Old Aug 04, 2013, 06:30 AM
holco's Avatar
The Netherlands
Joined Mar 2007
Test new Plettenberg Orbit 15-34 with the Mejzlik 15x5 propeller.
This combo had a 5 minutes test run on 1200 grams, with an ambient temperature of 26 the motor reached a max temperature of 48, so in total 22 above ambient.
Plus/minus Amp's draw by different weights and config's,
Hexa AUW 4Kg: 15,9A
Hexa AUW 5Kg: 21A
Hexa AUW 6Kg: 26,2A
Hexa AUW 7Kg: 34,3A
Octo AUW 7Kg: 30,4A
Octo AUW 8Kg: 35,6A
Octo AUW 9Kg: 42,4A
Octo AUW 10Kg: 50,4A
Octo AUW 11Kg: 56,8A
Octo AUW 12Kg: 66A
Octo AUW 13Kg: 73,6A
Octo AUW 14Kg: 83,2A
Plettenberg Orbit 15-34 / Mejzlik 15x5 / 6S (5 min 59 sec)
holco is offline Find More Posts by holco
Old Aug 08, 2013, 04:32 PM
holco's Avatar
The Netherlands
Joined Mar 2007
Conversion of the pan to brushless,
Mirror test,
Flexacopter BDD mount now with brushless pan (0 min 35 sec)
Old Aug 09, 2013, 10:23 AM
holco's Avatar
The Netherlands
Joined Mar 2007
Flexacopter BDD mount now with brushless pan2 (1 min 6 sec)
Old Aug 12, 2013, 07:00 PM
holco's Avatar
The Netherlands
Joined Mar 2007
First test shoot with the brushless pan.
10 aug brushless pan test shoot with gopro (6 min 52 sec)
Old Aug 21, 2013, 03:32 PM
holco's Avatar
The Netherlands
Joined Mar 2007
DJI retracts on the Kratos
Kratos with DJI retractable landing gear (1 min 46 sec)
Old Aug 22, 2013, 04:05 AM
holco's Avatar
The Netherlands
Joined Mar 2007
Weight for one leg,
Old Nov 02, 2013, 05:28 AM
holco's Avatar
The Netherlands
Joined Mar 2007
Teaser,
BIG pan axle bearing hub, (61705-2RS)
Old Nov 02, 2013, 05:59 AM
holco's Avatar
The Netherlands
Joined Mar 2007
Old Nov 08, 2013, 04:55 AM
holco's Avatar
The Netherlands
Joined Mar 2007
Ready to go to the anodizer
Old Nov 14, 2013, 02:33 AM
holco's Avatar
The Netherlands
Joined Mar 2007
All fitting perfectly
Pan-bearing with 25mm shaft,
Old Dec 01, 2013, 03:17 AM
holco's Avatar
The Netherlands
Joined Mar 2007
V2 wire-damper brackets, more than 50% weight reduction.
Old Jan 15, 2014, 12:16 AM
Scraghty
scraghty's Avatar
Joined May 2012
Can someone please correct my math. AUW of 10kg / 8 motors = 1250 grams thrust needed per motor. x2 for 50% hover efficiency = 2500 grams thrust.
How does this motor with 1256 thust, get of the ground. Im doing something wrong. Clearly a rookie mistake. Thanxs,
Originally Posted by holco View Post
Made a prediction of the flying time with a theoretical AUW of 10Kg for the Kratos.
Snapshot of the video at 1256g lift, this shows that there is +/- 7,65A running.
7,65A X 8 = 61,2A total
80% of 16000mAh lipo = 12800mAh or 12,8Ah
12,8 61,2 = 0,209 hour
0,209 X 60 = 12,54 minutes total flying time
Seems to me a very nice result
scraghty is offline Find More Posts by scraghty
Build Log Flexacopter ---The Making Of--- holco Multirotor Talk 695 Dec 01, 2013 11:46 AM
Discussion Theoretically using a Naza to control an Octocopter? Kahuna717 Multirotor Talk 15 Apr 01, 2013 02:40 AM
Discussion Make octocopter with least 15kg payload zowex Multirotor Talk 30 Oct 19, 2012 09:09 AM
Help! Seeking Qualified Builder for an Octocopter Project Canoctocopter Power Systems 3 May 02, 2012 03:15 AM
Discussion Will this work for an octocopter frame design? webgeek Multirotor Talk 6 May 13, 2011 03:44 PM
