Old Nov 27, 2014, 01:28 PM
4stripes is online now
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
TAFT 11 blade 90mm EDF
Since there was no dedicated thread here we go....
I recently ordered and received the TAFT 11 blade 90mm rotor and 5mm adapter from RCCastle. I did not order the shroud as I'm hoping to fit into existing shrouds that I've collected over the years and if it warrants, exchange with other fans if performance is better.
Has anyone been testing the TAFT 11 blade fans to see what power levels it can handle? Any testing data would be useful. Any fit data for various shrouds would also be welcome.
Just looking at the fan, I think is is well moulded (much better than a 12blade lander unit I bought recently). The blade angles look reasonable and are much thinner than the Changesun 12 blade. The blades do flex a little when pressed which concerns me but perhaps someone has already put some power through one can chime in on strength.
I will post my findings when I get a chance.
Thanks for any input.
Eric
4stripes is online now Find More Posts by 4stripes
Old Nov 28, 2014, 07:47 AM
Dave Grife is online now
Find More Posts by Dave Grife
Dave Grife's Avatar
Coldwater, Mi. USA
Joined Jul 2000
Larger diameter- possible issue
.....fwiw
Dave Grife is online now Find More Posts by Dave Grife
Old Nov 28, 2014, 11:48 AM
pajlotmato is offline
Find More Posts by pajlotmato
Slovakia, Veľký Krtíš
Joined Dec 2006
This is really great and cheap edf, I rebuild it little bit and it has really great turbine sound, quiet good performance for such a cheap outrunner motor and on 6s I am going to push my scratchbuild delta jet on it...pictures here: http://www.rcportal.sk/zachranene-dmychadlo-g2362
pajlotmato is offline Find More Posts by pajlotmato
Old Nov 28, 2014, 05:04 PM
4stripes's Avatar
Joined Jan 2009
TAFT 90mm 11 blade EDF fan measurements.
The TAFT 90mm 11 blade fan is 91.5mm in diameter and has a collet adapter that is 10mm in diameter made for 5mm motor shafts. The rotor diameter is about 3 to 4.5mm larger than the Haoye 7 blade and Changesun 12 blade 90mm fans (measured at 87 to 88.5mm). The TAFT also is a tall fan meaning a deep intake portion is needed in the shroud. I'm planning to test in the Changesun shroud which is plenty deep but the blades have to be shortened to fit. The typical shrouds for Flyfly Haoye 90mm fans are not deep enough to cover the TAFT blades and part of the fan will stick out (not suitable). I do not have the actual TAFT shroud for comparison but it must be a slightly larger outside diameter than most 90mm fans.
After shortening the blades to fit my CS shroud, I will post my findings.
Corrected measurement of CS diameter (it is 87mm)
Old Nov 28, 2014, 06:29 PM
4stripes's Avatar
Joined Jan 2009
TAFT 11 blade fan with Changesun 1600kv outrunner motor data
Running the shortened TAFT 11 blade fan in the Changesun shroud with the Changesun 1600kv outrunner gives identical figures to the Changesun impeller.
I added a intake lip to the shroud for bench tests to show figures closer to installed.
Using Gens Ace 5500mah 25C 6S batteries
2000watts 89amps peak
1750watts 82amps settled
What I don't know is the measured thrust. With my CS setups with similar motors it is about 2.2kg installed thrust. I will have to install the TAFT to see what the verdict is. I'm thinking that it may have an edge over the CS 12 blade in thrust but that information will have to wait till my F86 is finished. I will post the results then.
Old Nov 28, 2014, 06:42 PM
4stripes's Avatar
Joined Jan 2009
One thing about the TAFT collet adapter is that it is difficult to tighten the way it comes out of the box. I will cut a slot in the end of the adapter so that a large flat blade screwdriver can be used to help tighten the nut. I also glued a sandpaper washer to the back stop of the adapter to help prevent the fan from twisting out of position.
Old Nov 28, 2014, 07:56 PM
4stripes's Avatar
Joined Jan 2009
The TAFT Viper comes with this fan and a 1450kv outrunner but I think the Changesun 1600kv motor from X-flight would provide better performance and be reliable as my motor temperatures never exceeded 110F.
Old Nov 29, 2014, 10:55 AM
4stripes's Avatar
Joined Jan 2009
After cutting the adapter end with a slot, the it was much easier to tighten the collett adapter securely. The fan was clocked as was the spinner for dynamic balance. Some additional weight was added inside the spinner with CA. It runs well and the total weight is 352g with the CS shroud cut down to the length I wanted.
Old Nov 29, 2014, 10:16 PM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
A thrust/watt test I did some time ago with a Dr Mad Max 1600kv inrunner motor...
Taft Viper 90mm Fan with Dr Mad Thrust 1620kv motor Thrust Test (0 min 0 sec)
Taft Viper Jet 90mm 11-Blade Fan
Hobby King Dr Mad Thrust 1620kv 2400watt 90mm EDF Inrunner 6s version (36mm)
Dr Mad Thrust 36mm Heat Sink.
Turnigy Nanotech 6S 5000mah 65-130c battery
Thrust on a fully charged battery is not Captured on Video.
It's 3.2Kg for around 2500Watts (110Amps@22.6V).
Thrust starts at around 3Kg for around 2200watts (100amps@22V).
Slowly drops to 2.75Kg for 2037Watts (97A@21V).
anlucas is offline Find More Posts by anlucas
Old Nov 29, 2014, 10:20 PM
4stripes's Avatar
Joined Jan 2009
Thanks Anlucas
I haven't built a test stand that measures thrust as I just measure it once installed in the plane. Pretty crude, but give me an idea of what I can expect in the air (based on my other measurements).
Cheers Eric
Not sure the 1600kv rating for the Chanesun motor is accurate, but the power levels should be fine for my application.
Old Dec 02, 2014, 11:59 AM
moparren is offline
Find More Posts by moparren
I am what I teach
Tucson AZ
Joined Mar 2007
I'm running a Taft in my low power Jetster and am happy with it.
http://www.rcgroups.com/forums/showthread.php?t=2226971
On 4 s I get around 800 watts and flys a 3 - 4 pound airplane quite nicely.
I did spend some quality time with my balancer before install but for the price of the fan I'm not complaining. I'll be picking up a pair for my Nitroplanes HondaJet.
moparren is offline Find More Posts by moparren
Old Jan 02, 2015, 08:06 AM
Alpha10 is online now
Find More Posts by Alpha10
Alpha10's Avatar
United States, IL, Chicago
Joined Aug 2011
I love this fan for sound and performance on a budget. I run 1650kv CP inrunners with it and pull around 88amps, but I'm looking for a great 8s inrunner to try with it...
Any Taft 11b 8s numbers out there?
Alpha10 is online now Find More Posts by Alpha10
Old Jan 02, 2015, 09:23 AM
natiho2 is online now
Find More Posts by natiho2
Joined Apr 2012
Interesting thread,
Thank you share with us
I want to ask
When you assemble the fan
Where do you put Loctite
And what Loctite do you recommend to use?
natiho2 is online now Find More Posts by natiho2
Old Jan 02, 2015, 10:41 AM
4stripes's Avatar
Joined Jan 2009
I use medium strength on the motor mount screws and the spinner screw.
Old Jan 02, 2015, 01:13 PM
Joined Apr 2012
thanks 4stripes
Sold Taft 11 Blade 90mm 8s setup swps Aircraft - Electric - Jets (FS/W) 1 Oct 17, 2014 03:06 PM
Sold 90mm 11 blade EDF fan, motor, ESC from Taft Viper raptor30se Aircraft - Electric - Jets (FS/W) 1 Aug 27, 2014 08:49 PM
For Sale Taft 11 Blade 90mm 8s Setup with HV Esc and BEC swps Aircraft - Electric - Jets (FS/W) 0 Feb 07, 2014 11:07 AM
Sold 90mm taft 11 blade 6S Fan Combo leemkl06 Aircraft - Electric - Jets (FS/W) 0 Jan 20, 2014 07:56 AM
Sold 90mm taft 11 blade 6 - 8 s fan unit dr.edf Aircraft - Electric - Jets (FS/W) 2 Jan 04, 2014 12:29 AM
