Old May 01, 2013, 10:15 PM
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
Mini-HowTo
making & mounting landing gear for F3P & freestyle planes
This "how to" thread will demonstrate a simple way to make and mount landing gear with wheels on F3P and freestyle depron planes.
I have a video that shows all steps needed to assemble the gear, and tips for mounting onto an airframe.
supplies needed:
Carbon fiber for legs. (you can use 1.5,1.2 or 1mm size.)
1.2mm was used in the video for the demonstration and a weight of 1.2g.
Braided fishing string for wrapping axle/leg joint. (use 10# or less)
Dubro small fuel tubing used for retaining the wheel to the axle
Thin CA glue
wheels
The weight for the landing gear, with wheels was 1.2g
aerolite (Dennis R.)
Remember to always use safety glasses and mask when cutting and sanding carbon fiber, and when using CA glue!
MAKING LANDING GEAR FOR FOAMIES (11 min 3 sec)
aerolite is offline Find More Posts by aerolite
Old May 02, 2013, 01:23 PM
Joined Jan 2010
making landing gear for F3P & freestyle planes
aerolite,
Nice thorough review. Specifics always are very helpful. Wish I would have had this concept to use before I started my current build. Really like the idea of the jig to make getting the angle of the axle relative to the strut as desired and the easily replaceable reinforcements at the top of the strut. Looks like a little extra mass to the airframe, but probably more than worth it if a repair or replacement of the landing gear is required.
Will give your process a shot on my next build.
Dave
DaveWhitt is offline Find More Posts by DaveWhitt
Old May 03, 2013, 07:42 AM
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
Originally Posted by DaveWhitt View Post
aerolite,
Dave
Dave, thanks for the kind words. Give it a try, and let us know what you think. It's really easy to do, and works great on any foamy. I've been mounting my landing gear this way for several years, and have no problems at all with this setup. If you have any questions, or need additional photos, just let me know.
aerolite
Discussion new PT Carbon propellers for F3P/Freestyle HonzaS Indoor Pattern/F3P 6 Feb 28, 2013 03:41 AM
Sold 2- Carbon Fiber Landing Gear for larger plane Ifly101 Aircraft - General - Miscellaneous (FS/W) 0 Feb 23, 2013 04:14 PM
Discussion Making f3p & freestyle landing gear aerolite Indoor Pattern/F3P 67 Dec 24, 2010 03:46 PM
Discussion Installing Landing Gear on Freestyle & F3P aerolite Indoor Pattern/F3P 3 Oct 17, 2010 02:47 PM
Discussion Would it make any sense to make the Ultra Mini Stick a Tricycle landing gear plane? djdaveq Electric Plane Talk 15 Oct 24, 2006 08:23 PM
