Old Feb 16, 2006, 12:27 AM
Wingman65 is offline
Find More Posts by Wingman65
Build, Fly, Crash..Repeat
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
This is gen 3 fuse. It is thinner and has nothes in hinge area. My only complaint since I use balsa elerons. I added .210 carbon tubes in this area and added .25 balsa strips for my hinges as well as 2" wide fiber glass strip across the the entire rear to help prevent flex. The fg is adhered with Z-poxy and microbaloons. Use this mod on all my Strykers and never a failure in this area.
Tony
Wingman65 is offline Find More Posts by Wingman65
Old Feb 16, 2006, 05:00 AM
dfemmert is offline
Find More Posts by dfemmert
United States, OH, Cin
Joined Nov 2003
Check out the Ultimate Electric Jet Video at the bottom of this page!!
http://www.2kool4u.com/stryker/
dfemmert is offline Find More Posts by dfemmert
Old Feb 16, 2006, 10:43 AM
lowdive is offline
Find More Posts by lowdive
lowdive's Avatar
anaheim, ca
Joined Apr 2005
That is the Aero-Naut Blade 2
http://www.aero-naut.net/index.php?id=139&L=1
If you've got an extra $800 to spend, that would be one way to spend it.
lowdive is offline Find More Posts by lowdive
Old Feb 16, 2006, 01:32 PM
MTwallet is offline
Find More Posts by MTwallet
Gotta have more cowbell!!
MTwallet's Avatar
Clawson, MI USA
Joined Sep 2002
If you like that, then you'll like this too...
http://www.turbinemuseum.de/teddyjet.wmv
Looks like a modified Twin Jet, I think this could be done to the Stryker too. Any takers?
MT
MTwallet is offline Find More Posts by MTwallet
Old Feb 16, 2006, 02:34 PM
dfemmert is offline
Joined Nov 2003
Nice vid, thanks.
That thing is about the same size as the Stryker, it could be done. I want to see a turbine powered Stryker!!
David
Old Feb 16, 2006, 02:37 PM
lowdive is offline
lowdive's Avatar
anaheim, ca
Joined Apr 2005
yeah, looks like a twinjet fuse.... it doesn't look much faster than my stryker turning a prop, though. then again, it's hard to tell if he's doing much flying at full throttle. fuel, turbine, foam? i don't like my chances!
Old Feb 16, 2006, 03:31 PM
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
Wow. Nothing compares to the sound of a jet engine, large or small.
Old Feb 16, 2006, 08:41 PM
crash test dummy is offline
Find More Posts by crash test dummy
Foamsmithing forever!!
crash test dummy's Avatar
Sugar Grove, Il.
Joined Aug 2004
I with lowdive, my stryker looks faster unless he was holding back. I think the camera man should lay off the Starbucks before shooting.
CTD
crash test dummy is offline Find More Posts by crash test dummy
Old Feb 16, 2006, 08:42 PM
Sugar Grove, Il.
Joined Aug 2004
I with lowdive, my stryker looks faster unless he was holding back. I think the camera man should lay off the Starbucks before shooting. I must admit, you got to love the cool factor of the turbine.
CTD
Old Feb 16, 2006, 10:31 PM
MTwallet is offline
MTwallet's Avatar
Clawson, MI USA
Joined Sep 2002
Yeah, my propped Stryker looks faster too, but it does seem like the pilot was holding back some. The turbine never really seemed to realy wind up to me. Who knows, I just thought it was cool and love the sound of turbines. It's cool to know too that you can use a turbine is something like that though without all the electronic starting and monitoring stuff, plus the propane bottle in there weighing it down.
MT
Old Feb 17, 2006, 07:50 AM
dfemmert is offline
Joined Nov 2003
He did seem to be running it kind of easy and only got a little over 4 1/2 minutes of run time. It probably doesn't have a very large fuel tank. If he ran at full throttle, he would probably only get a 2 or 3 minute flight but there's nothing like the sound of a turbine.
David
Old Feb 17, 2006, 08:44 AM
lowdive is offline
lowdive's Avatar
anaheim, ca
Joined Apr 2005
yeah, definitely can't put down that lovely whistle. mmm.... one of these days i'll have my turbine engine put together (using a truck turbo)
Old Feb 18, 2006, 11:51 AM
Sugar Grove, Il.
Joined Aug 2004
Hey Boys,
Check out this pocket rocket!!! Now this is a turbine!!
Enjoy.
http://media.putfile.com/Mini-Delta-Turbine78
CTD
Old Feb 18, 2006, 04:17 PM
MTwallet is offline
MTwallet's Avatar
Clawson, MI USA
Joined Sep 2002
CTD, that video is awesome!!
Puts mine to shame!
That is how a turbine should look and sound!!
MT
Old Feb 18, 2006, 05:32 PM
kfong is offline
Find More Posts by kfong
Sterling Heights, Michigan, United States
Joined Nov 2003
Wow CTD that is fast, wish they weren't so darn expensive. I would make one if I knew how. Anyone know if there is published plans for a micro turbine on the web?
Well it's time for a new Stryker, the old one was looking pretty sad, even though it still flies. The new Stryker has a 16/25/4, and a 3100 4cell pq pack, 7x7 speed prop with lots of thrusts for this little piggy, current prop is to keep my batteries protected till I install an onboard monitoring system. It won't be a full out speed demon but it will be plenty fast and a great test bed for some new power plants I will be trying out, plus I wanted a version that could fly in heavy winds. The paint job turned out ok, but I think I will stay away from the copper color next time, once I accented it with black flames I started to like it again. Mods on this version are my own custom motor mount, bidirectional tape along the leading edges and motor area, vented canopy, vents on the sides and a complete covering of thinned goop. This stuff seems to take paint quite well but it's really nasty to breathe. Take precautions if you use it, it's also heavy as well, best to thin it down quite a bit if you don't need to bullet proof it.
Kin
http://www.embeddedtronics.com/
kfong is offline Find More Posts by kfong
F-27 Stryker How Far Can You Take It? Part 3 Fred Bronk Parkflyers 560 Jul 03, 2005 01:04 AM
F-27 Stryker How Far Can You Take It? Part 2 Michael Heer Parkflyers 861 Apr 10, 2005 10:02 PM
F27 Stryker...How far can you take it? ChuckD Parkflyers 536 Feb 16, 2005 06:33 PM
Corona: How far can you build, Kit only NewRotorSoon Electric Heli Talk 4 Mar 03, 2003 10:55 PM
Slow Stick on Kokams.... or how long can you take it? Tres Wright Parkflyers 20 Jan 21, 2003 09:20 AM
