Old Aug 12, 2014, 12:16 PM
Petjan is offline
Find More Posts by Petjan
Joined Aug 2014
Hi all,
Today I finished the Spitfire. I got him a great pleasure. Here is a link to my site: http://spitfire.vyjimecny.cz/. They are in Czech. I attach a photo.
Petjan is offline Find More Posts by Petjan
Old Aug 12, 2014, 02:14 PM
capteasy is offline
Find More Posts by capteasy
capteasy's Avatar
USA, Texas Hill Country
Joined May 2008
Congratulations Petjan....you should have a great time with it.
ce
capteasy is offline Find More Posts by capteasy
Old Sep 23, 2014, 04:43 PM
YarSmythe is offline
Find More Posts by YarSmythe
Addicted to RC
YarSmythe's Avatar
USA, TX, Houston
Joined Nov 2003
I'm at my wits end with the stock retracts. I've tried multiple servos, different pushrods & fittings, etc. They will not lock open/closed properly. Even tried two servos as one pilot here used.
Is there a (close) drop-in replacement servo retract I can use for this plane? Has anyone used the Durafly Spitfire retracts?
Thanks, -Lee
YarSmythe is offline Find More Posts by YarSmythe
Latest blog entry: How does YOUR antenna hang??
Old Sep 23, 2014, 05:00 PM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
Change Sun e-retracts from many sources are what I used.. 512 size IIRC - up to 2.5kg models on a 3mm diameter strut. Mechanical retracts are a nightmare that I don't ever want to revisit. E-tracts all the way, baby.
JimNM is offline Find More Posts by JimNM
Old Sep 23, 2014, 11:39 PM
capteasy is offline
capteasy's Avatar
Joined May 2008
The early Haikong Spit didn't have retracts but I modded it with some Hobby King HKD-312 e-tracts and they worked fine.
http://www.hobbyking.com/hobbyking/s...stem_1pc_.html
Good luck
Old Sep 27, 2014, 07:03 AM
Addicted to RC
YarSmythe's Avatar
USA, TX, Houston
Joined Nov 2003
Ready for maiden
I ordered the electric gear for the Spitfire but it'll be a while before it arrives. Until then, I locked the stock gear down in place and took the plane out for its maiden.
Flight was squirrely. She was pitching up hard but not acting tail heavy. I put half down trim to level her off. She had no pitch movement with or without throttle (usually a sign you need down-thrust). The plane's CG is right on at the 90mm mark (per instructions). I had a similar problem with a plane that I thought was tail heavy but turned out to be the horizontal stab had too much 'up' built into the construction. In this case, everything looks level so I have to guess she's tail heavy. Judging how easy this plane tips over with the gear down, I'm hesitant to add too much or she'll keep nosing over on take-offs and landings.
She flew well once the trim was set. Suprised how gentle she was at low throttle. Landing was long 'cause I couldn't get her to come down.
A few more tweaks, a spinner, electric gear, air holes and then she'll be complete.
-Lee
(anyone catch the build mistake in the photo? )
Old Sep 29, 2014, 10:28 AM
Addicted to RC
YarSmythe's Avatar
USA, TX, Houston
Joined Nov 2003
Flew a second/third flight on the Spitfire and it still needed down trim. Read back through this thread and found many of you pushing the CG forward to 75mm. Guess I'll add another ounce (or two) to get it there. Sadly, by doing this, I'll have to bend this gear way forward to keep it from nosing over. When the electric gear comes in, I'll be cutting up the wing to position the gear further back when retracted so it'll shoot forward when down.
Hopefully in a few more flights, I'll have her tweaked just right.
-Lee
Discussion what do ya think about this video? furyflyer2 Foamies (Kits) 2 May 05, 2006 05:19 PM
Discussion What do ya think, JR 10x heli or JR 9303? Bunyan Radios 2 Apr 24, 2006 04:20 PM
Discussion brushless pcw, going lipo 1stimer, what do ya think? snowcrash75 Flying Wings 1 Dec 31, 2005 02:36 AM
What do ya think about that? dad57c Engines 2 Dec 15, 2005 09:15 AM
Mini-Falcon,..What do ya think?,. wackyd Slope 19 Jan 29, 2005 09:41 PM
