Old Nov 02, 2010, 09:23 PM
GoatZilla is offline
Find More Posts by GoatZilla
GoatZilla's Avatar
Joined Sep 2005
Compact 2.4Ghz transmitter
So does anyone make a (decent) compact 2.4GHz transmitter? I want to put together a "travel" plane, but it seems the limiting factor is increasingly the obnoxiously bloated size of the standard transmitter.
I'm of the generation that grew up with video games, so a console gaming sized/styled controller would suit me perfectly well, particularly for the kind of flying that I do. As long as it had trims, expo, and v-tail/mixing.
GoatZilla is offline Find More Posts by GoatZilla
Old Nov 02, 2010, 11:08 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Originally Posted by GoatZilla View Post
So does anyone make a (decent) compact 2.4GHz transmitter? I want to put together a "travel" plane, but it seems the limiting factor is increasingly the obnoxiously bloated size of the standard transmitter. I'm of the generation that grew up with video games, so a console gaming sized/styled controller would suit me perfectly well, particularly for the kind of flying that I do. As long as it had trims, expo, and v-tail/mixing.
GWS 2.4GHz Parkflyer Radio System Review
Ideal for those used to "gaming"
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Nov 03, 2010, 10:10 AM
johnkielsen is offline
Find More Posts by johnkielsen
COPENHAGEN DENMARK
Joined Aug 2007
I look for a SPEKTRUM MLP4DSM range extender, but I don`t know how. I need a range around 1000 feet. I have COX MIXER built in.
John
johnkielsen is offline Find More Posts by johnkielsen
Old Nov 03, 2010, 11:02 AM
John Kim is offline
Find More Posts by John Kim
Panorama City, CA
Joined Sep 2004
I saw tiny 2.4 transmitters that come with Ready to Fly compact foam planes in the same box. Check Horizon Hobby.
I don't know if they sell radio separately.
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Old Nov 03, 2010, 11:56 AM
COPENHAGEN DENMARK
Joined Aug 2007
Thank You John Kim
But the range is around 300 feet.
John
Old Nov 03, 2010, 12:24 PM
GoatZilla's Avatar
Joined Sep 2005
The GWS unit seems to lack v-tail and expo.
The closest thing so far is the E-Flite controller that comes with the Blade MCX RTF, but even that lacks v-tail.
Does anyone know if that transmitter can bind to other DSM2 RXs? Or if it has any other quirks or hidden switches for mixing?
Old Nov 03, 2010, 12:57 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
I'm thinking about adding a Fly Dream DIY module to the MPL4DSM. This would give me a very small full range transmitter. Not sure yet if the module will fit inside, but even strapped on the back it's still a compact package. The module uses 3.3v and has low current drain, so should be fine on 4 AA cells.
The Fly Dream receivers range down to 1g in weight for a 4 channel! I have used the "large" 4-channel (3g!) and had excellent range (nominally 500m). I've used FD since the spring with no problems.
For details of Fly Dream in North America, go to:
http://www.rc-modules.com/
If I need V-tail or elevons, I'll use a mixer in the model.
Daedalus66 is offline Find More Posts by Daedalus66
Old Nov 03, 2010, 02:52 PM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
If the MPL4DSM is the TX that comes with things like the mSR, I doubt it has a PPM stream that you can use with other modules unless someone has found a hack that I haven't seen.
village_idiot is offline Find More Posts by village_idiot
Old Nov 03, 2010, 05:29 PM
srnet is online now
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
I bought one of the GWS TXs specifically for a travel setup.
I dont use expo even when I am flying with my 35Mhz RD6000, so I do not miss that. Lack of vtail is not an issue either, just get a vtail mixer from eBay for $5, small and light.
There are two travel planes I have which I fly with the GWS TX, one is a Weasel Sloper, goes back in the box, it needs the Vtail mixer and flys with no problems at all.
http://www.rcgroups.com/forums/showthread.php?t=1039051
The second is a take apart Gambler DLG, see the picture, the plane, electric power pod spare batteries tools etc all fit in the box.
The GWS TX is low power, but the range is fine for the small size of a travel plane. If you need longer range then you are going to be carrying a much larger plane around with you, so I dont see the point of a small TX.
srnet is online now Find More Posts by srnet
Old Nov 03, 2010, 07:49 PM
COPENHAGEN DENMARK
Joined Aug 2007
I want a size like the PLANTRACO, but DSM 2 and better range. i plan to mod a small HBZ
CHAMP with removable wings and tail. My DX6i is to big for travel.
John
Old Nov 03, 2010, 08:08 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
John
The RTF Champ comes with the small DSM2 transmitter and has pretty good range (enough for a 22" span model). All you have to do is make it more compact.
Old Nov 03, 2010, 08:40 PM
GoatZilla's Avatar
Joined Sep 2005
I tend to be rather minimalist about things to save budget for payload, so I am trying to avoid putting an extra v-tail mixer in there if at all possible. The only dead weight I want on there is my keychain camera...
Cool. The plane I've actually got in mind is an Alula Evo. Still molling over the build details...
Someone should just make a bridge between a multitouch Android device (via it's USB debug interface) and one of those RC TX units... Guess we'll have to wait a few more generations before these archaic TX designs finally die off.
Old Nov 03, 2010, 09:02 PM
Inciting Riots
Joined Dec 2006
Small like the Plantraco TX is going to be hard. It does have a PPM stream coming out from the trainer connection, so you might be able to graft a 2.4Ghz module onto it and give it a go. You are going to need at least 4 volts for a Spektrum module.
Old Nov 03, 2010, 09:05 PM
COPENHAGEN DENMARK
Joined Aug 2007
No, the range of the small TX is not good, around 300 feet. Sometimes I have get it back
from 600 feet or more, when it is blown away, in windy conditions. I can only see a spot,and control it by see which way it moves, by my control inputs. DX6i is fine, but not the small one. I live in a very windy place.
John
Old Nov 04, 2010, 01:34 AM
srnet is online now
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
The leads on the V tail mixers are over long, trimmed back and the overall weight would be around 3.5g. In the case of the Weasel it needed extra weight forward of the COG in any case. The matching RXs for this TX are very light too, around 3.5g.
I removed the TX antenna on mine and replaced it with a RP SMA socket so that I could use a standard removable Wi-Fi antenna.
The power consumption of the GWS TX is very low and you should get about 60 hours of use from a set of 4 x AAs, so n real need to carry a charger around.
The in air range of the GWS setup was around 600ft, plenty for flying small portable planes.
For Sale Airtronics SD-6G 2.4Ghz 6-Ch Computer Radio Transmitter Only $80.00 FieldofDreamsFlyer Aircraft - General - Radio Equipment (FS/W) 4 Feb 18, 2011 12:37 AM
Sold Never used Futaba 8FGH 8-Channel 2.4GHz Heli Transmitter *only Carbon Copter Aircraft - General - Radio Equipment (FS/W) 4 Oct 27, 2010 10:07 AM
For Sale Airtronics SD-6G 2.4Ghz 6-Ch Computer Radio Transmitter Only $80.00 FieldofDreamsFlyer Aircraft - General - Radio Equipment (FS/W) 1 Oct 18, 2010 11:07 AM
Sold Futaba 8FGA 8-Channel 2.4GHz Air Transmitter and R6008HS 8-Channel Receiver $350.00 mike(ocrc) Aircraft - General - Radio Equipment (FS/W) 7 Oct 13, 2010 10:30 PM
Sold New 2.4GHz Transmitter DSM2: Vapor/Ember 2/Champ dizzane Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Sep 08, 2010 06:45 PM
