Old Oct 10, 2012, 12:45 PM
sloperb is offline
Find More Posts by sloperb
Auburn, WA
Joined Nov 2005
100-120g 3D kit?
I have the E-Flite UMX Extra 300 and a EPP Leadfeather Yak. Love them both, but the Yak is a little big for my back yard and the UMX Extra 300 is a little small if there's any wind.
I'm looking for something in between. I'm considering just scratch-building the Yak smaller, but I thought I'd check if there's a kit out there people really like?
sloperb is offline Find More Posts by sloperb
Old Oct 10, 2012, 03:56 PM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
Twistedhobbys is about to release a new Crack Yak Lite. Could be just what your looking for
Aviefly is offline Find More Posts by Aviefly
Old Oct 10, 2012, 05:59 PM
sloperb is offline
Auburn, WA
Joined Nov 2005
I'll keep an eye out for that for sure. Can't tell right now if it will be slightly smaller or just a lighter build from the threads I read. Lighter build might make it more floaty than I like, but am definitely going to watch for this one.
Old Oct 10, 2012, 06:17 PM
cwojcik is offline
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
Crack Yak Lite is not the only thing coming out soon to scratch an itch like this. I can't say any more than that.
cwojcik is offline Find More Posts by cwojcik
Old Oct 10, 2012, 08:25 PM
KamikazePilot is offline
Find More Posts by KamikazePilot
Twisted Do Nut!
KamikazePilot's Avatar
Joined Dec 2010
There you go teasing us Cody!
Joking aside, have you thought about doing the smaller version of Leadfeather's yak? The 19 and 22 inch versions are just as easy to build as the 32 inch. If you have the gear for one of those that is.
KamikazePilot is offline Find More Posts by KamikazePilot
Old Oct 10, 2012, 08:34 PM
Get Real is offline
Find More Posts by Get Real
Flippin Multirotors
Get Real's Avatar
Illinois
Joined Feb 2006
If your comfortable with scratch building it wouldnt be difficult to cut a 32'' leadfeather yak in the 4oz range using light components. I usually get my epp from rcplanebuilder in 1.3lb 9mm but for lighter planes i go with 6mm 1.3lb. This was a slicko 32.5'' i cut from 6mm 1.3lb epp quite a while back and its a larger plane than a leadfeather yak to begin with so you could probably get the yak slightly lighter just from it being a smaller size plane to start.
Slicko SL 4oz 32'' 3D EPP Plane Test Flight! (3 min 18 sec)
Get Real is offline Find More Posts by Get Real
Latest blog entry: Simplecopter T-Copter
Old Oct 10, 2012, 11:58 PM
sloperb is offline
Auburn, WA
Joined Nov 2005
Funny, I found that video when I was searching earlier and said "yep, that's what I want".
Scratch building a scaled down Yak is quite tempting. The appealing thing about a kit is that the kit-builders have worked all the kinks out of the process and usually tried a few different motor/esc/battery/prop combinations to get the right performance. Its really the trial-and-error part of that that I'd like to avoid. I scratch-built a 3mm depron 22" leadfeather, but didn't have the right motor for the weight to make it do 3D (flew nice, but thrust/weight was off).
Mind sharing what components you used in that slicko?
Old Oct 11, 2012, 12:00 AM
sloperb is offline
Auburn, WA
Joined Nov 2005
I came across this one as well... looks like it might be a good fit for what I'm looking for.
http://www.dwfoamies.com/28in-yak-junior
Old Oct 11, 2012, 01:39 AM
Get Real is offline
Flippin Multirotors
Get Real's Avatar
Illinois
Joined Feb 2006
I flew the slicko sl on a few different packs,outrunners etc. This is the set up in the video posted above: t-motor 1804 outrunner,7x3.5 gws prop,turnigy plush 6amp esc,rc pro packs 220mah 2s 25c lipo,power hd 6g servo on ailerons,4.4 power hd's on the tail. I flew it heavier as well and took it with one time to the track and flew inside with it. Depron flys much crisper and more precise for sure,ive cut some depron planes from popular 9mm epp planes like the crack yak as well and you can drop the auw down quite a bit even using similar power set ups but depron is crunchy and not as forgiving if you crash but well worth it because they do fly very nice.
The slicko sl at the track.. should of doubled up the prop bands
Slicko SL Flying At RaceWorld Raceway 4.6oz Set Up (1 min 47 sec)
Old Oct 12, 2012, 12:12 PM
Aaeolien is offline
Find More Posts by Aaeolien
3d addict
United States, NY, Rochester
Joined May 2011
Cody the question becomes when do we get some more details?Hehe. Dying here waiting. Money burning a hole in my pocket. Hehe.
Aaeolien is offline Find More Posts by Aaeolien
Old Oct 12, 2012, 07:18 PM
asosestrom is offline
Find More Posts by asosestrom
United States, CA, Santa Rosa
Joined Mar 2011
OK, now I'm listening
asosestrom is offline Find More Posts by asosestrom
Old Oct 12, 2012, 10:39 PM
DRAMJET is offline
Find More Posts by DRAMJET
2 metre rule applies!
DRAMJET's Avatar
BOOGI, Australia
Joined Dec 2008
The Dualsky Mini Breeze may be something to look at. 24" wingspan, EPP, and about 3oz/100g but would be able to build lighter. Haven't flown this one but have been tempted having had the depron Breeze a few years ago until its AUW blew out with glue and tape repairs.
http://www.rcgroups.com/forums/showthread.php?t=1351809
DRAMJET is offline Find More Posts by DRAMJET
Discussion 3D CP size 100 heli UNDER $100.00! the desolate one Micro Helis 12 Mar 31, 2012 11:56 AM
Discussion Is there a good 3D kit for less than $100 shipped? texbird 3D Foamies 13 May 20, 2011 08:42 PM
Discussion Wildhonet on Vasafan 120G Vaclav Blaha Electric Ducted Fan Jet Talk 10 Jan 25, 2011 03:35 AM
120g EDF J35Draken!! henke Electric Ducted Fan Jet Talk 29 Feb 12, 2002 01:20 PM
