Old Nov 30, 2010, 11:50 PM
syncronized is offline
Find More Posts by syncronized
syncronized's Avatar
Canada EH?!?
Joined Sep 2007
Fiberglass reinforcement help
Hey guys,
I've been looking for the last 2 hours for an easy to follow tutorial on OSE, RRR, RCG, RCU....
And I can't find one!! LOL And yes I've tried Google, but corvettes and real boats keeps coming up in the search engine hahhaha
Can someone point me in the right direction in regards to laying fiberglass cloth to help me reinforce my BJ26 hull?
Thanks in advance!
syncronized is offline Find More Posts by syncronized
Old Dec 03, 2010, 02:02 AM
nick30head is offline
Find More Posts by nick30head
nick 30
nick30head's Avatar
Joined May 2009
hey sync
i have some experience with FG, i start with the side's, cut all piece's you need (side, bottom and top) dab some resin on the hull side's first, place on the FG and then add some more resin, then lay the bottom and add more resin then do the same with the top, this way all the resin soaks into the FG and locks it altogether, you could add a 2nd layer if needed and do it while its wet
the key is to have all the FG cut 1st and lay some resin on the surface for the FG to hold (you could scratch the surface if you wish for a better key)
nick30head is offline Find More Posts by nick30head
Old Dec 03, 2010, 02:17 AM
CornelP is online now
Find More Posts by CornelP
CornelP's Avatar
Bucharest, RO
Joined May 2009
One more trick in the 3M spray adhesive. I spray it on the surface, lay the fiber, following all the curves without problems and then apply the resin. The adhesive will melt in the resin, so no problems here.
CornelP is online now Find More Posts by CornelP
Old Dec 03, 2010, 09:09 AM
Canada EH?!?
Joined Sep 2007
Thanks guys! Ok so in order....
1. scratch up hull
2. cut FG strips to appropriate length
3. apply resin/adhesive spray to hull
4. lay FG strips on sides/bottom/top
5. apply more resin
Do the FG strips have to overlap? Do you apply the resin with just a tiny paint brush? I think I saw a thread where someone used an old Credit Card.
Should the hull be done all in one shot? Or should I do it in sections?
Is there specific areas that need to be reinforced...or should I just try and cover as much area as possible? Not sure how I'm going to get into the sponsons! LOL
Also, can I just use epoxy? I've got some 12min epoxy lying around.
Sorry for all the questions...
Old Dec 03, 2010, 11:00 AM
CornelP's Avatar
Bucharest, RO
Joined May 2009
The 12min is categorized as adhesive, so it will not be very good for your application. Look for normal epoxy or poly resin, used for laminating. Usually the cure time for the epoxy is 12-24h and 1-2h for the poly, depending on the amount of hardener.
Main areas to reinforce: central tub, transom (including transom to hull edge) and maybe the sponsons. I would do the last steps (if there are any) and forget about the rest of it...
Old Dec 03, 2010, 01:12 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You definitely want to squeegee the excess resin away, it does nothing but add weight and makes it look sloppy.
Wax paper is your friend if you need to weight it down as well.
wparsons is offline Find More Posts by wparsons
Old Dec 03, 2010, 04:45 PM
cyberhoops is online now
Find More Posts by cyberhoops
cyberhoops's Avatar
Seattle
Joined Feb 2006
I put my fiberglass on with finishing epoxy, which has a 1 hour working time.
cyberhoops is online now Find More Posts by cyberhoops
Help! L-39 Albatros Fiberglass 70mm NO Manual Help 1satnaam Electric Ducted Fan Jet Talk 4 Nov 18, 2010 05:32 AM
Discussion Reinforcement Fiberglass Curtis Suter Hand Launch 6 Dec 28, 2007 10:03 PM
Mini-HowTo My First Fiberglass Job - Destiny Fuse Reinforcement infopimp Composites Fabrication 15 Jan 30, 2006 04:33 AM
Tigermoth wing reinforcement help doug_or Parkflyers 8 Apr 30, 2002 04:02 PM
