Old Jul 11, 2015, 10:00 PM
SlowJeff is offline
Find More Posts by SlowJeff
Taranis Soarus Wrecks
SlowJeff's Avatar
United States, MO, Richmond
Joined Apr 2015
My FrSky rx - the white, no telemetry, sorry-i-don't-have-the-number one, has two longish black antennae growing out of it. There is no possibility to put one crosswise in my Yak 12; the antenna is longer than the fuselage us wide. I am operating under the impression that these two antennae should be perpendicular to one another.
Is this correct? Should they? Should I poke a hole in the plane's floor and stick one of them out?
Or any other suggestions?
Thank you.
SlowJeff is offline Find More Posts by SlowJeff
Last edited by SlowJeff; Jul 11, 2015 at 10:00 PM. Reason: My autocorrect is driving me crazy.
Old Jul 11, 2015, 10:04 PM
4*60 is offline
Find More Posts by 4*60
most exalted one
Canada, BC, Blind Bay
Joined Aug 2002
I believe you will find that the whole length isn't antenna. If I remember about 1 1/4 inches is 1/4 wave for 2.4 so don't worry about the first part out of the Rx. Make sure the last 2 inches or so are oriented the way you want and a bit away from 'junk'.
186000*5280*12/24000000000*.25
4*60 is offline Find More Posts by 4*60
Old Jul 11, 2015, 10:08 PM
SlowJeff is offline
SlowJeff's Avatar
Joined Apr 2015
Aha! Of course! And to make it more obvious, had I only been actually thinking, the end inch and a quarter is uninsulated wire.
So I can easily orient them, and keep them away from junk, which is an issue. I put an NX3 Evo in this plane, and I'm sure its little digital brain is thinking some thousands or millions of digital thoughts every second.
Thanks!
Last edited by SlowJeff; Jul 11, 2015 at 10:10 PM. Reason: Earth to autocorrect - uninsulated is too a word.
Old Jul 12, 2015, 02:21 AM
frater is online now
Find More Posts by frater
Joined Aug 2014
Why people are using these ancient units in a scientific context is beyond me. They are impractical to work with. Tradition has no place in science. Come on, it's the 21st century. Stop using those units! At least in a scientific context...
Gallons, inches, feet, miles belong in a museum together with Roman ciphers.
frater is online now Find More Posts by frater
Old Jul 12, 2015, 04:57 AM
4*60 is offline
most exalted one
Joined Aug 2002
AW!.....................It ain't worth it.
Old Jul 12, 2015, 05:51 AM
Nora is offline
Find More Posts by Nora
Nora's Avatar
Malta, Żejtun
Joined Aug 2014
hi everyone
is there a page that explains the difference between the new european protocol and WW protocol ?
tried to search but can find anything except how to update the firmware
thanks
Nora is offline Find More Posts by Nora
Old Jul 12, 2015, 06:02 AM
nigelsheffield is offline
Find More Posts by nigelsheffield
United Kingdom, Horbury
Joined Oct 2007
Originally Posted by SBright33 View Post
Long thin edge really? How many RSSI units if I turn them 90 degrees? Just did a range test got 300ft to 40 RSSI then rapidly drops to 0. Tested with RX only nothing else on the plane. Also tried carrying the RX instead, leaving the TX behind in a slightly different position. Only got 150ft to failsafe. This implies the problem is NOT in the telemetry direction.
300ft x 30 = 9000ft what gives?
I'm only getting 1200ft to 40 RSSI.
Tx and RX antenna need to be in the same plain to get maximum distance, ie paralell to each other.
For line of sight I much prefer to use the wiska antenna , less total range but better diversity.
Your range tests sound reasonable to me and getting an odd rssi warning at 1200ft would not be anything to worry about, I too get them on occasion butnever had any loss of control and rssi levels immediately come back up to above 50 or so, I suggest logging your flights and seeing what the rssi looks like.
nigelsheffield is offline Find More Posts by nigelsheffield
Old Jul 12, 2015, 06:04 AM
Joined Oct 2007
Originally Posted by Nora View Post
hi everyone
thanks
Listen before talk is one of the main things the EU has, most would agree its best to stick with the normal version if you don't need to change.
Old Jul 12, 2015, 06:16 AM
SlowJeff is offline
SlowJeff's Avatar
Joined Apr 2015
Yeah... let's go there...
Old Jul 12, 2015, 06:17 AM
Nora is offline
Nora's Avatar
Malta, Żejtun
Joined Aug 2014
your telling me to shut up ?
thanks for the info ..il stick with the normal version then
Old Jul 12, 2015, 06:29 AM
Joined Oct 2007
I normally get told to think before I speak lol.
Old Jul 12, 2015, 12:24 PM
SBright33 is online now
Find More Posts by SBright33
Joined Sep 2014
Nigel, you're right, an occasional RSSI warning at 1200ft is no big deal. DEPENDING WHAT YOU SET THE ALARM AT. I set it to 40. During range test it rapidly drops from 40 to 0 as you walk away. An alarm at 48 mean you can go twice as far. An alarm at 40 is dangerous?
SBright33 is online now Find More Posts by SBright33
Old Jul 12, 2015, 02:30 PM
woglom is offline
Find More Posts by woglom
Joined Apr 2014
I have had my Taranis XD9 Plus for 3 months and it has been working great, the about 14 days ago I thought the battery was dying. It wouldn't hold a charge for very long. Then over the last week the screen slowly gets gray and fades off about 15 - 20 seconds after I turn it on. If I turn it off and then back on the screen stays blank although the radio gives me a verbal switch or throttle warning. I tried a different battery with the same result. Any ideas?
woglom is offline Find More Posts by woglom
Old Jul 13, 2015, 05:04 AM
LapinFou is offline
Find More Posts by LapinFou
LapinFou's Avatar
France, Lower Normandy, Falaise
Joined Mar 2014
I got exactly the same problem on a brand new T+. The root cause was a defective motherboard. Changing it (under warranty) definitely solved the issue.
LapinFou is offline Find More Posts by LapinFou
Old Jul 13, 2015, 05:32 AM
woglom is offline
Joined Apr 2014
Ok, thanks for the reply. I'm waiting to hear back from RMRC which is where I bought it. What bad timing! I'm at the tail end of a six week recovery from neck surgery......I'm fine but not released to go back to work for another 10 days or so. Just think of all the flying I could have done without spousal complaints!
New Product FrSky Taranis - 16 Channels, Full Telemetry, RSSI Rotozuk Radios 44138 Today 08:13 PM
Discussion Owner's Thread: ROC HOBBY 2.2M V-TAIL GLIDER by FMS/MOTIONRC StarHopper44 Electric Sailplanes 2139 Yesterday 11:48 AM
Question FrSky Taranis - assimilating web info mcshaz Radios 7 Jun 16, 2015 10:30 AM
Discussion is the FrSky Taranis next step after Turnigy 9X 9Ch tormodnt Radios 3 Nov 30, 2014 06:58 PM
