Old Oct 17, 2012, 09:36 AM
Joined Oct 2012
UAV Thesis Topic
Hi,
I'm new to these forums. I will be completing my Bachelor's of Mechatronics Engineering and Computer Science next year and I need to select a thesis topic. I am quite interested in aviation, and there is a UAV project at my university but it has only recently begun. The only components designed so far I believe are an embedded controller with some sensors such as an altimeter and barometer. It is similar to ArduPilot but made from scratch using a Texas Instruments board and other components.
I don't want to bite off more than I can chew, so I was thinking of implementing some kind of RF control system (which I have never done before). I plan to use XBee Pro RF modules, one on the UAV connected to the microcontroller and one connected through an XBee Explorer USB adapter to a PC (the "base").
I intend to design a program on the PC that will read in sensor values sent over the XBee modules (eg, altitude sensor, barometer readings, gyroscope readings), as well as potentially control the UAV when the other parts of the system are completed (by other students). If I connect directly to the PC using the USB adapter, does anyone know how I would program it and in what language (serial)? Should I use an Arduino [though I believe the Arduino should not be used for the full project, instead it should be used for prototyping].
Does this seem like a feasible project idea? Are there any other ideas I could potentially do relevant to my degree?
cozmicf is offline Find More Posts by cozmicf
Old Oct 17, 2012, 02:29 PM
Project Tormentor is flying!
United States, WA, White Salmon
Joined Nov 2005
Quite a few students and teams have done this for a project. It is not a simple project, on many levels. I suggest you talk to actual UAV operators and learn what are the common setbacks/problems/limitations they come across and see if you can design a solution that addresses as many of them as possible.
UAV's are still a young industry, and as such they are a bit rough around the edges. I believe a project that aims to assist the use of UAVs has merit. I know this is all very vague, but I think if you do some research, you could narrow down onto something you would enjoy undertaking that is feasible and unique.
philthyy is online now Find More Posts by philthyy
Old Oct 18, 2012, 03:34 AM
Joined Oct 2012
What complications do you know of that students have encountered doing this?
I don't really know any UAV operators so I thought some would be on here so I don't know who to ask about setbacks/problems/limitations.
Also, what do you mean by a project that aims to assist the use of UAVs?
Old Oct 18, 2012, 06:50 PM
brakar's Avatar
Asker, Oslo, Norway
Joined Feb 2009
There is a full thesis about autopilot develpment to be fond here: http://lib.ugent.be/fulltxt/RUG01/00...10_0001_AC.pdf
(Google translate)
And the current state of the open source firmware: http://code.google.com/p/gluonpilot/...e/#svn%2Ftrunk
brakar is offline Find More Posts by brakar
Discussion Discuss the future of UAV (thesis) fthrw8 UAV - Unmanned Aerial Vehicles 3 Jun 21, 2012 11:40 AM
Discussion Senior Industrial Design Thesis: Multiple UAV's Marrocco UAV - Unmanned Aerial Vehicles 17 Feb 10, 2009 07:36 PM
Discussion Master Thesis , UAV tracking device 2.4Ghz Impulze FPV Talk 2 Jan 27, 2009 07:48 PM
Slightly Off Topic: Israeli UAV wing. EPP? toygeek Slope 11 Mar 27, 2004 01:59 AM
Topic Suggestion: UAV Development mcu-electric Site Chat 0 Jan 11, 2003 09:17 PM
