Old Jun 15, 2001, 06:50 PM
jschrader's Avatar
Munich area, Germany
Joined Jan 2000
Hi Haldor,
yesterday I tried a special Fun version (400-26) in my Adrenalin. 7 cells 700 AR - 5x5x4,3 - 20A - rpm not measured yet.
To slow for me
In such a small plane you get a lot of wing load with this equipment. Handling (esp. landings) are quite ok but not as convenient as with a model with more wing area.
If you don't intend to race you may look for something that is more F5Dish rather then S400 and you'll get a kick ass baby hotliner with this one
jschrader is offline Find More Posts by jschrader
Old Jun 15, 2001, 08:11 PM
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Thanks for the help. Looked up Jurgen Heiligs posts and he seem to be favouring the CAM5x4,3 on 8cells (in a twin BTW) Amp draw around 20.
jschrader - yes you're quite right. The current crop of s400 pylon ships are a little smallish for the heavier FUN400 motor/cells although manageable. I am considering rolling my own ship just a little larger and more wingarea than the small ones.
I like the lines of the F5D ships tho. Maybe....
Do you have some time left over so I could get some?
So the -26 wasnt fast enough for ya? Just how fast is that? Mike think the -36 on 7cells and 4,75x4,75 should haul a** Mine is tied up in my F18 EDF however so it will be the -28 who will be a propdriver.
Happy flying!
Haldor is offline Find More Posts by Haldor
Old Jun 16, 2001, 12:11 AM
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Kontronik FUN400-28 setup
Hi there.
I have this motor and currently a Graupner CAM5x5 and 5x4,3 prop. (Grp. 30mm spinner also) The Kv=2800 BTW as the name implies.
Intent to use 7-8*700AR and CP1300's. No racing, just4fun.
Anyone tried this motor in a pylon ship? I would really appreciate some numbers/specs if any know of them. (I have expired my 30day MotoCalc trial and havent shipped any check yet )
Old Jun 16, 2001, 12:25 AM
Senior Member
Oxford(ish), England
Joined Feb 2001
Look for some of Jurgen Heilig's posts. his Twinjet uses these, and he's very,very technically able and knowledgable and helpfull as they come.
gdb1973 is offline Find More Posts by gdb1973
Old Jun 17, 2001, 01:18 PM
Gothenburg, Sweden
Joined Jan 2001
Originally posted by jschrader:
Hi Haldor,
To slow for me
How is your 7 cell 700AR pack configured??
/Erik
Erik Johansson is offline Find More Posts by Erik Johansson
Old Jun 17, 2001, 10:31 PM
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Bench tested the motor today - old 8x700AR pack and Graupner CAM 5x5prop => 24A@8V and ~200W peak, no rpm readings. Now I need to find a suitable pylon model for some inflight testing...
Total weight of the motor/prop/controller is 350gram (12,3oz) but you could loose some by shortening the leads - mine are stock length at this time.
Old Jun 18, 2001, 03:44 AM
jschrader's Avatar
Joined Jan 2000
1 stick with 3 and 2 sticks with 2 build a "pyramid". The yeti fits exactly (means: absolutely no room left) besides the packe in the fuselage.
[This message has been edited by jschrader (edited 06-18-2001).]
Old Jun 18, 2001, 11:14 AM
Gothenburg, Sweden
Joined Jan 2001
Do you have wing mounted aileron servos?? It would be hard to fit the single aileron servo in the fuse with that pack.
/Erik
Old Jun 18, 2001, 11:07 PM
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Herrn Scrader :
Do you know of a suitable set of parameters for a hotliner around this combo? I dont have much of a feel about pylon models (what size/span/wingarea..) myself as I have mostly done EDF's.
Danke,
Haldor
Old Jun 19, 2001, 03:28 AM
jschrader's Avatar
Joined Jan 2000
@Erik
I've got a single servo in the fuse. (Should be an SES 100 or alike) It's "lying" on a 5mm balsablock. There's enough room left to fit the 7th cell beneath.
But since there's everything very tight any setup should be configured individual.
@Haldor
You may use a hotliner around 1,50 wingspan with the geared motor. Please ask Mike for suitable models and useful gear ratio. He's the specialist on this issue.
Besides: any F5D ship is a suitable hotliner as well if you can deal with 1m wingspan. With the 400-28 and let's say 700 AR you can built a real good glider which is even very easy to land.
Old Jun 19, 2001, 03:57 AM
Kyri's Avatar
England
Joined May 2000
I have used my Teufelchen F5D as a hotliner once or twice, with a speed 480 3.45:1 and a 10x8, on 7 and 8 700AR's. It was great, I could have done with some more prop though, the wing got in the way of anything bigger than 10inch diameter.
So with a geared 400-28 it would be even lighter and more powerful...
I now use the plane as a pylon plane, since it doesn't thermal very well!
Kyri is offline Find More Posts by Kyri
Old Jun 19, 2001, 07:23 AM
Gothenburg, Sweden
Joined Jan 2001
@Erik
I still donīt fully understand how the pack is built, and how it sits in the fuse.
Gonna do the final work on my Adrenalin today.
/Erik
Old Jun 19, 2001, 11:32 AM
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Jurgen - thanks. I am not thinking about a geared one yet so the smaller F5D ships might be more of what I'd like to have. Perhaps a 90cm version of the Graupner Munga or something like that. Since I have the motor and a square 8x700pack (4sticks of 2 end-end) I'd like to consentrate on a design around that. DD and CAM5x5 looks very promising regarding speed
Thanks again for all the help - any more ideas ...dont be shy
FS - Kontronik Fun400-28 motor Haldor Aircraft - Electric - Airplanes (FS/W) 8 Nov 05, 2003 12:57 AM
Shulze Future 45Ho setup VS. Kontronik, The first time setup of Schulze? Inverted-3D Electric Heli Talk 1 Feb 01, 2002 05:04 PM
What happened? -- need help with Kontronik FUN400-23 Neil Morse Electric Plane Talk 10 Oct 28, 2001 10:38 AM
Kontronik FUN400-28 and Minifan480 Thierry F Electric Ducted Fan Jet Talk 2 Sep 06, 2001 01:31 PM
Kontronik "smile" governor setup jaggies Electric Heli Talk 28 Jul 15, 2001 05:07 AM
