Old Jun 13, 2009, 12:00 AM
Peterfly's Avatar
Joined Mar 2006
recycle gyro sensor from broken digital camera
I have the broken digital camera. It has vibration delete function, so I understand that it has built-in gyro sensor. I'ld like to use it for my DIY gyro.
But when I look over the circuit board, it hard to point-out which IC is the sensor. How can I search the code on SMT device ?
Peterfly is offline Find More Posts by Peterfly
Old Jun 13, 2009, 01:24 AM
Chief Dumb Thumb
coulee's Avatar
United States, SD, Tripp
Joined Jun 2009
Type the code from the IC into google.. You will get all of the necessary datasheets.
BTW It is probably an accelarometer not a gyro. You would be better off to buy a dedicated IC and design your own board using express pcb or eagle, both free.
For a circuit check any of the popular robotics websites.
Ted
coulee is offline Find More Posts by coulee
Old Jun 13, 2009, 07:24 AM
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
There is no gyro in that camera. It makes little sense to try salvaging or building your own gyro anyway. Get replacement unit with servo/RX interface from Esky or Walkera.
rich smith is offline Find More Posts by rich smith
Old Jun 13, 2009, 02:52 PM
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
There are plenty of digital cameras with gyro sensors in them. There will probably be a pair of gyros and they will be mounted at right angles to each other on the pc board. I have several boards from broken cameras with Murata gyros on them. They are in tiny silver cans. The Murata gyros have two different resonant frequencies (will have different suffix letters) so they can be mounted close together without interfering with each other. Here is a spec sheet for the ones on my Panasonic camera boards.
jeffs555 is online now Find More Posts by jeffs555
Old Jun 13, 2009, 03:12 PM
rich smith's Avatar
Joined Dec 2006
I stand corrected. Mine had acceleometers. What model cameras have gyros? If OP posted a picture we could probably locate it.
Old Jun 13, 2009, 04:48 PM
Raleigh,NC
Joined Nov 2000
Not sure which models, but Canon, Pentax, Olympus,Panasonic,Sony and many others have cameras with gyro stabilization. I have several Panasonic Lumix DMC-LZ2 to DMC-LZ7 cameras and they all have two Murata gyros. Also have a Canon that I think uses Murata. Here is a dual axis gyro from Sanyo that Google says is used in several different brands of camera. http://www.letsgodigital.org/en/1147...stabilization/
Old Jun 13, 2009, 05:27 PM
Joined Apr 2009
Well, a MEMS Gyro would be nice, but the ones used in digital cameras do have way too little maximum rates for any useful use as a tail gyro. Except you would like to turn your tail with just about 60/s
If the camera uses Piezos, you could use them, but they are so cheap to buy anyway. But if you like...
OiOi is offline Find More Posts by OiOi
Discussion Video downlink from a digital camera thesporter FPV Talk 4 Mar 04, 2009 04:57 PM
Is there a digital camera that gives stills from the video? Canada Goose Aerial Photography 8 Sep 23, 2005 07:43 AM
Digital Camera Highlights from the Las Vegas CES 2003 Show Mr.RC-CAM Aerial Photography 5 Jan 16, 2003 07:58 PM
Using R/C AA cells in my digital camera? totalboss Electric Plane Talk 4 Sep 06, 2001 03:58 PM
Need help with digital camera!!!!!!!!! deadcell Electric Plane Talk 4 Jul 24, 2001 12:20 AM
