Old May 15, 2012, 10:52 PM
lanternfly is offline
Find More Posts by lanternfly
Joined Oct 2011
Extending the base of the vector power frame
I would like to extend the base of the vector power frame as shown in the diagram.
I am not sure if this will work out fine if I used it on the box kite.
Any suggestion or comments.
Thks.
lanternfly
lanternfly is offline Find More Posts by lanternfly
Old May 16, 2012, 12:21 AM
flattermann is offline
Find More Posts by flattermann
check the crazyplanes ...
flattermann's Avatar
Germany
Joined Dec 2006
Hi lanternfly,
it works. I did it with 3 GEN. I for my big Deltas (19 foot, 12 foot).
Have fun!
flattermann
flattermann is offline Find More Posts by flattermann
Old May 16, 2012, 02:50 AM
Joined Oct 2011
flattermann
Thank you for your kind reply.
Will try to extend the frame and fixed on my Alpine DC kite.
Hopefully, it will reach for the sky.
BTW, have you ever tried fixing the motor in reverse trust, such that
the propeller is facing the rear of the kite.
I wonder if this reverse trust can actually work!
Some crazy idea just came to my mind.
Cheers!
lanternfly
Old May 16, 2012, 11:55 AM
Germany
Joined Dec 2006
Reverse vector thrust works (I call it 'pusher'), but a 'pulling' vector thrust unit works -on kites- better. Extremely results delivers a 'double' vector unit, containing both:
www.crazyplanes.de/dopvek.wmv
My very first vector kite in 2008 was an experimental Delta Box with a reverse 'pushing' vector thrust:
www.crazyplanes.de/drache1.wmv
flattermann
Old May 16, 2012, 09:09 PM
Joined Oct 2011
Hi flattermann,
You are my idol.
All kind of vector kite tricks you have already tried, enormous experience you have accumulated.
Thanks for sharing!
lanternfly
For Sale Two Gaui 330x frames w/ extended prop mounts mmalik4 Aircraft - Electric - Multirotor (FS/W) 3 Jan 20, 2012 10:56 AM
For Sale Two Gaui 330x frames w/ extended prop mounts mmalik4 Aircraft - Electric - Multirotor (FS/W) 0 Dec 08, 2011 09:21 AM
Sold Hdx300 Base Frame Belt Drive Tail And Head snolord1 Aircraft - Electric - Helis (FS/W) 10 Mar 15, 2008 04:29 PM
For Sale raptor 30 frame base plate gruntdog Aircraft - Fuel - Helis (FS/W) 2 Mar 31, 2006 04:39 PM
Zoom Frame Base Plate jerrysimon Mini Helis 1 Oct 28, 2004 01:36 PM
