Old Yesterday, 02:17 PM
4stripes is online now
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Sounds like the perfect candidate for a turbine conversion.
4stripes is online now Find More Posts by 4stripes
Old Yesterday, 02:38 PM
Tumbler is online now
Find More Posts by Tumbler
Tumbler's Avatar
New Jersey
Joined Feb 2003
So I ripped out the balsa below the fan and thrust still way down. So I don't get it. Something is wrong somewhere.
Tumbler is online now Find More Posts by Tumbler
Old Yesterday, 02:39 PM
Tumbler's Avatar
New Jersey
Joined Feb 2003
I designed it for turbine for the start then they were banned everywhere around me. I can't stand electric. I only do it because I have to now.
Old Yesterday, 02:48 PM
70 ragtop is offline
Find More Posts by 70 ragtop
United States, CT, Oxford
Joined Jan 2009
Bummer
Same thing around here, all grass....sucks
Actually found out yesterday I lost my dead end street flying site. Was right around the corner, between the house and work. They put Jersey barriers up blocking off the street, and put up no trespassing signs. Guess the jackaxxs were tearing it up with 4x4s, so everyone looses.
Now have to drive an hour to fly anything, and its only grass
70 ragtop is offline Find More Posts by 70 ragtop
Old Yesterday, 03:31 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
how much onlet area? try it with the main doors open?
corsair nut is offline Find More Posts by corsair nut
Old Yesterday, 03:32 PM
tehachapi, CA
Joined Jan 2006
sounds like your hurting for inlet area. how big is your tail pipe?
Old Yesterday, 03:39 PM
Tumbler's Avatar
New Jersey
Joined Feb 2003
I reset all the settings on the ESC(YEP programming can be a PITA) and got the 17 lbs back with all ducting out and hatches off. Best I can get with the hatches on is 13. With doors open it goes to 15 but can't fly it like that because the doors hang too low. 15 lbs is not enough for a 25lb plane anyway. 17 was marginal to begin with off a bumpy grass runway.
Tailpipe is 105mm. Not worth making another one because even a lb of thrust won't help me.
Old Yesterday, 03:49 PM
tehachapi, CA
Joined Jan 2006
how are you measuring?
Old Yesterday, 09:36 PM
Tumbler's Avatar
New Jersey
Joined Feb 2003
Plane on 15 degree decline to remove friction then metal rod hooked around nosegear to rear of plane hooked to fish scale. Get 17 lbs with open hatches. 13 with hatches.
Old Yesterday, 10:13 PM
tehachapi, CA
Joined Jan 2006
yikes..that puppy is starved. if you had hard pack youd be fine. i did a project that only had a cheater hole..weighed 25lbs and only had 5kw. it took off great from hard surface.
Old Yesterday, 10:17 PM
tehachapi, CA
Joined Jan 2006
this thing was a beast. you have way more power than this had. running a 12s turbax setup. and this was not a clean airframe like your 100 lol. grantedi wasnt on grass but the takeoff roll was short!
Old Yesterday, 10:18 PM
tehachapi, CA
Joined Jan 2006
would if you did a speed brake/blow in door for takeoff?
Old Today, 03:10 AM
Tumbler's Avatar
New Jersey
Joined Feb 2003
The inside of the fuse where the speed brake is all sealed off. Even with the doors open I don't get back to 17lbs so I don't think having the air brake open 1/2" will do all that much. Needs a huge cheater hole.
Sold Widgeon twin 80" span from rcm plans LPU rcshirt Aircraft - Electric - Airplanes (FS/W) 3 Jul 09, 2013 12:54 PM
Build Log Windfree from RCM Plans ulpilotrmh Electric Sailplanes 4 Mar 04, 2013 07:54 PM
Build Log PT-19 from RCM plans EdLokken Scale Kit/Scratch Built 14 Jan 05, 2013 05:55 PM
For Sale RCM Hot Hots kit + Plan $100 shipped. rcgreaves Aircraft - Fuel - Airplanes (FS/W) 4 Oct 23, 2006 02:22 PM
Gallery Depron F-18 parkflyer from the beautiful plans by Steve Schumate CzechSix Your Plane Photos 0 Nov 18, 2004 05:17 PM
