Old Dec 30, 2011, 12:34 AM
Luis Moya is offline
Find More Posts by Luis Moya
Luis Moya's Avatar
Mexico
Joined May 2004
Need tips to Avoid Hanging Prop
Most pictures of flyings sailplanes show one blade attached to the fuse and the other hanging.
Neddles to say, my planes also show this behavior. Are there effective tips to avoid the unnecessary drag from the hanging blade?
All the best,
Luis
Luis Moya is offline Find More Posts by Luis Moya
Old Dec 30, 2011, 01:13 AM
smewr is offline
Find More Posts by smewr
smewr's Avatar
United States, PA, Easton
Joined Jan 2009
A very small rubber band attached to very small hooks will work on Art-Hobby gliders.... I made my hooks out of stainless steel wire, drilled tiny hole near blade root, knotted SS wire, pulled wire thru and made a tiny hook for the rubber band to hook to. When power is off, blades snap back flush to fuselage, I've heard this is popular in Europe....
smewr is offline Find More Posts by smewr
Old Dec 30, 2011, 01:43 AM
DingoII is offline
Find More Posts by DingoII
Czech Rep.
Joined Aug 2006
Hi Luis,
A rubber loop works fine for me, however I found it needs to be fixed with pieces of tape, at least with the yokes/spinners I do use. Very primitive, I know...
One afterthought: I find opening and closing the canopy pretty annoying when I have to fight the interfering blades
Regards,
Jan
DingoII is offline Find More Posts by DingoII
Old Dec 30, 2011, 04:07 AM
Kenny Sharp is offline
Find More Posts by Kenny Sharp
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
Rotate the yoke on the shaft (you may have to grind a flat spot in the shaft in a different location), ....so the blades stop sideways, instead of up and down.
Kenny Sharp is offline Find More Posts by Kenny Sharp
Old Dec 30, 2011, 07:04 AM
WimH is offline
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
Use the "Reisenauer" clamp spinner/yokes, they have rubber O rings available and the design takes them into account....
WimH is offline Find More Posts by WimH
Old Dec 30, 2011, 09:25 AM
Leadchucker is offline
Find More Posts by Leadchucker
AMA7224 LSF1832
Leadchucker's Avatar
United States, DE, Seaford
Joined Sep 2008
I use rubber bands similar to Dingo's method, but with no tape. Make a half twist in each end then slip the loop over the prop hub, the middle loop behind the yoke with the motor shaft inside the loop,then the last loop over the other prop hub. You might have to remove the second prop blade from yoke to get the loop over the hub. Dress the rubber band so it's even and there's no interferance with the spinner or motor screws. Close fitting spinners might not let you use this method. I am not aware of any way to index the prop when stopped as Kenny Sharp suggested. It would be nice if there is one.
Excuse the crude drawing but you can get the idea from it.
Leadchucker is offline Find More Posts by Leadchucker
Old Dec 30, 2011, 09:45 AM
Luis Moya's Avatar
Mexico
Joined May 2004
smewr
This seems to be intuite right, although I have problems visualing your actual implementation. A photo or two could made it clearer.
Thanks a lot,
Luis
Originally Posted by DingoII View Post
Hi Luis,
Regards,
Jan
Jan,
Clear and simple. I'll try this while waiting for pictures from smewr.
Luis
Old Dec 30, 2011, 09:51 AM
Luis Moya's Avatar
Mexico
Joined May 2004
Leadchuker,
Will study your method. Crude drawing beats no drawing every time.
Luis
Old Dec 30, 2011, 11:29 AM
turn, turn, turn.
Joined Oct 2005
I've tried rubber bands ...not a huge fan.
WimH knows a lot of solutions ...I'd check out Reisenauer just in case rubber bands keep breaking on you.
Discussion Hanging electric planes by their motor/prop? copperbricks Electric Plane Talk 15 Jan 19, 2012 09:46 PM
Discussion Hanging t-28 by prop Whomprat Electric Plane Talk 5 Jul 11, 2011 08:35 PM
Help! prop hanging jbrracer 3D Foamies 7 Jun 10, 2011 04:21 AM
Discussion Static thrust and prop-hanging ulogix Electric Plane Talk 15 Apr 01, 2011 03:28 PM
