Jeti HiCopter Voltage Regulator
Power for Your FPV Gear
Solid 12V Power for FPV Equipment
The Jeti HiCopter is a switch mode BEC unit that can accept 14-42V (4S -10S Lipo) input voltage and supplies a steady 12V out up to a constant 3A with 12A peaks. This can be really useful if you are battling weight and don't want to add an extra 3S Lipo on your craft to power your video transmitter and camera. It only weighs 29g and the only downside would be that it is drawing off of your main battery pack and your run times could be affected. The weight savings would likely make up for that and the small size of this BEC unit makes for a clean nice looking setup and there is something nice about only having to plug in one battery to get everything working. [Esprit Model]
Specs:
  • Type: Switching Regulator
  • Max Input Voltage: 42V
  • Min Input Voltage: 14V
  • Output Voltage: 12V Stabilized
  • Output Current: 3A Continues/12A Peak
  • Dimensions: 60mm x 28mm x 10mm
  • Weight: 29g
  • Applications: FPV & APV Devices
Old Dec 30, 2013, 09:25 AM
The Valkman's Avatar
Joined Nov 2011
Thanks for the post and info but $55 ( ex ship ) is a bit much in all fairness.
A quick example from the adverts above is ..
http://www.rctimer.com/product_1009.html
And it cost less even though you get more, metal cases, and leads. I know its a different product but there is no special components in either.
The Valkman is offline Find More Posts by The Valkman
Old Dec 30, 2013, 12:43 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
What everyone needs to know first is what is the RF signal emitted from this device? If it emits anything on 433MHz or close to it, it could be a no-go for many FPV pilots.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Help! camera step up voltage regulator question snoshoe62 FPV Equipment 5 Dec 16, 2013 05:13 PM
For Sale BNIB Align RCE-B6T 2-in-1, Voltage regulator & Remote Glow VKGT Aircraft - Fuel - Helis (FS/W) 1 Dec 11, 2013 05:41 PM
For Sale BNIB Align RCE-B6T 2-in-1, Voltage regulator & Remote Glow VKGT Aircraft - Fuel - Engines and Accessories (FS/W) 0 Dec 10, 2013 02:40 PM
For Sale Scott Gray Reactor X2 voltage regulator $50 pete914 Aircraft - General - Radio Equipment (FS/W) 0 Dec 03, 2013 08:04 AM
Discussion Dimmer switch to regulate voltage NighthawkF-117 DIY Electronics 10 Nov 30, 2013 03:05 PM
