Old Jul 16, 2014, 02:16 AM
Australia, QLD, Mudgeeraba
Joined Jul 2014
new blade nano will not fly
Hi to all,
I am new to this forum, hope i am in the correct area, I have just bought a Blade CPX nano, when you increase throttle, it just stays there, if you feel the air coming from the rotors it is go up, it should be going down so to lift the helicopter off the ground.
I have a spektrum DX4e controler, if i try to go to stunt mode by turning the ACT/AUX switch to on nothing happens, motor should go to full throttle, if i push the bind button instead ofthe motor causing the throttle to go to the off position it causes the main rotors to swap from forcing down to forcing up, so if you hold it in the heli will fly but as soon as you let go it drops to the ground. hope some can give me advice what i can do, is there something wrong with its program or what i am lost.
Regards
Peter
jaymin is offline Find More Posts by jaymin
Old Jul 17, 2014, 07:06 PM
Helicopters
Airworks's Avatar
United States, MA, Adams
Joined Oct 2008
you have something reversed
blades are spinning correct direction i assume .
after that is your pitch reverse.
Airworks is offline Find More Posts by Airworks
Help! Bland Nano QX rtf - Will not Bind DanObiWan Micro Ready-to-Fly 1 May 29, 2014 08:27 PM
Discussion blade 300x tail rotor will not return to center Vmoon Electric Heli Talk 1 Oct 28, 2013 02:51 PM
Discussion Blade Mcp x v2 will not fly.... Baddmove Beginner Training Area (Heli-Electric) 5 Oct 20, 2013 10:55 AM
Discussion DJI Phantom will not fly , please help tried everything, TruthLogic Multirotor Talk 0 Sep 29, 2013 11:39 AM
Discussion Xtream blades fitted now will not fly ! covert Coaxial Helicopters 9 Oct 11, 2007 12:28 PM
