Old Apr 13, 2004, 07:50 AM
4 Scale is offline
Find More Posts by 4 Scale
Trampling out the vintage
Joined Feb 2002
Modifications to Alfa models?
I am taking a break between scratch builts and recently added the Alfa Corsair to The Fleet. This model is stunning - looks and flys great. If I did the best job I could with balsa and fiberglass, it would take 100 hours and still not look as good or be as light as an Alfa.
I tested the top of the wing when building it and noticed the existing paint comes off easily with acetone without marring the white foam underneath. So you could easily repaint these.
I have about 25 flights on mine and find I am missing the rudder for some aerobatics (stock model is T/E/A). While I know you can add rudder control fairly easily to the Flying Styro models, I'm not sure on Alfa.
So - has anyone added a rudder or re-painted an Alfa?
4 Scale is offline Find More Posts by 4 Scale
Old Apr 13, 2004, 08:37 AM
Pat Daily is offline
Find More Posts by Pat Daily
Pat Daily's Avatar
United States, VA, Chesterfield
Joined Mar 2001
Greg
You are right about the Alpha F4U -- it is a superb and very well designed plane and the scaleness is really good. I am just starting my second F4U--lost the first one when she augered in--still not sure how I did it. But I was also wondering about rudder control--I noted when I pitched No. 1 theat the rudder is made of two pieces and is hollow. I would think it could be pretty simple to put a balsa trailing edge for the fin and leading edge for the rudder and it should work. Still not sure I want to do that just yet. I also would like to try some other paint schemes--the dark blue is hard on old eyes at a distance.
Pat Daily
Pat Daily is offline Find More Posts by Pat Daily
Old Apr 13, 2004, 09:10 AM
4 Scale is offline
Joined Feb 2002
Pat we are thinking exactly alike. I’ve been thinking of painting the underside light blue to improve visual orientation. On the rudder thanks for confirming what my “wiggle” test showed (that it is hollow foam). I think the solution is to carefully cut out the moving surface part of the rudder, glue on a balsa edge to the exposed surface, then finish with touch up paint.
Old Apr 13, 2004, 08:45 PM
CUBANO8 is offline
Find More Posts by CUBANO8
Joined Oct 2003
Yes, I have. I didn't use acetone, but rubbing alcohol, to remove the paint.
CUBANO8 is offline Find More Posts by CUBANO8
Old Apr 13, 2004, 10:20 PM
4 Scale is offline
Joined Feb 2002
Nice job cuban8. I crashed my Alfa today (pilot error, again) and will be getting a new one. No question but the next one will get some different paint and a rudder.
Alfa Models P47, any advice? Zeroaltitude Parkflyers 23 Apr 30, 2003 06:45 PM
Alfa Models P-47 Thunderbolt "Tarheel Hal" Maiden Flight thunder1 Parkflyers 8 Apr 07, 2003 10:17 AM
P-51D/ HL-Alfa Models NoFlaps Fuel Plane Talk 5 Feb 14, 2003 09:55 AM
P-47 from Hobby Lobby (Alfa models) jah Parkflyers 8 Feb 02, 2003 11:20 AM
Modifications to a World Models Extra 300 .30 size Speedfreak Sport Planes 1 Mar 02, 2002 06:35 AM
