Old Jan 02, 2015, 07:07 AM
OldRCNut is offline
Find More Posts by OldRCNut
Still Flying
OldRCNut's Avatar
United States, WI, Fond du Lac
Joined Mar 2013
MV Motors
Originally Posted by corsair2014 View Post
i put the j3 cub motor in the Night Vapor with a 150mah battery and it would pull vertical with ease and fly for 15 minutes.... i think that would be way too much power for the mini vapor... are the motors even the same size?
Yes - They are both the same 6mm diameter so both motors fit the MV gearbox. The stock MV motor is about 10 mm long and the J3 motor about 15mm long.
OldRCNut is offline Find More Posts by OldRCNut
Old Jan 02, 2015, 11:15 AM
corsair2014 is online now
Find More Posts by corsair2014
United States, TX, Cypress
Joined Jan 2012
dang that would be alot of power... haha
corsair2014 is online now Find More Posts by corsair2014
Old Jan 06, 2015, 06:24 PM
James_S is offline
Find More Posts by James_S
United States, WA, Woodinville
Joined May 2014
Originally Posted by Torch8 View Post
MV discontinued what will replace it?
Still nothing in the works to replace it? That was over a year ago and I just recently discovered this plane on Horizon's site. Even had my wallet out to buy one when I saw it had been discontinued. Dang, I love my Night Vapor and would buy a smaller version in a heartbeat.
James_S is offline Find More Posts by James_S
Old Jan 06, 2015, 09:34 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
I don't know why the discontinued it... my guess it it didn't sell real well (until the clearance sale anyway) being that it wasn't all that much cheaper than the regular vapor, and you really cant fly it anyplace you couldn't fly the vapor.... I only got one because of the clearance sale.
dacaur is offline Find More Posts by dacaur
Old Jan 08, 2015, 01:14 PM
Joined Jan 2012
yeah same i got mine for 30 dollars a few years ago^
it actually flys faster than my night vapor did...
Old Feb 13, 2015, 01:04 PM
brathering is offline
Find More Posts by brathering
Germany, NRW, Lippstadt
Joined Jan 2015
What is the weight of the 30 mah battery?
Can I use turnigy nano tech 60 mah batteries or are they too heavy?
brathering is offline Find More Posts by brathering
Old Feb 13, 2015, 03:35 PM
rccraze is offline
Find More Posts by rccraze
rccraze's Avatar
United States, VA, Herndon
Joined Jul 2012
Nanotech 60 mah works great! You can get good 8 minutes of spirited flight. It is not heavy for mini Vapor.
rccraze is offline Find More Posts by rccraze
Old May 11, 2015, 04:30 AM
R31 Mark is offline
Find More Posts by R31 Mark
amidoinitrite¿ ¿
R31 Mark's Avatar
Joined Feb 2012
Hi Guys, I have received a Mini Vapor brick that I ordered through the mail, after making sure that it binded and the servos worked, I am confused as to how to wire the motor wires to the brick. Could somebody give me some advice and point me to where the motor wires are supposed to go to on this brick? I assume I need to solder them to it yes?
Thank you
R31 Mark is offline Find More Posts by R31 Mark
Old May 11, 2015, 01:50 PM
ruzam is offline
Find More Posts by ruzam
Go small or go home
ruzam's Avatar
Canada, SK, Regina
Joined Mar 2008
Post #1616
ruzam is offline Find More Posts by ruzam
Old May 13, 2015, 04:25 AM
R31 Mark is offline
amidoinitrite¿ ¿
R31 Mark's Avatar
Joined Feb 2012
Originally Posted by ruzam View Post
Thankyou! Are the wires soldered to the bottom side of that part of the board? I can't see the wires up top near the black thingy
Old May 13, 2015, 11:19 AM
ruzam is offline
Go small or go home
ruzam's Avatar
Canada, SK, Regina
Joined Mar 2008
Yep, bottom side. You'll have to remove the board from the frame to get to them.
Old May 15, 2015, 05:53 AM
R31 Mark is offline
amidoinitrite¿ ¿
R31 Mark's Avatar
Joined Feb 2012
Thankyou! Worked out fine for me
Old Jul 28, 2015, 07:28 PM
Lostcity is online now
Find More Posts by Lostcity
United States, MI, Portage
Joined Apr 2013
Broke horizontal stab close the hinge. I can find a new since my epoxy fix did not last. Has anyone done this repair? Looking for tips on getting the tail feathers off the frame without further breaking it.
Lostcity is online now Find More Posts by Lostcity
Old Jul 28, 2015, 08:24 PM
jbarchuk is online now
Find More Posts by jbarchuk
DeBary, FL
Joined Nov 2010
Lap in 'something' across the break. Very fine CF would be best of course. A bit of sewing pin is heavy but strong. A bit of toothpick is weak but light. (Though a soak with thin CA (after the next step) will make it *much* stronger.) On -each- -side- of the lap joint wrap and tie with spiderwire, dental floss, or thread. Then dab in thin CA to freeze it all. The curve of the repair stab won't be anywhere near the same as original but at these speeds that doesn't matter at all. Lightweight is ALWAYS best.
jbarchuk is online now Find More Posts by jbarchuk
Old Jul 29, 2015, 06:58 PM
Joined Apr 2013
Break is at the hinge so I think a new stab is in order. Thanks though.
Wanted I Need a Parkzone (Vapor) DSM2 Rec/ESC/servo "Brick" *** Joe Pierson Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Mar 25, 2012 10:27 PM
Sold parkzone vapor bnf original $50.00 shipped chrisb22 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Mar 03, 2012 01:25 PM
