Old Jan 05, 2014, 08:12 AM
OK FLyer is offline
Find More Posts by OK FLyer
Lost in the sky
Tulsa, OK
Joined Sep 2007
Thanks Ray.
Those are actually souvenir magnets on the fridge. I travel quite a bit for work and every time I go somewhere new I get my wife a magnet.
OK FLyer is offline Find More Posts by OK FLyer
Old Feb 09, 2014, 02:21 PM
OK FLyer is offline
Lost in the sky
Tulsa, OK
Joined Sep 2007
Finshed up
Hi all
I finished off my OLY III. I managed to balance it on the spar without adding any weight by moving around the receiver, ESC and flight data recorder. All up weight ended up at 68.2oz ready to fly. Now all I need is for the weather to cooperate to do the maiden flight. I've included a few beauty shots and a short video of the controls operation.
OLY III Controls Test (0 min 20 sec)
Old Feb 10, 2014, 08:59 AM
n0irw is online now
Find More Posts by n0irw
LSF 6632 Level II
n0irw's Avatar
United States, OK, Perry
Joined Jun 2006
Hi Mike
That's a beautiful job on your Oly III. I just started mine, but not electrifying it. My build thread is over on Sailplane Talk.....I would like to invite you over to our glider fun fly on May17th in Stillwater.....the flyer can be found in Sailplane Talk nd Sailplane Events under Oklahoma Glider Guider Get Together. We'd love for you to come. Don Harban from Tulsa is coming and some of the other old Tulsoar members as well. Hope you can make it.
Kevin O'Dell
n0irw is online now Find More Posts by n0irw
Old Feb 11, 2014, 09:07 PM
OK FLyer is offline
Lost in the sky
Tulsa, OK
Joined Sep 2007
Thanks Kevin
I hope to make it to the fun fly. Thanks for the invitation.
Old Feb 14, 2014, 11:29 AM
Luckyducky is offline
Find More Posts by Luckyducky
AMA 179
United States, CA, Huntington Beach
Joined Dec 2007
Mike, your OLY III looks great! It has vivid colors which will look really nice in the air.
What's the specs of the power and prop?
Regards,
Ed
Luckyducky is offline Find More Posts by Luckyducky
Old Feb 15, 2014, 03:23 PM
OK FLyer is offline
Lost in the sky
Tulsa, OK
Joined Sep 2007
Thanks Ed
I used the following power system:
Twister T15-900 Outrunner
Aeronaut 13X8 with 40MM Spinner
Castle Thunderbird 54 ESC
Turnigy 3S NanoTech 2200mAh 25-50C LiPo
Old Mar 14, 2014, 05:18 PM
OK FLyer is offline
Lost in the sky
Tulsa, OK
Joined Sep 2007
Maiden Flight!
Hi all
The weather and my schedule finally lined up and I was able to get my Oly III in the air.
I did a range test and a static power test. The WattsUp indicated a peak value 47.73 Amps which was right in line with than the MotorCalc value of 48.13.
Next was glide test. The Oly III flew cleanly and went forever (at least 200 ft.) in ground effect, I had to steer around a tree I didn't expect to reach.
Since it seemed to be trimmed up OK and the controls were functional I decided to go for broke and do a full throttle launch. The model climbed out comfortably at about a 45 degree angle and had little tendency to loop over, it would stay at just about any angle I wanted with very little down elevator ( a click or 2 of down trim would likely make it climb hands off). I caught a thermal almost immediately after launch, the wind was up a bit (about 5-10mph) and it was hard to stay in the thermal. The flight trim was just about perfect, I messed around a little with up and down trim but it really seemed to fly best with neutral trim. A dive test showed that the CG was pretty close to neutral, it would pull out of a dive but it took a while, I might move the CG forward slightly. I didn't do any aggressive stalls but light stalls had a clean break without dropping a wing, it would just drop the nose a fly on. Overall it is a nice flying bird and I am very pleased.
I flew for about 15 minutes feeling out the plane and working some light thermals, a pair of hawks came by and showed me a nice little thermal that I gained a couple hundred feet in. I played with the flaps a little bit but I haven't gotten a feel for them yet. The wind was gusting up a bit from the west (my landing field is North/South and is bounded by trees to the west and steel fenced round pen on the East) so a the next lull I brought it in. The spoilers were very effective and I landed a bit short of my intended spot and at a steeper angle but the ground was soft and other than a bit of mud on the spinner everything is fine.
I always a bit nervous for the first flight and now that I got it down in one piece I'm more relaxed looking forward to many more flights.
I've included a few photos and data logs from my Eagle Tree flight data recorder. Note that the X-Axis scale on the watt data is in battery pack milliamp hours not time.
MIke
Old Mar 14, 2014, 07:59 PM
Rayven is offline
Find More Posts by Rayven
Lift is good
Rayven's Avatar
Olympic Penninsula, WA
Joined Dec 2001
Thanks for the flight report!
Congrats....so beautiful in flight, isn't she??
Rayven is offline Find More Posts by Rayven
Old Mar 14, 2014, 09:55 PM
OK FLyer is offline
Lost in the sky
Tulsa, OK
Joined Sep 2007
Yes she is. The purple shows up well.
Old Mar 15, 2014, 04:48 AM
Ray Hayes is offline
Find More Posts by Ray Hayes
United States, IN, Fort Wayne
Joined Apr 2003
Mike,
Congratulations on your maiden flights.
Is It Ok to post pics on my web with a link to your build thread. Your thread will be very helpful to future builders of the OLY lll.
Ray
Woodys Forever
Skybench
Ray Hayes is offline Find More Posts by Ray Hayes
Build Log Skybench OLY III build k4to.dave Thermal 818 May 31, 2014 04:26 AM
Question Oly II, Oly III or Oly IIs nine2fitzpatrick Thermal 27 Oct 15, 2012 11:54 AM
Build Log My Woody is growing.....photo journal of my Oly III build. hog2soar Thermal 91 Jan 04, 2012 08:14 PM
Help! Building Skybench OLY III questions Gliderbill46 Thermal 7 Oct 02, 2010 02:03 PM
Discussion Oly III build tips ozmo01 Thermal 5 Jan 20, 2008 07:44 PM
