Old Apr 18, 2014, 03:17 AM
Andrew u.k.'s Avatar
Berkshire U.K.
Joined Oct 2006
Question
Blade 450 3d tail rotor problem
Hi
A question from a relative newbie.
I've been flying my Blade 450 3d quite well with only 2 minor crashes caused by a failed servo & motor bearing (should check it over more carefully, so pilot error definitely on the first one ).
I replaced the motor and had completed 2x 7min flights. On the third flight I was doing low slow circuits when the tail started to spin, not really fast and violent but fast enough. I hit throttle hold and landed up right with just the stabiliser pulling out of its screw.
The tail still seems to be on solid and the servo works.
I'm not sure what it could be as everything seems to be fine.
Any ideas?
Cheers Andrew
Andrew u.k. is offline Find More Posts by Andrew u.k.
Old Apr 18, 2014, 11:23 AM
RC Heli Addict
United States, GA, Dublin
Joined Mar 2013
Check your tail belt tension. If the tail belt is not tight then it will slip causing the tail to spin out.
shaun.evans09 is offline Find More Posts by shaun.evans09
Sold Blade 450 3d: swash plate, tail assembly, and tail drive Terson Aircraft - Electric - Helis (FS/W) 4 Mar 28, 2014 12:59 AM
Help! Blade 450 3d tail problems. Help josh.wallent Electric Heli Talk 7 Mar 06, 2014 09:16 PM
Sold Blade 450X / 450 3D Main tail Drive Gear (2): B450 by BLADE (BLH1653) Terson Aircraft - Electric - Helis (FS/W) 2 Feb 24, 2014 11:47 AM
Sold Blade 450 3d swash plate, tail assembly Terson Aircraft - Fuel - Helis (FS/W) 0 Oct 27, 2013 11:33 PM
Discussion Blade 400 3D Tail Rotor Problems Treb Mini Helis 2 Jun 02, 2008 06:17 AM
