Old Nov 08, 2013, 01:30 AM
manuel v is offline
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
Rewind one PA Thrust 20.
I have a motor to rewind,
This motor is used with an APC 11x4.7 SF and 3s lipo.
I find heavy load, because the motor weighs 71 grams and has a kv of 1030 according to the manufacturer.
Either way the motor is burned.
Manuel V.
manuel v is offline Find More Posts by manuel v
Old Nov 08, 2013, 01:37 AM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
Disassembly of the motor is more difficult than normal.
The motor has a pin between the stator and the base, with some sort of bonding glue.
Removing it was somewhat laborious.
After having a couple of clips that also must be removed.
Now if the engine is mounted on a base and is heated with air gun.
Once hot, the stator is covered with a suede and clip is removed.
Be very careful because the stator has a very thin laminations.
Old Nov 08, 2013, 01:41 AM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
Remove the wire was a headache.
The wire is coated with epoxy and need to remove it into many pieces.
I lingered forever.
Old Nov 08, 2013, 01:46 AM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
The motor has a Kv of 1030.
But few Turns?
To find out, rewind one test with 10 turns of wire no. 26 awg.
this was the result.
18,300rpm. , 10.94V, 2.73A. Kv 1672.
Drive calc6.
16 Tuns DLRK Delta= 1045 Kv.
33 Tuns Half parallel Delta= 1013 Kv.
Old Nov 08, 2013, 01:50 AM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
I decided to rewind in Half Parallel with 33 turns of 25AWG
But if I can put 34 turns, so I will.
A slightly lower Kv, will allow the motor to use the propeller with less risk of burning.
Old Nov 08, 2013, 01:51 AM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
The motor now has 34 turns 25AWG,
Half parallel wind.
Manuel V.
Old Nov 08, 2013, 01:52 AM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
No load.
11,100 rpm, 11.3 V, 1.04 A, 982 Kv.
Drive calc= 978 rpm/V, Rd= 112.5 mOhm., Kt= .966 Ncm/A. Max Eta =80.7% to 96 watts.
APC SF 9x4.7, 8,800 RPM, 10.63 V, 13.69A.
GWS 10x6, 8,700 RPM, 11V, 18.35A.
APC e 10x7, 8,200 rpm, 11.15V, 22.70A.
APC e 12x6, 7,400 rpm, 10.67V, 24.95A. 266 watts.
Manuel V.
Old Nov 08, 2013, 03:53 AM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi Manuel
Great
For information what are the diam x length of the stator ?
Louis
Fourdan is offline Find More Posts by Fourdan
Old Nov 08, 2013, 11:32 AM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
Fourdan.
30.5 x 7 mm stator.
Old Nov 09, 2013, 02:57 PM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
Drive calculator.
PA Thrust 20 vs PA Thrust 20 Rewind, Low Kv.
Old Nov 09, 2013, 05:34 PM
JoseLuis28 is offline
Find More Posts by JoseLuis28
JoseLuis28's Avatar
Colmenar Viejo - Madrid - Spain
Joined Jan 2009
Excelent job.
JoseLuis28 is offline Find More Posts by JoseLuis28
Old Nov 09, 2013, 06:33 PM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
Thank you Jose Luis.
This Motor is well above others in its category.
Manuel V.
Old Nov 14, 2013, 05:15 PM
jhilgart is offline
Find More Posts by jhilgart
United States, CA, Encinitas
Joined Aug 2006
Great Work! Thanks again for the rewind, excellent job detailing your work!
jhilgart is offline Find More Posts by jhilgart
Old Nov 14, 2013, 05:54 PM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
Jhilgart.
Thank you very much.
Today at 5 pm I'm sending the motor back.
Possibly it delivered on Monday.
Manuel V.
Old Nov 14, 2013, 09:09 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Nice work. You've turned a dog into something decent.
But imo it remains an Odd motor ..
Being more Case than working motor. Ring and stator is a % of it's overall size.
Designer must have been told that bigger is better :-)
Bare is offline Find More Posts by Bare
Sold PA Addiction + Thrust 20 motor + ESC + servos LPU $200 jv8 Aircraft - Electric - Airplanes (FS/W) 3 Sep 21, 2013 03:25 PM
Wanted PA THRUST 20 brushless Motor WANTED! jhilgart Aircraft - Electric - Airplanes (FS/W) 0 Sep 08, 2013 04:50 AM
Wanted THRUST 20 Brushless Motor PA jhilgart Aircraft - Electric - Power Systems (FS/W) 0 Sep 08, 2013 04:44 AM
Question Cross Mount for PA Thrust 20 motor Island Runner Power Systems 2 Jan 21, 2013 11:54 AM
Discussion help rewinding thrust 20 speedy_1 Electric Motor Design and Construction 15 Aug 04, 2010 07:32 PM
