Old Aug 18, 2006, 08:32 PM
Mr. Reliability
Lithuanian Flyer's Avatar
Chesapeake, Va.
Joined Jul 2006
Question
Brushless motor angle on Microjet
After seeing a Microjet brushless setup recently, I've read many threads about them before making the decision to build one using a Mega 3 for power.
The many comments on launch difficulty posted are a concern. One person had several bad initial experiences but overcame them by changing the thrust angle of the brushless motor. In this case, it had an aluminum bracket that was bent.
I am wondering if putting a shim under the prop end of the Mega would get the same results, and , what are the thoughts on the motor angle improvement for reducing launch rolls and dive crashes? And, if lipos aren't used, what would be the best NiMH application for the Microjet?
The MJ looks like the ultimate for speed for the cost, if the launch issue is overcome.
Thanks for any insight on the Microjet.
Rick
Lithuanian Flyer is offline Find More Posts by Lithuanian Flyer
Old Aug 18, 2006, 10:21 PM
gilford, new hampshire, usa
Joined Nov 2003
The shim would work fine. The aluminum mount is easily made from stock bought at the hardware store (like I have 6 feet of it!) bent to proper thrust angle and held on with zip ties. I went with lipos, a light 3s pack, and all up weight was almost 100 gms less than printed on the box and have had absolutely no problems with the launch ( other than scary fast at full throttle with the GWS 15T brushless)
nebuchadnezzar is offline Find More Posts by nebuchadnezzar
Rave Which brushless motor to use on a Tiger Moth 400? JustFly Parkflyers 11 Jul 05, 2005 11:21 PM
FS: Castle Creations Phoenix 10 Brushless Motor Controller on E-Bay DaveSawers Aircraft - Electric - Airplanes (FS/W) 0 Oct 02, 2004 05:43 PM
how would the MTM 400F Out Runner Brushless Motor perform on my plane? Zachary Power Systems 1 Sep 10, 2004 11:57 PM
MTM 400-T brushless motor E-flite 370 brushless motor PERFORM ON GWS FORMOSA? Zachary Power Systems 0 Sep 07, 2004 11:10 PM
Question Anyone use Stevensaero brushless motor mount on Formosa Gatorfan Power Systems 4 Jan 23, 2004 11:49 PM
