Old Jul 30, 2013, 06:35 AM
JoeR is offline
Find More Posts by JoeR
USA, NY, Jamestown
Joined Jun 2000
Question
Can standard voltage Hitec servos run safely on 2S A123 (LIfe) packs?
Can standard (not HV) Hitec servos run on a 2S A123 pack (Life batteries)? I've got some 5965 servos that I'd like to run on a 2S A123 pack instead of messing with a BEC in a large electric plane.
A fully charged 5 cell NiMH is 7.5 volts (1.5v x 5 - I believe) while a fully charge A123 (Life) pack is 7.2 (3.6 x 2). Should be fine?
JoeR is offline Find More Posts by JoeR
Old Jul 30, 2013, 04:10 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Yes, as covered under:
. Servo - Operating Voltage Range - (Hitec) usuage with NiMH, Lipol & A123 batteries.
extract: |Update 20 Jan 2012:
A123 Update
"Any Hitec standard size servo can be used with unregulated A123's. - Mike."
As always, the higher the voltage, the higher the speed and current draw which inevitably leads
to a reduction in life expectancy of the servo and associated gear.
. Servo - Burnout. Cause & Prevention
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Discussion Peak Voltage LiFe 2s? TedFlack Batteries and Chargers 6 May 09, 2013 11:47 AM
Discussion In-flight voltage of 2s LiFe battery Dan Zero-G Hand Launch 15 Feb 19, 2013 08:36 AM
For Sale Brand New WRC Wike IBEF for 2s LiFe / A123 SpinMeUp - Gyro Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 02, 2013 09:09 AM
Discussion LiFe/ a123 rx pack voltage and servos hidaven Electric Plane Talk 3 Mar 14, 2012 03:44 PM
