhicks is online now
Find More Posts by jhicks
jhicks's Avatar
Joined Jan 2005
Hey guys. no problem.
It is really straight forward. You want to make sure when you install the servo that the servo screw lines up with the hingle line. Simply place the servo over the foam so it is alined and trace around the servo with a pencil. Then cut out the outline. You will want to take a strip of 3mm carbon and brace the inside of the aileron. This prevents from twisting. Once you have the servo slot cutout. Glue the servo in flush and make sure the hinge line lines up with the screw hole for the arm. Then all you do is glue the servo arm to the carbon rod thats on the aileron. The pic should help show you what I mean.
Hope this helps.
Jamie Hicks
jhicks is online now Find More Posts by jhicks
Old Oct 04, 2013, 01:34 AM
ChrisBowker is offline
Find More Posts by ChrisBowker
RC Bum 4 Hire
ChrisBowker's Avatar
United States, NM, Albuquerque
Joined May 2004
aerolite
Off topic: You might have to sell your JR to get him to help you lol.
On topic: I have flown some of Jamie's planes and the Aileron response is very crisp.
ChrisBowker is offline Find More Posts by ChrisBowker
Sold Astro 020 brushless direct drive with speed controller bendix1 Aircraft - Electric - Power Systems (FS/W) 1 Feb 11, 2013 06:29 PM
Wanted GWS 1060 Direct drive AKA GWS 10x6 Direct Drive Alex Schauer Aircraft - General - Miscellaneous (FS/W) 0 Jan 16, 2012 07:29 PM
