Old Jul 13, 2015, 08:39 AM
raptor357 is offline
Find More Posts by raptor357
United States, MI
Joined Jan 2013
Originally Posted by dambit View Post
If your gear struts are bending every landing, perhaps it's not the struts that are the problem. Haha.
It's just the right one, I'm sure after the first bend its weaker and can't hold like it should, I guess I'll just order the replacement, I have seen the 10mm oleo struts and better retracts just wondering if they have been modded to work with this plane. I land in rough grass field
raptor357 is offline Find More Posts by raptor357
Old Jul 13, 2015, 08:42 AM
United States, MI
Joined Jan 2013
For 5 or 6 cell the power system would need to be replaced I'm sure the esc and motor can't handle it right? Right now it flies around 3/4 throttle the hole flight to keep it up
Old Jul 13, 2015, 09:22 AM
Cocg is online now
Find More Posts by Cocg
Fly and let Fly!
Cocg's Avatar
United States, CO, Grand Junction
Joined May 2010
With 5s, fly reserved .. You'll be fine.. 6S? Really? Watch the prop assembly too.. May not handle the rpms..
Cocg is online now Find More Posts by Cocg
Old Jul 13, 2015, 10:30 AM
United States, MI
Joined Jan 2013
Just take the motor and esc out of the 1700mm bird
Old Jul 13, 2015, 11:46 AM
paladin-34 is offline
Find More Posts by paladin-34
This area for rent
paladin-34's Avatar
Vestal, NY
Joined May 2006
while I never know what china does. the strut wire should be cold rolled steel and the more you bend it the stronger it gets. that however does not mean that after bending you can get it back to the way it was.
I use a Dlux 100 esc which allows me to run 5s. judging from my two 5s4k20c batteries you will need to have a battery that can put out 100amps (ie 4k25c), as mine have ballooned, well one ballooned the other is fine? I take from that I need to bump up the C rating
Joe
paladin-34 is offline Find More Posts by paladin-34
Old Jul 13, 2015, 11:56 AM
United States, MI
Joined Jan 2013
I can bend the strut with my hands pretty easy.
Old Jul 13, 2015, 12:04 PM
United States, MI
Joined Jan 2013
The hub is showing signs of stress already you can see the oblong holes started. Took a lot of weight to balance the hub and props.
Motor winding are not very clean either. Why would they put a 70 amp when this thing pulls 75 is beyond me
Old Jul 13, 2015, 12:31 PM
brandonmoon is offline
Find More Posts by brandonmoon
Fly & Have Fun..Enjoy the Ride
brandonmoon's Avatar
United States, AZ, Phoenix
Joined Mar 2009
I replaced all my stock FMS ESC's in my 1400 birds some time back with YEP 100A also did the 1700's as well (Throttle is much more linear now with the YEP ESC). The FMS ESC's are ok and fairly good, but like you mentioned above...just cutting it too close their limits and capabilities.
I moved those stock ESC's to other planes with lower requirements or hold on to them as backup spares They are actually ZTW ESC's with the FMS name on them.
That 580KV motor really needs an 85A or better ESC
brandonmoon is offline Find More Posts by brandonmoon
Old Jul 13, 2015, 12:43 PM
United States, MI
Joined Jan 2013
I was just looking at the YEP 100amp, you run the 4s or 5s with the YEP on the 580? Looking at the spec of the 580kv its rated at 850 watts i pull over 1000 watts already
Old Jul 13, 2015, 12:51 PM
Joined Mar 2009
It's a good ESC and very smooth linear throttle.... Works great in all my planes and EDF's. its was developed for Heli's but work great in planes.
I highly recommend getting the programming card with it
Old Jul 13, 2015, 01:29 PM
United States, MI
Joined Jan 2013
Here is a suspect winding
Old Jul 25, 2015, 07:17 PM
FieldofDreamsFlyer is offline
Find More Posts by FieldofDreamsFlyer
Field of Dreams Flyer
FieldofDreamsFlyer's Avatar
San Pedro,Ca
Joined Sep 2004
Messerschmitt BF109G-4 at RIAT 18th July 2015 (5 min 59 sec)
FieldofDreamsFlyer is offline Find More Posts by FieldofDreamsFlyer
Old Jul 25, 2015, 11:13 PM
dno264 is offline
Find More Posts by dno264
David
dno264's Avatar
San Francisco, CA
Joined Sep 2004
Excellent flying. Very scale.
dno264 is offline Find More Posts by dno264
Old Jul 25, 2015, 11:23 PM
pittso is online now
Find More Posts by pittso
Buy em , Break em,Buy em ect
Australia
Joined Mar 2013
About as scale as you can get ,seeing as its the real thing
pittso is online now Find More Posts by pittso
Discussion FMS 1400mm FW-190 Owners Thread Orion Pax Electric Warbirds 7128 Jul 13, 2015 09:24 PM
Discussion fms warbird owners thread warbird_cowboy Electric Warbirds 126 Mar 11, 2015 08:13 PM
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
New Product FMS Messerschmitt Bf109F 1400mm Beltpilot Electric Warbirds 1299 Mar 30, 2013 09:24 AM
Poll Choose the paintscheme of the new FMS GIANT Bf109F Beltpilot Electric Warbirds 41 May 31, 2010 05:44 AM
