Old Jun 26, 2013, 09:44 AM
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
Question
Micro LED
I finished building my first micro not too long ago and am looking to fly it at night.
I've visited my local Rat Shack and bought a pack of leds that included some 3mm. I have wired 2 of the 3mm in using 3 10Ω resistors in series to drop my voltage from 3.4v to below 3 for use with a 1s lipo, plane itself is using a 2s pack for power so the lights are on a separate pack.
The whole lighting rig including battery is 8.5 grams now while not much on a bird that's auw is 42.5 grams it's a bit much, weight with lights is a whopping 51 grams. She stays airborne with the lights, but I'm really looking for a way to shed weight. I'm also going to have to add either a light up front or a tail light for orientation as when turning I'm blind to one side.
Looking for lightening the load suggestions, be it using metal traces instead of wiring, or smaller leds or lighter battery packs or all of the above.
dedStik is online now Find More Posts by dedStik
Latest blog entry: Confessions of a smoker...
Old Jun 27, 2013, 06:56 AM
Bonnie Scotland
Joined Jun 2004
The biggest weight saving you could make would be to ditch the separate battery and take power from the flight battery. That's what I do, using the balance connector for my lights. Recalculate the resistor required using this very useful site :
http://led.linear1.org/led.wiz
BTW the resistor, whilst dropping the voltage, is really there for current limiting.
Next use smaller LEDs.
Finally use very thin wire. Some people use single strand enamelled copper wire for micro models.
electrotor is offline Find More Posts by electrotor
Old Jun 27, 2013, 10:04 AM
dedStik's Avatar
Joined Feb 2012
I thought about using some magnet wire instead of strand the plane runs off a 2s 200 mAh pack I'm worried the excess current draw would reduce pack time considerably. I'm also not aware of smaller leds than 3mm that would still be visible from max 30 yards. I fly it in about the area of a dirt ball diamond. My battery also has no balance plug, I hacked an eflite 2s which had the balance lead as the out lead, I wired red and black to the micro deans and shrink wrapped the white lead.
Wanted Micro LED's for Hobbyzone Champ SkiCrazy Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 May 17, 2013 07:17 PM
Discussion Hubsan X4 micro quad $37 shipped & v949 with LEDs $31 shipped Koo Hot Online Deals 25 Apr 26, 2013 11:57 AM
New Product Helimax 1SQ Quad 6 Axis With Micro Cam,LED's,And Flip Button Get Real Mini Multirotors 2 Apr 10, 2013 04:19 AM
Discussion Poor Mans Micro Brushed ESC/Actuator Driver/LED Proportional with trim elvill Micro Ready-to-Fly 5 Jan 18, 2013 01:12 AM
Cool LED lights for your micro plane. LED and battery .8 grams Lammergier Micro Ready-to-Fly 3 Apr 01, 2011 10:16 PM
