Old May 09, 2012, 12:02 PM
modelerchina is offline
Find More Posts by modelerchina
Canada, ON, Mississauga
Joined Apr 2006
Question
quick release heavy duty servo connector
I saw connecting the flap/ail servo everytime on glider can be a boring and risky idea. sooner or later the servo connectors will wear out and fail either flap or aileron servo. is there any connector that really heavy duty and last foreever, hold strong in air but still easy to take off? ideally one connector for all four servo wires is best solution.
modelerchina is offline Find More Posts by modelerchina
Old May 09, 2012, 01:21 PM
Wazmo is online now
Find More Posts by Wazmo
Duane
Wazmo's Avatar
No. VA
Joined Nov 2004
Multiplex plug and socket.
Pair of Deans micro 4-pin connectors. Can use red to differentiate.
DB9 connectors. Available from many other sources also.
Wazmo is online now Find More Posts by Wazmo
Old May 09, 2012, 09:20 PM
Joined Apr 2006
OMG, that's very complete source, thank you
Old May 09, 2012, 09:46 PM
Wazmo is online now
Duane
Wazmo's Avatar
No. VA
Joined Nov 2004
Forgot to mention, if you use DB9 connectors, don't forget the pin and socket terminals. I prefer crimp, but some like solder.
Old May 11, 2012, 11:38 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
For wings with wing rods, I glue pins onto the wing and the socket into the fuse or vice versa. I try to have the pins recessed. When the wing goes in, the plug gets connected automatically. There are many connectors which can be used, but it's good to use something with a bit of extra length. Headers and sockets available from Digikey and such places. Cheap, too. For a wing that bolts on top, the Multiplex connectors aren't bad, though even there it might be good to have them mounted so they plug automatically instead of handling wires all the time. I've seen this done with a DB9 connector on some fancy moldie.
lincoln is offline Find More Posts by lincoln
Found Help! Need just a few Dubro Heavy-Duty Servo Arms! Garret H Aircraft - General - Miscellaneous (FS/W) 5 Apr 16, 2012 08:54 PM
Found Help! Need just a few Dubro Heavy-Duty Servo Arms! Garret H Aircraft - General - Radio Equipment (FS/W) 4 Apr 16, 2012 08:53 PM
Found Hitec Heavy Duty Servo Arms Doubledog Aircraft - General - Radio Equipment (FS/W) 5 Mar 24, 2012 01:10 AM
Sold Servo City heavy duty Pan and Tilt Blue Collar FPV Equipment (FS/W) 4 Mar 20, 2012 04:35 PM
Sold Servo City Heavy Duty Pan / Tilt for antenna tracker w EZ Antenna Tracker thefokker FPV Equipment (FS/W) 4 Sep 08, 2011 07:53 AM
