Old Mar 07, 2013, 08:20 PM
bill clark is offline
Find More Posts by bill clark
Half way there
bill clark's Avatar
USA, FL, Ocoee
Joined Sep 2008
Help!
Control system linkage weight
I am in the process of designing and machining a different type of linkage system for 6mm depron foamies and would also like to create a version for 4oz'ish 3mm F3P planes. I need a target weight for the F3P version and was hoping some of you guys could share what you have. Basically I need the total weight for these items.
-servo arms (3)
-pushrods
-horns
-pull-pull cable
-z-bends or whatever end fittings you use
-heatshrink
-glue
basically intead of arms the system will use pulleys. Also it woud be helpfull to know the maximum throw you would use on each surface. I would really appreciate some info. thanks
bill clark is offline Find More Posts by bill clark
Discussion Build help, .15 Wild Thing, control linkages ToddB Beginner Training Area (Aircraft-Electric) 1 Feb 17, 2013 01:40 PM
Wanted Phenolic Control Horns & Pull-Pull Linkages 51" Slick ognolman Aircraft - General - Miscellaneous (FS/W) 0 Feb 17, 2013 10:22 AM
For Sale HiTEC Optic 5 2.4 aircraft Control System Gary Kelley Aircraft - General - Radio Equipment (FS/W) 0 Jan 07, 2013 10:58 PM
Discussion Foresail/Jib Control System Advice Needed clayfeld Scale Sailboats 5 Jan 06, 2013 12:45 PM
Help! Control linkages for throttle control: not enough throw arukum17 Beginner Training Area (Fuel) 11 Dec 24, 2007 11:56 AM
