Old Feb 18, 2004, 06:53 PM
Fairport, NY
Joined Jun 2003
Packing Tape not sticking to Depron?!?!
What do you guys use to for hinge tape when using Depron? Packing tape doesn't seem to stick well to it at all!
Napolean
Napolean B. is offline Find More Posts by Napolean B.
Old Feb 18, 2004, 07:45 PM
Rehab is for quitters
LuckyArmpit's Avatar
West Middlesex, PA, US
Joined Jun 2001
Use an adhesive spray to very lightly spray the foam before you affix the tape. Be careful when you use the spray because most of them have acetone which will eat foam. If you lightly spray about 3 feet away from the foam, the acetone will evaporate before it hits the foam. I've used the newer 3M spray this way and haven't melted any foam yet.
Dave...
LuckyArmpit is offline Find More Posts by LuckyArmpit
Old Feb 18, 2004, 11:20 PM
Hard Wired
Clinton Sherman, Oklahoma, United States
Joined Nov 2003
Try wiping the Depron down with alcohol prior to taping.
flipinflopin is offline Find More Posts by flipinflopin
Old Feb 19, 2004, 01:24 AM
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
Blenderm tape sticks very well to Depron.
GBR2 is offline Find More Posts by GBR2
Old Feb 19, 2004, 04:20 PM
Quiet Power
USA, CA, Citrus Heights
Joined Mar 2001
I personally have shied away from any type of Hinge Tape. Almost always seems to pull away near the control horn or worse. Been using the mylar found in old floppy disks. Cut to shape, drill some holes in the part that is inserted into the depron (for the epoxy). Control LE surfaces need to be "V" shaped vs. tapered.
My simple $.02
Happy flying
costath is offline Find More Posts by costath
Old Feb 19, 2004, 07:39 PM
1,1,2,3,5,8,13,21,34
Shortman's Avatar
United States, OR, Portland
Joined Nov 2003
Napolean, your airplane isnt by any chance airbrushed is it? I found that packing tape does not like to stick to airbrushed depron foam. On plain white it has worked fine for me.
Steven
Shortman is offline Find More Posts by Shortman
Help! Tape not sticking to my wing eckace1 Flying Wings 13 Oct 25, 2006 09:22 PM
Acrylic paint and packing tape do not mix..Help!! DavidJ Parkflyers 7 Sep 07, 2002 11:21 PM
T-52 & Packing Tape? mrebman Foamies (Kits) 5 Aug 26, 2002 04:04 AM
Source for colored packing tape??? Steve-S Electric Plane Talk 5 Jun 03, 2001 10:24 PM
Hinge tape - Packing tape OK? ChrisD Power Systems 8 May 05, 2001 12:35 AM
