Old Mar 16, 2003, 08:02 PM
Joined Feb 2003
Slowstick modification thread...
Ok, I've got a slowstick coming from www.allerc.com and a GWS radio on the way from www.balsapr.com. I want to build it with the best of the mods suggested here in this group. So far, here are the best ones I've found:
1. Wood stick plug to give 3 degrees right and 3 degrees down thrust.
2. Stickin an arrow shaft or dowel into the stick to prevent it from bending.
3. Replacing aluminum wing reinforcing rod with brass one.
4. Putting packing tape on leading edge of wing and also a strip on the bottom full length of wingspan.
5. Using epoxy to glue the wing together.
Am I missing something that would help make this plane better?
RandyH
Randy_H is offline Find More Posts by Randy_H
Old Mar 16, 2003, 08:14 PM
MooseFlyR's Avatar
Slingerlands, NY
Joined Feb 2003
Just the forward section & maybe tail.
Also, maybe .125 CF tubing to replace the fiberglass rods
Sparingly, or use probond
6. Better wheels.
7. Reinforce landing gear wires.
8. CF pushrods
Good luck with your Slowstick... it is a great plane.
MooseFlyR is offline Find More Posts by MooseFlyR
Old Mar 16, 2003, 08:16 PM
Joined Jul 2001
I haven't done a single modification to my SS and it flies fine.
quietfly is offline Find More Posts by quietfly
Old Mar 16, 2003, 08:28 PM
senor_paco's Avatar
San Antonio
Joined Dec 2001
I did the wheel and CF mods, as well as a 12*6 prop, and it's all right after 30+ flights, including mods such as hitting mailboxes, bushes, and once getting tangled in a neighbors rooftop reindeer display (misjudged distance), but all in all, it's ready to fly on a moments notice. Motor is starting to lag a bit though. Could be the prop and the 8cell 1100 mah pack. I only stonp the throttle for taking off, then just putter around. It's nice to have that power when you need it. Kinda like being in my big super street V8. when you need to go, you can!
senor_paco is offline Find More Posts by senor_paco
Old Mar 16, 2003, 08:34 PM
MooseFlyR's Avatar
Slingerlands, NY
Joined Feb 2003
As Quietfly says...
You dont NEED to do any mods.
Old Jun 15, 2014, 07:44 PM
United States, VA, Woodbridge
Joined Jun 2014
What is a good replacement motor for the HK slow stick. Seems like it needs more power. Can I go to a 1800KV?
Dan
dporter is offline Find More Posts by dporter
Old Jun 15, 2014, 10:28 PM
United States, AZ, Tucson
Joined Jun 2004
SS motor
You would do better using a motor with a 1000 KV -800 KV and a bigger prop . Here a thread that will help http://www.rcgroups.com/forums/showthread.php?t=407136 . Dan
fx-2 is offline Find More Posts by fx-2
Old Jun 16, 2014, 07:28 AM
Joined Jun 2014
Dan, Thanks much. Have briefly checked the thread; it looks like there is a lot of great info there.
Dan
Old Jun 16, 2014, 08:24 AM
In thrust we trust
phoam's Avatar
Aguanga, Ca
Joined Mar 2010
Dan
If you use an 1800Kv motor on your Slow Stick be sure to stick with 2S packs.
phoam is offline Find More Posts by phoam
Old Jun 16, 2014, 09:49 PM
Joined Jun 2004
Slow Stick
Your welcome . I need to get my old SS out an fly it , it been a hanger queen for 4 years now . It weight 14 oz an has a 100 watts to the prop . I have one slow stick that weight 12 oz ready to fly , only 60 watts on that one . They fly best with a lower kv motor an a bigger prop . You need thrust not speed , the lighter the better . Dan
Old Jun 16, 2014, 10:06 PM
Joined Jun 2014
wal86ker is offline Find More Posts by wal86ker
Reply With Quote  (Disabled)
Old Jun 16, 2014, 11:44 PM
Joined Jun 2004
Ss
What battery are you using? How are you flying it , as a trainer or sport ? Dan
Old Jun 19, 2014, 07:08 PM
Joined Jun 2014
What wheels are you using?
Dan
Old Jun 19, 2014, 08:23 PM
Joined Jun 2004
SS wheels
If I recall there the GWS wheels that come with the kits if not there Du-bro . Hope that helps . Dan
Old Jun 19, 2014, 08:26 PM
Dave K's Avatar
Sebastopol, Ca
Joined Jun 2004
Is there a mod to better mount a large battiery pack to the SS? Also what is a good motor for a SS set up for a small camera?
Dave K is online now Find More Posts by Dave K
Discussion Gws Me 262 Modification Thread corsair nut Foamy EDFs 71 Aug 30, 2007 03:33 PM
Discussion Wattage Powerfan Modification Thread corsair nut Foamy EDFs 114 Jan 20, 2007 12:52 PM
Whoops! Slowstick building thread digsy Parkflyers 2 Jan 09, 2004 02:39 PM
