Old Aug 10, 2012, 01:42 AM
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
Experts! Please critique my new fpv setup
Im currently planning a new fpv setup and here is what i plan on going with. Goals are about 5km range, clear video, PA & RTH, robust operation.
Plane: super sky surfer 2.4m (can too big be a bad thing?)
Vtx/rx: Bevrc 5.8ghz 500mw or Immersionrc 600mw, any preference?
Tx Antenna: clover leaf antenna from bevrc
Rx antenna: not sure yet. Suggestions?
Camera: 600tvl sony super HAD ccd w/2.8mm lens
Osd: nova
Display: my laptop with a composite input video capture card
Rc transmitter: my futaba 9c with a frsky module.
Future addons:
1W 1.2 ghz booster for the frsky tx module + 7db patch antenna
What do you think?
compuatic is online now Find More Posts by compuatic
Old Aug 10, 2012, 02:18 AM
Ask me about my FPV addiction
Ugrd's Avatar
United States, MN, Wayzata
Joined May 2011
Looks good to me, but your going to need a circuital antenna to match your cloverleaf. also a booster is normally the worst thing you can do to get more range. Get a real LRS like a dragon link chain link etc. I don't know why you said 1.2 ghz booster for your radio because im pretty sure its still on 2.4 ghz
Cheers,
Ugrd
Ugrd is offline Find More Posts by Ugrd
Old Aug 10, 2012, 02:22 AM
Joined Jul 2012
Great setup only display should be on Monitor or goggles, they say pc can make video lag.
FPVAustralia is offline Find More Posts by FPVAustralia
Reply With Quote  (Disabled)
Old Aug 10, 2012, 03:52 AM
New Zealand, Waikato, Cambridge
Joined Feb 2012
Osd: nova
Future addons:
What do you think?
Vtx: go for bevrc/foxtechfpv 5.8ghz 400mw instead; if you are shopping at foxtechfpv, pickup a couple of 4V regulators (under HoryzonHD section) for DZO-V58N.
Cloverleaf from bevrc are, reportedly, crap. Invest into bluebeam or circular-wireless antennas.
Rx antenna: circular-wireless helical.
Camera: you mean PZ0420 from SC2000, correct?
Laptop for the display is a bad idea. It will run out of battery at the worst possible moment. Get goggles and DZO-V58N off ebay instead.
Get a recorder: DZO-V58N is a good one.
Get a TK102 GPS/GSM tracker -- it is only a matter of time of you loosing the plane. Make it easier to recover it.
RC receiver: get 60cm extensions for FrSky antennas.
Don't use booster, use better antennas. Get 7db FrSky patch straight away and a good biquad later (e.g., fredrich electronics, which I reviewed here).
mkuvy is online now Find More Posts by mkuvy
Old Aug 10, 2012, 08:45 AM
Ceros007's Avatar
Montreal, Québec, Canada
Joined Apr 2010
Don't buy the 500mw! Go for the 200mw or 400mw.
Ceros007 is offline Find More Posts by Ceros007
Old Aug 10, 2012, 01:14 PM
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
yes i meant 2.4ghz booster. Can someone elaborate why the booster is a bad idea?
Can someone recommend a good cheap display and a recording device? I was planning on using the laptop to do the recording and then a seperate display or goggles for actual flying. Ideally i would like to get the fatshark googles but will probably start off with some sort of cheap display first.
I didn't realize that the 400mW units are better than the 500mW. Can someone elaborate why please?
mkuvy, yes that is the camera i have in mind.
Old Aug 10, 2012, 01:59 PM
United States, IN, Carmel
The first batch of CP antennas were crappy indeed - too much hot glue in the middle.
Bevrc has changed the design since then.
/Dimitrios
Dimitris76 is online now Find More Posts by Dimitris76
Old Aug 10, 2012, 03:32 PM
Joined Feb 2012
All answers to your questions are already on RCGroups. Unfortunately, RCGroups search is not the best as it spews out a lot of garbage. Try searching for "rcgroups <question>" on Google, e.g., "rcgroups 5.8ghz 400mw 500mw" and then clicking the "More results from rcgroups on google". In this instance the right thread is http://www.rcgroups.com/forums/showthread.php?t=1654119
DZO-V58N that I mentioned is the good cheap display and recorder.
Old Aug 10, 2012, 05:54 PM
Australia, VIC, Melbourne
Joined Aug 2012
Nice setup you got there mate. Yeah hate when CP have too much glue.
FirstPersonView is offline Find More Posts by FirstPersonView
Old Aug 11, 2012, 11:55 PM
Koo
A semi-advanced FPV newbie
Koo's Avatar
United States, OH, Oxford
Joined Mar 2012
The booster is not necessarily a bad idea.
Here is link to my topic that discusses the idea. http://www.rcgroups.com/forums/showthread.php?t=1706509
From my research, the booster will work just fine. You might need an ubec to power the booster at 5v (depending on the booster) but with 5.8ghz video, you will probably lose the video before controls. Get the frsky patch from hk for $4 with buddycode and you might not even need it.
Koo is offline Find More Posts by Koo
Old Aug 12, 2012, 07:47 PM
100mph club member
turbodriven's Avatar
NW O-town
Joined Jun 2005
There is a good chance that any booster you get will burn out eventually. I was using a 500mw wifi booster setup powered from a ubec on my 2.4ghz radio. Last month I was getting about 2 miles range and now I'm down to about 1/2 mile when failsafe kicks in. I'm pretty sure she fizzled which is not uncommon as I understand. Luckily I got it for pretty cheap.
turbodriven is offline Find More Posts by turbodriven
Old Aug 12, 2012, 09:20 PM
Koo
Koo's Avatar
Joined Mar 2012
What radio system where you using? With frsky, there is much less strain on the booster than on some other systems
Old Aug 12, 2012, 10:13 PM
100mph club member
NW O-town
Joined Jun 2005
I'm using a futaba 9c with an Assan 2.4ghz module. I was running a 3db attenuator in line before the booster.
Old Aug 14, 2012, 12:21 AM
Joined Aug 2012
Great setup, should work fine!
Discussion new to FPV and want your opinion on my setup (already research options) jaas75 FPV Talk 16 Aug 09, 2012 01:42 PM
Help! Critique My Remzibi OSD Setup Please paintz2007 FPV Talk 11 May 07, 2012 02:36 PM
Discussion Please critique my FPV setup! Pics included. KC10Chief FPV Talk 8 Apr 06, 2012 12:03 PM
Help! Power system experts: please critique my setup lgibjones High Performance 8 Apr 05, 2007 01:26 PM
all my savings are going into this heli, can you critique/commenton my setup Yen Micro Helis 12 Oct 19, 2004 05:43 PM
