Old Feb 06, 2015, 11:14 PM
mozzyrocks is offline
Find More Posts by mozzyrocks
Australia, VIC, Blackburn North
Joined Feb 2011
This HAS to be the universes way of telling me to stop bothering with this hull and buy a newer better one!
I went outside to bring the hull in and it had been blown off the hook and smashed to the ground damaging the front again and splitting the rear and wrecking the strudder mount points!
FFFFFFFFFF.................!!!!!!!!!!!
mozzyrocks is offline Find More Posts by mozzyrocks
Old Feb 07, 2015, 12:48 AM
Joined Feb 2011
I can't remove the strut as the nuts keep turning on the inside and I can't get in to grip them.
Game over!!!
Genesis hull will be given away and I'll just buy a V hull to put the motor, ESC and drive line in.
Any suggestions on hull?
I was thinking a Pursuit or carbon Ariane 2 or the Osprey from HK.
The Pursuit is the cheapest, then the Osprey and the Ariane......at $600 is a little pricey, unless I can get a carbon V hull with hardware somewhere else cheaper?
Old May 19, 2015, 05:14 PM
nevi is offline
Find More Posts by nevi
Finland, Northern Ostrobothnia, Oulu
Joined May 2015
hello boaters
i finally ordered my own hk genesis.
its used but in good condition.
cooling has been upgraded greatly, it has also 200a esc, handcrafted steel rudder, and it includes stock & upgrade engine also
i just ordered 4pcs of 3S 30C 5000mah batteries and couple connectors so i can run it on 6S maybe i will try to run it on 6S 10000mah and see is there too much weight by that configuration.
i will post couple photos when i get the boat home
greets from finland!
nevi is offline Find More Posts by nevi
Discussion Genesis setup recommendations stuglas69 Racing Boats - Electric 32 Jul 03, 2015 09:55 PM
Question TFL Hobby GENESIS twin setup Alfa Twin Spar Racing Boats - Electric 54 Feb 21, 2014 08:43 AM
Yippee! Carbon Fiber Genesis Hulls!! FighterCat57 Racing Boats - Electric 7 Dec 03, 2010 01:34 PM
Discussion bought the "Genesis Offshore Twin Hull",need opinions! ginnz Racing Boats - Electric 77 Oct 20, 2010 04:52 PM
Sold Genesis Cat Dangerous_toys Boats (FS/W) 5 Sep 09, 2010 11:29 PM
