Old Feb 09, 2013, 11:03 AM
eak is online now
eak
Find More Posts by eak
eak
Joined Feb 2011
HK multiwii 328p ftdi/dsm controler going crazy
Ok I did a test flight today it worked the other day(untill one prop came lose and it crashed from 1meter in the air).
I aplied just enough throttle to make it start lift. Then it went totaly crazy on me applied random throttle and just started climbing dropping and climbing i was applying 0throttle on the radio I had random control over it in the air.
Then it suddenly crashed a few hundred meters away behind some houses in the sidewalk.
it was connected with hitec optima 7 reciver 5channels 1 for aux to switch acro/stable/althold BEC -> Reciver -> Board.
The SPC port was not used.
The flight controler now is scrap or i can perhaps de slder all the connectors and resolder leads straight to the board instead or buy new connectors.
The heli was set to plus configuration. magnetic feild set to where i live.
When connecting the board now to the computer all sensor output seems fine exept the barometer it keeps jumping upp and down I dont know if its supposed to be that way or not it jumps betwen 17-18
eak is online now Find More Posts by eak
Old Feb 09, 2013, 04:44 PM
eak is online now
eak
eak
Joined Feb 2011
I desoldered all the connectors and soldered the servo leads to the PCB. Conected it to my computer. Then found out that the power batery conector side of he reciver is dead. But that probably happened in the crash. Because the gyros semed to work while it was out of control. And the reciver was powering the board.
Old Feb 09, 2013, 05:52 PM
eak is online now
eak
eak
Joined Feb 2011
Found this clip
DJI F450 Flame Wheel aka LameWheel vibrations FAIL (0 min 52 sec)
Maby this is he problem my heli had when it was uncontrolable. But dount explain whuy 0 throttle did not work.
Old Feb 09, 2013, 07:44 PM
neobot is offline
Find More Posts by neobot
Joined Jun 2012
ask the person you bought the from for tips after all the maker should now everything about this board?
neobot is offline Find More Posts by neobot
Reply With Quote  (Disabled)
Old Feb 09, 2013, 08:46 PM
eak is online now
eak
eak
Joined Feb 2011
It's a HK board. Can you get in touch with an enginer from such a big hobby company? As i under strand it all their boards are copies from other open source boards? He most important thing for me is to under strand what went wrong. So i can eliminate it on the big hexacopter egen i put it together. I bought he whitespy controler board for that one. End this quad is for testning and not beräkning to manny expensive parts before its solid.
Old Feb 09, 2013, 08:51 PM
eak is online now
eak
eak
Joined Feb 2011
Sorry for the spelling my tablet keeps messing with me. It's set to swedish dictionary.
Discussion the HK/Holybro MultiWii 328P Flight Controller w/FTDI & DSM2 Port dutchcommando Multirotor Electronics 677 Apr 26, 2015 08:33 PM
Discussion Multiwii Mini Flight Controller w/FTDI Interface blackdiamond11 Multirotor Electronics 1 Apr 28, 2013 12:42 AM
Help! MultiWii 328P Flight Controller Setup. help!!!! Raul Dhillon Multirotor Electronics 27 Apr 27, 2013 05:44 AM
Sold MultiWii 328P w/FTDI & DSM2 Port FC and KK2.1 FC Mike Carrio Aircraft - Electric - Multirotor (FS/W) 2 Jan 30, 2013 10:05 PM
Discussion HK MultiWii SE V2.0 Flight Controller w/FTDI Sketch Judar Multirotor Electronics 7 Oct 15, 2012 12:56 PM
