Old Sep 26, 2005, 08:18 AM
3810 is online now
Find More Posts by 3810
3810's Avatar
Australia, VIC, Delacombe
Joined Nov 2003
Bubble Dancer Spar Material
Could someone please advise me on a problem.
I want to have ago at building a BD,but sending the 48'' spar material to Australia will cost the earth(only42''max via airmail).
The kind staff at CST said they would help by cutting the spars to make postage cheaper,so my question is,the center panel is about 36''so do I ask them to take a couple of inches from each end of the 48'' strips? and also same question about the mid panel,where to cut the 48'' stock?
Any help.
3810
3810 is online now Find More Posts by 3810
Old Sep 26, 2005, 09:15 AM
Ollie is offline
Find More Posts by Ollie
Punta Gorda, FL
Joined Apr 2002
The BD plans are complete. Ask CST to cut the 48" stock one 6" x 0.0014" thin end and then the opposite 6" x 0.0014" thin end. You use the proper cut off 6" pieces for the bridge assembly.
You can confirm my advise and ask your question at:
http://groups.yahoo.com/group/Allegr...guid=108420033
Ollie is offline Find More Posts by Ollie
Old Sep 26, 2005, 12:06 PM
rdwoebke is offline
Find More Posts by rdwoebke
I'm all about that bass
rdwoebke's Avatar
United States, IN, Indianapolis
Joined Feb 2004
3810,
The Bubble Dancer build is quite rewarding. Congrats for taking on the project.
You cut the ends off the center section spar, as you thought. The mids you cut in two.
A good picture of how this all works out is here:
http://www.charlesriverrc.org/articl...Fs/spar_V2.pdf
You might want to have them leave the tips a little long and then you don't need to have a separate carry through spar.
rdwoebke is offline Find More Posts by rdwoebke
Old Sep 27, 2005, 07:28 AM
3810 is online now
3810's Avatar
Joined Nov 2003
Thanks for your help GUYS
3810
Old Sep 30, 2005, 04:00 AM
LWThompson is offline
Find More Posts by LWThompson
Senior Member
LWThompson's Avatar
Nashville, TN USA
Joined Jun 2002
If the spar material is 48" carbon fiber laminate, it can be rolled and inserted in a tube for shippment like a set of blueprints. I bought some that is 48x24. If rolled a couple of turns, it would fit into a 24" tube for shipment or maybe a triangular Federal Express box.
LWThompson is offline Find More Posts by LWThompson
Old Sep 30, 2005, 05:06 AM
3810 is online now
3810's Avatar
Joined Nov 2003
Hi LWThompspn,
From what I understand the laminate for the center panel is to stiff to roll up,but thanks anyway.
3810
Old Sep 30, 2005, 08:00 AM
rdwoebke is offline
rdwoebke's Avatar
Joined Feb 2004
The outer spar material can be rolled (and I expect it will come that way, at least mine did), but the center and mids spar, nobody's rolling that. Unless you want to end up with some carbon splinters and a whole bunch of little spars.
Ryan
Bubble Dancer Spar Repair ASK Thermal 7 Jan 05, 2005 11:36 PM
Aileron Bubble Dancer? Yochim Thermal 1 Feb 28, 2003 05:09 PM
Bubble Dancer, sort of, for 7-cell LMR pocket rocket Electric Sailplanes 3 Jan 22, 2003 05:37 PM
Rave Any thoughts on Mark Drela's Allegro/Aegea/Bubble Dancer...? Raymund Reyes Thermal 3 Jan 05, 2003 02:38 AM
Bubble Dancer reviews/info cold boy Thermal 2 Dec 11, 2002 08:04 AM
