Old Oct 10, 2001, 07:21 AM
NipponDave is offline
Find More Posts by NipponDave
http://www.aircraft-world
NipponDave's Avatar
American in Japan
Joined Mar 2001
Electronites! Put on your thinking CAPs
A pal of mine has a Jeti JES-70-3P Opto brushless ESC. After running for about a minute at half throttle on his test bench, the ESC blew its capacitor (condenser). He was running 16xCP1700 on Mega 22-20-2 motor (~42A full throttle).
He was using a clamp meter and his leads from battery to ESC totaled about 7", so there are no apparent problems with his setup.
The Jeti 70-3P Opto has one 470/25V cap.
Should this cap size be sufficient?
Would a 470/63V cap do a better job? Or should he use two of the 470/25V?
This question was left dangling in another thread, so I'd really appreciate some help from an electron-enabled member - I don't know enough to advise my buddy on this issue.
NipponDave is offline Find More Posts by NipponDave
Old Oct 10, 2001, 08:23 AM
Mikael Pedersen is offline
Find More Posts by Mikael Pedersen
Certified Propellerhead
Copenhagen, Denmark
Joined Mar 2001
I can see several problems here:
1: 25V is perhaps a little short of what a freshly charged 16-cell batterypack will put out. But i don't think it is that big a problem. But please don't put in a new 25V cap. Find a 35V type (or more).
2: I don't know what type of cap that are used on the Jeti controllers, but it may not have been able to handle the high switching currents. Replace it with a high current / low ESR type.
3: A Mega 22-20-2 on 16 cells really doesn't sound like a combination i would try, even in my dreams. Isn't the 22-20-2 designed for 7 cells use?
Mikael Pedersen is offline Find More Posts by Mikael Pedersen
Old Oct 10, 2001, 08:27 AM
Gerald is offline
Find More Posts by Gerald
ὅπερ ἔδει δεῖξαι
Gerald's Avatar
Joined May 2000
If you can measure the voltage waveform on the cap with an oscilloscope it may give you a clue as to why it failed. It seems common for these large electrolytics to get hot in our brushless controllers. The 16 cell pack could have exceeded the voltage rating of the cap when freshly charged. At 1.6 volts per cell that comes to 25.6V. This of course will drop rapidly as soon as any significant current is extracted from the battery. Part throttle operation at high currents will produce current pulsations in the battery circuit. It is the purpose of the cap to act as a buffer to reduce the effect this would have on the ESC circuitry. If the combined wire length of the battery and ESC is long, or if the wire is undersized, the pulses can be larger. Inductive effects in the wires can then magnify the voltage, so it is again possible that the 25V rating was exceeded. Also, these electrolytic caps tend to heat up when subjected to high power / high frequency duty. The heating reduces the performance of the cap and it should be de-rated as a result. I'd suggest using a higher voltage capacitor at those higher cell counts, perhaps 35V. Also be sure that the wire is at least 14 or even 12 guage to support the high current.
All that said, I recommend the controller be returned to the manufacturer for repair before any mods are made if it is still under warranty.
Gerald is offline Find More Posts by Gerald
Old Oct 10, 2001, 10:30 AM
NipponDave's Avatar
American in Japan
Joined Mar 2001
1) So should I use two 25V caps in parallel, or one 67V? I don't have a souce for 35V Caps and have plenty of 25V and 63V in hand.
2) Says 470/25V, looks just like the cap you'd find on any other ESC - don't know more than that...
3) Actually, the Mega 22-20-2 on 16 cells, 5:1 gear and 13x8 prop is just about ideal - extremely efficient. Also runs fine on 27 cells at 7:1. Seven cells is just the max recommended for DIRECT drive, as the Kv is 2875, but it's much better on more cells geared.
Old Oct 10, 2001, 11:17 AM
cwatters is offline
Find More Posts by cwatters
Somewhere in England
Joined Apr 2001
Originally posted by NipponDave
snip
They really should be low ESR types as a previous poster
mentioned. Low ESR caps look identical to normal capacitors so
the only way to tell is by checking the manufacturers specs.
Chances are that normal caps will get hot and won't last long.
Colin
cwatters is offline Find More Posts by cwatters
Old Oct 10, 2001, 11:19 AM
cwatters is offline
Joined Apr 2001
No.
Two 25V caps in parallel have a working voltage of 25V not 50V.
You might get away with two caps in series but then the capacitance is halved.
Colin
Old Oct 10, 2001, 01:46 PM
Copenhagen, Denmark
Joined Mar 2001
Definately go with the 67V. But be prepared that if it isn't a low ESR type cap, it just may die at some time.
I have just received my Jeti controller (for my first brushless ) and it doesn't seem like it is a low ESR type.
Oh, geared. That explains it
Old Oct 11, 2001, 06:20 AM
geoff.sim is offline
Find More Posts by geoff.sim
geoff.sim's Avatar
Northamptonshire, UK
Joined Oct 2000
IMHO, 63V would be fine.
geoff.sim is offline Find More Posts by geoff.sim
Old Oct 11, 2001, 07:00 PM
RMFISH is offline
Find More Posts by RMFISH
Surrey, BC Canada
Joined Apr 2000
Why dont you get in touch with Jety and ask them, they did after all design the contoller, or probably know who did. You never know, they might be able to give you some good information about their product. They might be able to tell you why the blocking capacitor failed in your aplication. You never know, they might even be able to tell you how to get it fixed so that it will work as it should, they may even tell you what not to do so that it does not blow again. Give it a try, it might just be the rite thing to do.
Robert.
RMFISH is offline Find More Posts by RMFISH
Old Oct 11, 2001, 11:34 PM
bklein is offline
Find More Posts by bklein
Trabuco Canyon, CA
Joined Mar 2001
TVSD
You could try putting a TVSD across the motor... A TVSD is a transient voltage suppression diode - much like a high current zener. Digikey sells them. Pick a voltage above your battery voltage.
The capacitor should be low ESR, but at the same time be twice the expected working voltage at a minimum. Even given this, the capacitor could fail as this one, if the voltage across it was inadvertantly reversed - even momentarily. A higher ESR cap will not fail sooner than a low ESR cap. In fact I'd expect the opposite. With a high ESR cap your ESC could fail. The lower the ESR the more current the cap will be passing. Shock due to a crash could be a factor too. Tantalum and other caps will emit high voltage spikes with shock events - maybe enough to cause failure(?)
bklein is offline Find More Posts by bklein
Old Oct 12, 2001, 02:34 AM
Copenhagen, Denmark
Joined Mar 2001
Re: TVSD
I wouldn't do that with a brushless motor.
If it has to be done, it will take 6 diodes in order to make it work properly. And I don't see the need for them. Brushless motors doesn't make sparks and big transient voltages in the first place.
Old Oct 12, 2001, 07:27 AM
Copenhagen, Denmark
Joined Mar 2001
After a bit of thinking, I realised that 3 diodes are enough if they are coupled as a star, with the center joint left "floating".
Old Oct 12, 2001, 08:44 PM
bklein is offline
Trabuco Canyon, CA
Joined Mar 2001
Oops I didn't catch the fact that it was a brushless motor. Regardless, a 470uf cap will not be placed across it in some way - it will be on VCC for the ESC. Definitely there can be overvoltages here with a brushless motor. Say you're running full bore and crash. The back EMF has to go somewhere and it will be the ESC and its bypass cap. This cap could be damaged it wouldn't be apparent until some future point in time when it decides to short. I work for a disk drive company and we use a TVSD on each drive to protect against overvoltage from the motor or crappy power supply... Truthfully though, I'd just put another cap in like the one you had unless the manufacturer advises otherwise. Be advised that the cap could be very critical in the design. If the ESR is not right the motor may not start because the BEMF on the cap isn't large enough to determine motor speed. The circuit determines this by the ripple frequency across the cap.
Old Oct 13, 2001, 06:05 AM
NipponDave's Avatar
American in Japan
Joined Mar 2001
Thanks for all the good responses. I have replaced the blown cap with a 470/25V, just to see if the rest of the ESC survived. It seems fine, but we've only tested it at 7 cells. We'll repeat the 16-cell, part-throttle torture test again soon and see what happens. If it blows again, we might conclude that 25V caps aren't sufficient. If it runs OK, then we'll suspect that the original cap was weak.
If the 25V does blow again, we'll install the 63V cap and see how the ESC likes it. Further reports to follow...
Thanks again for all the illumination.
David
Old Oct 13, 2001, 09:27 PM
rlt55 is offline
Find More Posts by rlt55
Senior Moment
rlt55's Avatar
Woburn, MA, USA
Joined Jul 2001
When I design a DC circuit, I always use capacitors that are rated at about twice the voltage I'm using. If it's a 5V power supply, I use a 10V cap.
If I was building a 24VDC supply, I sure wouldn't use 25V caps.
I've seen too many of them pop.. To be safe, use at least a 25% safety margin.
Rich<>
rlt55 is offline Find More Posts by rlt55
Which Velcro part do you put on your battery? rcmann Parkflyers 13 Oct 17, 2005 05:01 PM
Put a search engine on your RCGroups site Capt. Electron Webhosting 6 Oct 31, 2003 06:05 PM
Put a foot on your step? jrsnow Waterplanes 2 Sep 27, 2003 10:24 PM
Where Do You Put the C50 Switch on Your Kwik-E kelvin Sport Planes 11 Aug 03, 2002 08:09 AM
Don't forget to put GWS Micro Retract Landing Gear on your planes GWS4CEO Parkflyers 20 Dec 12, 2001 12:48 PM
