Old Jul 04, 2010, 09:41 PM
galaxiex is offline
Find More Posts by galaxiex
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
Originally Posted by Cralis View Post
How long ago would they have changed? I have on that's maybe... 8 months old. Would that be a switching one? Is there a way to tell?
Probably it is the switching BEC.
2 clues....
The 3 wire lead that goes to the Rx has a ferrite choke on it, and the ESC itself has a large square heatsink on the side opposite the sticker.
The older one's with the linear BEC did not have the ferrite, or the large heatsink.
EDIT;
Actually it's not a heatsink.... it's a metal "cage" to contain the noisy switching circuitry.
The heatsink for the ESC proper, is on the sticker side.
Yes, I have peeled off the shrinkwrap and had a look.
galaxiex is offline Find More Posts by galaxiex
Old Jul 04, 2010, 09:48 PM
Cralis is offline
Find More Posts by Cralis
I love FPV!
Cralis's Avatar
Eastern side of Australia
Joined Jan 2007
Thanks sir! I'm indeed switching then.
I'm maybe 7 days from maiden... but am already deficating myself about the throw.. how hard I'll need to throw etc...
So... I'm wondering... what are the wheel options? Or maybe ... a trolly! I am lucky to have a few cricket pitches when I fly... I could take off on that, leaving the trolly behind when there's sufficient lift?
Ah - be Brave, Cralis, and just chuck the damn thing!
Cralis is offline Find More Posts by Cralis
Old Jul 04, 2010, 09:52 PM
saabguyspg is offline
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
get someone to chuck it for you! lol... I hate having to chuck my maidens myself...
saabguyspg is offline Find More Posts by saabguyspg
Old Jul 04, 2010, 09:58 PM
Kev.au is offline
Find More Posts by Kev.au
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Get you're wife to throw it!, you can blame her if it crashes..
Cheers, kev.
Kev.au is offline Find More Posts by Kev.au
Old Jul 04, 2010, 10:02 PM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
haha.. good call, but have you seen my wife throw? when she throws a stick or a ball for the dog.. the dog really doesn't have to get up to go fetch it. No - that will certainly not work... Wow, I hope she doesn't check these forums!!!
Old Jul 04, 2010, 10:04 PM
Bear_au is offline
Find More Posts by Bear_au
Bear_au's Avatar
Australia, NSW, Peakhurst
Joined Mar 2006
Better to go opto... take out +pin on speedie (Red) and use a ubec from your aux battery that runs the vid and TX..
http://www.hobbycity.com/hobbyking/s...oise_Reduction
Use a ferrite core over the ubec (comes with one) and also just run your X3 AC lines from the motor , just have them past through the ferrite core ring and on the other led to you RX but wrap that as many times as you can.. cuts most of , if not all the high speed switching RF from the speedie.. every little helps
Cheers
Richard
Bear_au is offline Find More Posts by Bear_au
Old Jul 04, 2010, 10:06 PM
Kev.au is offline
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
hehe, i don't think you'll have to much trouble. Does it weigh much more than your EZ*?.
Most of the videos i've seen of the Walker, the launch has looked quite effortless.
Cheers, kev.
Old Jul 04, 2010, 10:24 PM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
For you, I just ordered a $7.95 scale off ebay. Delivered! it's gonna be a high quality scale! So, I'll get an AUW for you.
The SW is quite a bit heavier, but once you have the tail on, wings... which I did for the first time last night, I'm shocked, amazed and happy at the size. it's HUGE!! I've held it in the throwing position... and it feels good to throw... but it's way bigger than the EZ*... It's boardering on intimidating! It's a very very big plane. I like it though!
My only concern is what people have been saying... it flys at 50km/h. Now, on my throws with the EZ*, I usually go to maybe 60% throttle and throw... and then adjust the throttle to get a nice flat path, gaining speed and then climbing. But my OSD says I throw it to around 30km/h ...
So, throwing the bigger, heavier SW... I expect to obtain the same speed on the throwm which means it will need to gain speed rather quick, if it cruises at 50! I've got around 20km/h to gain before I am flying. Until then, I'm stalling!
That's my only worry... That, and hitting my head as the tail comes past!
Old Jul 04, 2010, 10:40 PM
galaxiex is offline
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
50km/h may be cruise speed.... but what is the stall speed?
I bet it's less than 50km/h.
Probably your 30km/h throw is plenty.
Old Jul 05, 2010, 12:19 AM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
sooo. I finished up the plane the other day. Topped out at 1.7kg which isnt too bad and it balances well in front of the servo wires so I might even have to move my battery back a little. Cant complain about that Next it to see how it flies.
ashdec87 is offline Find More Posts by ashdec87
Old Jul 05, 2010, 12:25 AM
Kev.au is offline
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
That's a good weight Ash. How many mAh you running?.
Cheers, kev.
Old Jul 05, 2010, 12:32 AM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
I've got two packs to choose from. A 4s3500 and 4s4000. Both are identical weights cuz of the C rating, but the setup draws something like 16-18 amps WOT (works out to 270 watts) , so I'm looking at some insane flight times... Im also running a 1300mah video battery.
Old Jul 05, 2010, 10:22 AM
Thumb_number is offline
Find More Posts by Thumb_number
I think my wheels fell off.
Thumb_number's Avatar
Perth
Joined Oct 2009
Mines done. No special mods. 2 x 2200 and a GoPro balances fine and IMO CoG should not be any more forward than the servo wires even 5-10mm back works good. Enjoying this plane lots.
http://vimeo.com/13097075
Thumb_number is offline Find More Posts by Thumb_number
Old Jul 05, 2010, 10:31 AM
IL76MD is offline
Find More Posts by IL76MD
fly it high as possible
Falls Church, VA
Joined Jun 2009
[QUOTE=Thumb_number;15470107]Mines done. No special mods. 2 x 2200 and a GoPro balances fine and IMO CoG should not be any more forward than the servo wires even 5-10mm back works good. Enjoying this plane lots.
Hi there,
it's nice video, really smooth and enjoyable. Do you use some kind of gyro,
Co-Pilot?
IL76MD is offline Find More Posts by IL76MD
CoastalTom is online now
Find More Posts by CoastalTom
United States, AL, Foley
Joined Nov 2005
Really nice flying and video!
What motor are you using?
CoastalTom is online now Find More Posts by CoastalTom
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
