Old Dec 07, 2012, 03:58 PM
willfly4food84 is offline
Find More Posts by willfly4food84
willfly4food84's Avatar
United States, TX, Red Oak
Joined Jun 2008
ar6100 rx flaps and gear....
Is it possible to run flaps and gear on a ar6100 and how if so. I have a y on my ailerons and a y on my flaps and they all work but I cant get my flaps to run in the same direction because they are on a y..... please help....
willfly4food84 is offline Find More Posts by willfly4food84
Old Dec 07, 2012, 04:03 PM
freechip is offline
Find More Posts by freechip
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
Flaps & Gear(retract) requires you to have FLAP servos on the Aux1 channal.
So if you have a dual servo flap setup you have no choice but to mechanicaly take care of orientation or get a reversing Y harness. Some will say you can't use them with Spektrum BUT I have no experience with them and can't really comment on it.
freechip is offline Find More Posts by freechip
Old Dec 07, 2012, 04:07 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
The only ways to get the flaps to go in the same direction if the two servos are on the same channel are:
  1. Mechanically: shift the push rod and arm for one flap to the other side of the servo. Of course, that's not always possible.
  2. Get a reversing Y-cable or an in-line reverser (note that Spektrum specifically recommends NOT using one of these.
  3. Reverse one servo. This involves switching both the motor connections and the pot connections. May be tricky on a small servo.
  4. Find a similar servo that rotates in reverse.
Here's some more info:
http://www.rcgroups.com/forums/showp...94&postcount=6
Daedalus66 is offline Find More Posts by Daedalus66
Old Dec 07, 2012, 04:12 PM
Joined Jun 2008
thank yall very much! I guess i will swap the wires on the board and motor of the servo....
Old Dec 07, 2012, 04:24 PM
freechip is offline
Air, Ground & Water
freechip's Avatar
Joined Aug 2008
Swap the 2 motor leads around.
Swap the outer leads of the pot around.
Should do the trick but like mentioned above could be a bit trick on small servos.
Old Dec 08, 2012, 07:34 AM
Buschbarber is online now
Find More Posts by Buschbarber
Buschbarber's Avatar
United States, NY, Rochester
Joined Apr 2004
Depending upon the size of your aircraft, a JR Matchbox is a much better choice than a Reversing Y. The Matchbox allows you to set Neutral, Servo Direction, and End Points, for each servo.
I have never had good luck with Reversing Y's. Many times, the side with the Reversing circuit would drift off Neutral every couple of flights.
Buschbarber is online now Find More Posts by Buschbarber
Old Dec 08, 2012, 08:29 AM
freechip is offline
Air, Ground & Water
freechip's Avatar
Joined Aug 2008
If a AR6100 is being used a think JR match box might be overkill. I don't know just saying.
Old Dec 08, 2012, 08:32 AM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
I agree that reversing cables are pretty dodgy. But Matchbox is too much for a smallish model. Best bet is to reverse the servo if the OP has the skills and equipment.
Old Dec 08, 2012, 09:44 AM
Joined Apr 2004
I agree if the model has no room or weight is a factor.
Old Dec 08, 2012, 10:56 AM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Ya think!!!!! Good catch
Always better to get the mechanical linkage correct, As Daedalus mentioned in post #3.
While no mention has been made as to what ARF this is. I do know there are ARF's out there with the flap servo pockets molded in a mirror image as they should be for ailerons, but NOT the flaps. I guess the designers think everyone buying the model has at least an 8 channel radio and has the luxury of having each servo on a separate channel
Pete.
pilotpete2 is offline Find More Posts by pilotpete2
Wanted Orange Rx R415 or AR6100 or AR6100e Mike20 Aircraft - General - Radio Equipment (FS/W) 1 Sep 30, 2012 03:09 AM
For Sale Durafly T-28 Trojan w/flaps/retracts/lights/gear doors 1100mm (PNF fathallah2 Aircraft - Electric - Airplanes (FS/W) 33 Apr 29, 2012 05:59 PM
Sold Super Cx3 250 HYBRID. Ar6100e Rx EFL2001 HH gyro 3in1 Rex250 landing gear boom canopy blueindian Aircraft - Electric - Helis (FS/W) 0 Nov 16, 2010 01:50 AM
Sold Super Cx3 T250 HYBRID. Ar6100e Rx EFLH2001 HH gyro 3in1 T250 landing gear boom canopy blueindian Aircraft - Electric - Helis (FS/W) 0 Nov 15, 2010 02:14 PM
Sold Super Cx3 T250 HYBRID. Ar6100e Rx EFLH2001 HH gyro 3in1 T250 landing gear boom canopy blueindian Aircraft - Electric - Helis (FS/W) 0 Nov 12, 2010 12:04 AM
