Old Apr 21, 2014, 02:10 PM
Vik_'s Avatar
Prague CZ
Joined May 2010
Hi Nuts
I thing I will give them a try. the extra capacity is tempting.
The Nano Tech (20-50C) 6000mAh 6S are 908g
The Zippy 40C 5000mAh 6S are 895g so it is looking good I thing.
Hi All,
I made small progress over the last few days.
The canopy frame was glued to the skin on the fuse to get the correct shape.
I'm thinking about the sliding canopy.
The ESC is mounted to the firewall. There will be a direct duct to cool it from the propeller/fan.
Rudder is now covered in Solartex with MR rib tape. It is really easy to work with and I'm pleased with the results so far.
I had to change the work type so I started to paint the pilot. I really like the Bestpilots product. Sailor Malan is waiting for his turn too. During the week I may go to see the artist shop to get some oil paint and try some shadowing to get some more depth. Colors are not 100% accurate as I was working with what I had at home.
And to end up in TopGear style - I made a hole in the fuselage
That's it for now. Happy Easter
Vik_ is offline Find More Posts by Vik_
Old Apr 27, 2014, 04:19 AM
Vik_'s Avatar
Prague CZ
Joined May 2010
Hi All,
Only a quick info:
based on the weights with counted batteries, color etc I shall be on the 12.5Kg range.
Which is tad more than I was hoping for.
The ecalc gives me 307W/Kg (139W/lb)
So what do you thing?
Old Apr 27, 2014, 07:39 PM
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
139w/lb should fly the plane quite well in a scale like manner. Others will say you need more, but only if you want to do things the real plane couldn't or shouldn't
Nice work by the way, I've been watching without comment since the start. She is a beauty!
I had the supreme pleasure of seeing a real one fly this past summer. Never dreamed I'd ever see anything more than pictures. I was suitably impressed!! fwiw jmho Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Apr 28, 2014, 10:17 AM
low, left, & fast
nuts-n-volts's Avatar
Albuquerque, New Mexico
Joined Dec 2004
+1 on Doug's reply. The plane should be more than OK at that power/weight and it should have just a bit more power than scale. Perfect. Most of the time, more power equates to more weight anyway. Of course, keep it as light as you can. I'm interested in seeing what you actually end up with as I've been pondering getting this kit as well. I should just order it. It looks too nice!
nuts-n-volts is offline Find More Posts by nuts-n-volts
Old Apr 30, 2014, 03:35 AM
Vik_'s Avatar
Prague CZ
Joined May 2010
Hallo Nuts,
If you can get one get it now. Sist (Stefan Siegmund) actually closed his company due to healt issues. I heard that the molds were sold, but so far no offer has been made for re-relasing the kit. Which is sad.
Old May 08, 2014, 02:01 PM
Vik_'s Avatar
Prague CZ
Joined May 2010
Hallo All,
I decided to go on the end with the Nanotech. I hope I have chosen wisely
The gear doors are as on full scale from two parts. And in the kit from even more parts It is not really hard. It just takes me more time than expected.
So upper door:
Lower door:
as for battery placement I decided to make a battery box above the motor with access from the gun hood. This would be my next task I guess.
Old May 10, 2014, 01:32 AM
Vik_'s Avatar
Prague CZ
Joined May 2010
a tad bit off topic, but this is a cool guy
Helicopter Pilot Saves Kid's RC Plane (4 min 54 sec)
Old May 12, 2014, 10:20 AM
low, left, & fast
Joined Dec 2004
Righteous!!
Old May 23, 2014, 12:44 AM
Vik_'s Avatar
Prague CZ
Joined May 2010
Hi All,
Small progress on the build side has been made.
The elevators are now covered and all control tabs epoxied on the place.
It looks like this:
The battery box is finished as well ready for gluing in to the place. I realized that the ESC position will have to be changed. The box will go partially above the motor and with be glued to the fuselage formers on the other side (gunhood) to spread the battery weight. It is not done 100% tight to allow some space in case of exchanging the batteries for different brand. I hope this will prevent lot of additional nose ballast.
And have a nice sunny weekend hopefully with fly-friendly weather
Old Jun 09, 2014, 02:20 AM
Vik_'s Avatar
Prague CZ
Joined May 2010
Hi All,
After I got back from US I could continue on the battery box.
Now it is done and the batteries are really easy to exchange. It is connected to the internal structure of the fusalage to transfer the forces evenly.
Old Jul 13, 2014, 03:21 PM
Vik_'s Avatar
Prague CZ
Joined May 2010
Hi All
Only a small motivation picture. Finally the wing mounting is done. First time on own legs.
Old Jul 14, 2014, 10:18 AM
Ducky22's Avatar
Canada, ON, Mississauga
Joined Apr 2011
Very nice, indeed great motivation!
Ducky22 is offline Find More Posts by Ducky22
Sold Holman 1/5th scale FW190A kit demire Aircraft - Fuel - Airplanes (FS/W) 5 Jul 19, 2012 07:24 PM
For Sale Glennis 5" FW190A wheels demire Aircraft - Fuel - Airplanes (FS/W) 0 Mar 04, 2011 11:47 AM
For Sale Vailly FW190A 1/4.5 kit partially built. demire Aircraft - Fuel - Airplanes (FS/W) 1 Jan 01, 2011 05:19 PM
Wanted Sist 1/5 FW190 A8 scale wheels and spinner w/ fan invertmast Aircraft - Fuel - Airplanes (FS/W) 0 Nov 30, 2010 12:34 PM
For Sale Pro Built 1/48 Fw190a-6 Checkerboard Nose ASAMech Non R/C Items (FS/W) 0 Sep 30, 2008 07:03 AM
