Old Nov 15, 2009, 08:27 PM
Micro Brushless crazy
Uttam1's Avatar
India, Bangalore
Joined Jul 2002
bagging ailerons
Hi guys,
I have ailerons shaped from some light wood, each aileron is about 24" long and 2.5" wide. There are lightening holes to save some weight. The ailerons have a 45 bevel at the hinge line. I need to glass the ailerons, and get a nice smooth surface ( like from using mylar skins ) for the tape hinge. Any suggestions on how to glass it?
-TIA
Uttam
Uttam1 is offline Find More Posts by Uttam1
Old Nov 15, 2009, 09:04 PM
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
First off, since you put lightening holes in the ailerons you will not be able to use the standard mylar and vacuum bag. The vacuum will "dimple" the mylars around the lightening holes. You will have to the replace the mylar with something thicker that won't deform under the vacuum pressure.
Adam
wyowindworks is offline Find More Posts by wyowindworks
Old Nov 15, 2009, 09:07 PM
Uttam1's Avatar
India, Bangalore
Joined Jul 2002
Thanks Adam. I thought so too. Maybe lesser vacuum? I will try bagging without the fiber glass layup to see how bad the "dimples" are.
-Uttam
Old Nov 15, 2009, 09:08 PM
Just fly it!
Cody, WY
Joined Nov 2007
It may work with less vacuum. It really depends on how large the holes are. I don't like to go below 9" Hg.
Adam
Old Nov 25, 2009, 10:49 AM
DLD
David Layne
Tracy, Ca
Joined Jun 2004
You'll find that any amount of vacuum with 14mil mylar (or less) will show dimples unless the lightening holes are tiny. You will either have to find a thicker replacement for the mylar, or do it with no vacuum. You might be able to sandwich the mylar between the aileron and some bead board, or something similar that will spread the load evenly.
Good luck,
DLD
DLD is offline Find More Posts by DLD
Discussion Another FPV Candidate, THE SKY SURFER (Looks Like EZ w/Ailerons) SoMoney FPV Talk 135 Apr 23, 2010 06:54 AM
Discussion Newbie to Ailerons suggestion: Model Tech Fledgling chimmike Beginner Training Area (Aircraft-Electric) 12 Nov 07, 2009 11:24 PM
Discussion 2 chan ruder elv v 4 chan ailerons aardy Beginner Training Area (Fuel) 2 Oct 13, 2009 10:56 PM
Question Attaching control horns to ailerons Splatt42 Beginner Training Area (Fuel) 6 Oct 10, 2009 10:33 AM
Question X9303 + AR500 Ailerons + Flaperons mahbouni Radios 11 Oct 07, 2009 03:25 AM
