Old Apr 12, 2012, 07:53 PM
electricrc68 is online now
Find More Posts by electricrc68
The Sweet Aroma of 92 Octane
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
Hitec HS-55 vs hs5055mg
hey guys. i plan on getting one of the two servos. im looking for the one that is the most durable out of the two and has the most power. i had two hitec hs55's but they just stopped working straight out of the box...thats why im wondering if the hs5055mg servos are the same? anyone have any opinions to state about the two?
electricrc68 is online now Find More Posts by electricrc68
Old Apr 12, 2012, 09:02 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
HS-55 are the most popular of servo,
there must be a reason for them to stop working soon out of the box.
Were they the right servo for the job?
101 - Servo FAQ & picking the right servo for the job
and was correct voltage being used?
Servo - Burnout. Cause & Prevention
The HS-5055MG is virtually the same servo, only being the digital version.
What is the application? perhaps a larger servo is required?
See also sub Section :
"Glitches & Jitter in Receiver, Servo & ESC - causes and cures " under
"Radio Systems, Accessories, Alterations and FAQ." at:
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
A.T. is offline Find More Posts by A.T.
Old Apr 13, 2012, 02:17 PM
Joined May 2011
thanks. the servo is going to be put into a losi 1/18 mini desert buggy. im not sure if its up to the task, but im needing a sub micro servo around the size of a hitec hs55 for it. any suggestions?
Old Apr 13, 2012, 03:44 PM
A.T. is offline
Joined Aug 2002
HS-55 not intended for those models, suspect you have stripped the nylon gears
- Replacement HS-55 Servo Gear Set.
The HS-55MG should fit but be aware that Losi Parts House recommends:
HRC35055S HS-5055MG Digital Metal Gear Sub Micro Servo with Tech Note
"Will not work with the stock Losi Mini-T ESC/Rec Combo Unit LOSB1087"
NB: Check that the servo saver (must be used) does fit the servo output shaft spline
correctly or use an alternate.
Hitec 2012 Servo Chart
Alan T.
(quick search = Ctrl+F)
Old Apr 13, 2012, 05:36 PM
Joined May 2011
cool thanks for all the help!
Discussion Hitec HS-55 servo humming weeheavy Radios 4 Apr 14, 2012 05:24 PM
Sold 3 X brand new in package HITEC HS 55 java8297 Aircraft - General - Radio Equipment (FS/W) 2 Apr 08, 2012 03:50 PM
Sold Like new Hitec HS-55 Economy Feather Sub Micro Servos thundercl58 Aircraft - General - Radio Equipment (FS/W) 1 Mar 29, 2012 04:07 PM
Sold Hitec HS-81's,HS-55'S, two standardservos kg4min Aircraft - General - Radio Equipment (FS/W) 3 Feb 17, 2012 12:21 PM
Hitec HS-55 vs HS-56... kleckner 3D Flying 10 Jan 06, 2005 09:26 AM
