Old Nov 03, 2004, 09:34 PM
rpvpilot's Avatar
United States, AZ, Yuma
Joined Oct 2003
Disabling ESC brakes, enabling mechanical brakes.
I feel I have a solution to the brake mystery. You need a fairly high end radio and a 3 ch. Rx to accomplish it, but I'll explain using my Futaba 3PK.
First I disable the ESC's braking effect by turning the braking ATV to zero on the Tx. Then create a mix program (throtle-to-Ch3) setting the Th. channel as master and channel 3 as slave. Then just set the bias of thr. channel to brake channel so that it's where you like it.
That leads me to my next idea. My radio is set up with a feature the most of the 1/5 car guys use, front to rear brake bias, driving a separate servo for each end of the car. Why not do it for bikes? All that would be required is seting up a side plate to accept two micro servos, one for the front and one for the rear. Then set up the radio with more front bias than rear. I can also integrate a mix that allows an A.B.S. function that automatcally shifts from A.B.S. mode in straight lines to normal brakes when the wheel is turned past a certain amount so that the A.B.S. doesn't upset the bike when leaned over.
Just trying to get your brains stimulated guys!
rpvpilot is offline Find More Posts by rpvpilot
Old Nov 03, 2004, 10:23 PM
vaz2107's Avatar
Dubai U.A.E
Joined Oct 2003
Originally Posted by rpvpilot
I can also integrate a mix that allows an A.B.S. function that automatcally shifts from A.B.S. mode in straight lines to normal brakes when the wheel is turned past a certain amount so that the A.B.S. doesn't upset the bike when leaned over. Just trying to get your brains stimulated guys!
RPVpilot: Clever idea that. I've got my nitro bikes set up on a JR R1, but never thought about configuring the ABS like you mentioned
kevin@rcbike.com
vaz2107 is offline Find More Posts by vaz2107
Old Nov 03, 2004, 10:37 PM
rpvpilot's Avatar
Joined Oct 2003
If you try it, let me know how it works! I'll try it this week on mine.
Old Nov 03, 2004, 11:02 PM
vaz2107's Avatar
Dubai U.A.E
Joined Oct 2003
OK, will do and keep you posted. Only thing is I think the weather isn't going to be that good this weekend, so that may stop play , plus next week I'm out of town
kevin@rcbike.com
Old Nov 04, 2004, 11:14 AM
metomwhou's Avatar
Stuttgart
Joined Jan 2004
Sounds promising! I hope I can do that on my XS3. If Furron is watching this thread, do you have any good news for us on the Novak B/L??
Tom
metomwhou is offline Find More Posts by metomwhou
Old Nov 04, 2004, 03:58 PM
Chainlube By Dave
chainlube's Avatar
Denver, Colorado. USA
Joined Aug 2004
I have an xs3 and a novak ss5800 also, and I'm eagerly awaiting the same info.
Dave (Chainlube By Dave)
chainlube is offline Find More Posts by chainlube
Old Nov 04, 2004, 10:01 PM
rpvpilot's Avatar
Joined Oct 2003
OK guys, I've got my bike now, so I'll start to figure out this thing with the brakes.
Discussion Hobbico Upstar ESC--brakes Dirty Bad Jim Electric Sailplanes 6 May 03, 2007 06:41 PM
Idea Disabling esc bec.. flightmare Power Systems 5 Dec 28, 2006 07:35 AM
ESC Brakes? RcAroPlanes Electric Ducted Fan Jet Talk 3 Nov 04, 2004 07:19 PM
ESC Brakes vs. gearboxes - how should they get along? Joedy Electric Sailplanes 11 Feb 17, 2003 10:25 AM
Brakes on ESC's. LESLIEx317537 Parkflyers 6 Nov 26, 2002 12:18 PM
