Old Nov 21, 2003, 08:58 PM
Australia
Joined Sep 2001
One more picture.
Did another pcb this morning using Koichi's method to see if results could be repeated easily. 0.1mm pcb material.
This method is quick, cheap and effective.
Dave
david_dewit is offline Find More Posts by david_dewit
Old Nov 21, 2003, 10:06 PM
Koichi Tanaka's Avatar
Japan
Joined Dec 2002
Dave,
It is the very good result!
Koichi
Koichi Tanaka is offline Find More Posts by Koichi Tanaka
Old Nov 21, 2003, 10:57 PM
Zama city, Kanagawa, Japan
Joined Dec 2002
Is it common in US ? http://www.techniks.com/
Press-n-Peel Blue Transfer Film may be one of the solutions.
Regards, Yoshi
moto is offline Find More Posts by moto
Old Nov 22, 2003, 03:58 AM
Leicester England
Joined Jun 2001
The lightest circuitboard is not having a circuit board? Much quick than making a circuit board too?
Just a thought?
Mark?
aeronutz is offline Find More Posts by aeronutz
Old Nov 22, 2003, 04:51 AM
Australia
Joined Sep 2001
Thanks Koichi, Yoshi and Mark. For kind words, link and thoughts.
Dave
Old Nov 23, 2003, 01:14 AM
billystiltner's Avatar
United States, VA, Clintwood
Joined Nov 2002
Mark how much does your no circuit board RX weigh with one shaved down sensor?
Thanks for all the tips Bulent.
Billy
billystiltner is offline Find More Posts by billystiltner
Old Nov 23, 2003, 06:59 AM
Joined Dec 2002
A circuit without circuit board needs some wire to connect the legs of SMD parts. This work may be very complicated usually.
It may be effective only for the units which requires very few parts. Koichi and Dave had built simple circuit without circuit board already. It may be impossible to build Koichi's new IRXA301-3 without circuit board.
Yoshi
Old Dec 05, 2003, 07:08 AM
QLD, Australia
Joined Sep 2003
David,
I got my ir system working , I made a new miniTx on a pcb kept the resonator in close to the pic , re-used the original pic worked right off .
I think my hunch was right that the unit i built on vero board wasnt tight enuff -the resonator was too far away from the pic .
I tested it with the 3 servo Rx it worked normally so my budy box unit must be not working properly - least i know i have an rx that works so can use it to work with the tx - am wondering if my model tx needs a modified circuit ?oh for a scope !
see the picture of the mini tx with both boards next to each other
clipclop is offline Find More Posts by clipclop
Old Jan 18, 2004, 08:17 PM
QLD, Australia
Joined Sep 2003
Just thought this chart may be usefull to those following .
Stewart.
Dave you may like to add this to your index
Old Jan 18, 2004, 08:30 PM
Joined Nov 2002
Stewart
what values did you use for trim parts on your TX?
I'm going to have to add some to mine. They worked ok with magnetic actuators but with the MW actuators it needs some seroious adjustment.
Billy
Old Jan 18, 2004, 08:35 PM
QLD, Australia
Joined Sep 2003
Billy,
I used 5k 25 turn trim-pots, I also changed the 3.3k fixed resistors to 1k . I preset the pots to have a serial resitance with the 1k resistors of 3.3k befor inserting the pic and fireing it up .
Stewart
Old Jan 25, 2004, 12:52 AM
Joined Nov 2002
Stewart
Thanks for the info on the resistors.
Dave
Here is a direct link to babelfish with english translation of Koichi's page. It should be valid till AV changes babelfish interface.
Seems like they used to show the CGI url when you translated a page but now it is not present.
http://babelfish.altavista.com/babel....html&lp=ja_en
Billy
Old Feb 19, 2004, 11:35 PM
Australia
Joined Sep 2001
Supplies arrived which will allow me to get this one finished.
BBA should be well suited to this type of model.
Working towards some living room aerobatics.
Loops,rolls and inverted hopefully.
Thread rigging is to give wing some torsional stiffness to handle manoeuvres.
I believe model could be built closer to 7 gram giving it a thrust to weight of almost 2:1.
6mm motor
5 inch prop
6.7:1 gear ratio
E-Tec 90
IR Rx
area 76 sq/in
loading 0.54 oz/sqft
weight 8 gram
thrust to weight 1.75:1
Dave
Old Feb 20, 2004, 03:44 AM
Joined Nov 2002
Dave
That is a pretty awesome plane.
Billy
Old Feb 20, 2004, 04:01 AM
QLD, Australia
Joined Sep 2003
Dave,
well done , most people are struggling to get enough thrust to weight to fly normal circuits looks like you have a liveing room hovering aerobat there .
Stewart
questions on diy ir rx jonathan8388 Scratchbuilt Indoor and Micro Models 29 Jan 11, 2005 10:44 AM
Question Diy IR Z-tron Tx micromad Scratchbuilt Indoor and Micro Models 0 Dec 10, 2004 11:50 AM
DIY IR Rx PCB's david_dewit Scratchbuilt Indoor and Micro Models 11 Nov 04, 2004 05:12 PM
Where is the DIY IR and LRFers thread? Timbo337 Scratchbuilt Indoor and Micro Models 2 Dec 30, 2003 04:29 PM
DIY IR 555 timer help. j8m8l Scratchbuilt Indoor and Micro Models 4 Dec 03, 2003 10:02 PM
