Old May 05, 2015, 08:26 AM
bmilleker is online now
Find More Posts by bmilleker
bmilleker's Avatar
Canada, SK, Regina
Joined Apr 2011
Originally Posted by LVSloper View Post
The props should not be an issue if they are balanced; maybe try a different PIDC.
I tried a couple last night. Luxfloat and Multiwii hybrid. Same issues after a small tuning on each.
I am going to monitor accelerometer vibrations in the GUI. And probably soft mount the FC using foam tape. I am running out of ideas.
bmilleker is online now Find More Posts by bmilleker
Old May 05, 2015, 09:14 PM
Titus Gordon is offline
Find More Posts by Titus Gordon
FPV it is!
Canada, SK
Joined Aug 2012
Shot down by aliens? (CRASH)
Major crash with my Flip FPV pro/Vector FC..
lots of damage
sad panda
FPV 04.05.2015 • Oops! Something happened... (CRASH) (2 min 30 sec)
Titus Gordon is offline Find More Posts by Titus Gordon
Old May 07, 2015, 05:46 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Sorry to see that happen. To me it looks like you lost a motor/esc/prop in flight...lilikely the front right one. The frame rolled into the dead motor and went into the death flip towards the front right arm. What props were you using?
Vantasstic is offline Find More Posts by Vantasstic
Old May 07, 2015, 07:00 PM
FPV it is!
Canada, SK
Joined Aug 2012
Yeah I'm leaning towards ESC failure or prop (but all the props are broken from the crash).
Those are HQ Prop 10x 4.7
Old May 07, 2015, 08:55 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Maybe just the motor stopped then. If you only threw a blade I'd expect a lot of vibrations. Since the prop was still on I'd rule out a lost prop...so either the motor or esc. Of course, it could be something else (like FC gone whacko).
Old May 08, 2015, 10:40 AM
Genivos is online now
Find More Posts by Genivos
Genivos's Avatar
Netherlands, UT, Amersfoort
Joined Oct 2013
Sorry about your loss man... sad to see that it went wrong.
Looks like an ESC failure to me. Not so long ago I had the same issue. Couple times crashed like this. Couldn't figure out. Until there was only one thing left. I changed the ESCs and no problem since. First I was looking in my pixhawk but after multiple crashes, analysis and contact with 3dr that option was excluded. As well as props and engines.
Not sure about the logging of the Vector, does it have good logging?
One other thing, if you don't mind me saying, I find you flying on a bit risky spots with roads and cars and parking lots. But that's just me. I wouldn't do that personally.
Genivos is online now Find More Posts by Genivos
Old May 19, 2015, 06:28 AM
cmanley_nl is offline
Find More Posts by cmanley_nl
Unregistered User
cmanley_nl's Avatar
The Netherlands
Joined Jul 2010
For those using gimbals:
What is the minimum propeller to gimbal clearance one should have?
I'm using HQ 9x4.3 props (they seem more like 9.5 inches diameter) and the clearance between GoPro and prop tip is only around 15mm. I'm concerned that prop wash will show up as vibrations in the gimbal footage.
B.t.w. I saw the XL arms, but they're way too XL.
cmanley_nl is offline Find More Posts by cmanley_nl
Discussion Show Us Your Hoverthings FPV Frame scrape Multirotor Talk 2149 Apr 18, 2014 05:06 PM
Discussion Hoverthings quad flipping and crashing randomly? easymoney99 Multirotor Talk 9 Jun 12, 2012 02:17 AM
Sold Hoverthings HT-FPV black Lucasberg Aircraft - Electric - Multirotor (FS/W) 3 May 04, 2012 08:10 AM
Sold Hoverthings FPV Quad Plug-n-play W/ Naza Blucross Aircraft - Electric - Multirotor (FS/W) 1 May 01, 2012 06:26 AM
Discussion Test flight of Hoverthings.com FPV 'Ralphie' frame daign FPV Talk 1 Jan 16, 2012 01:27 PM
