Old Sep 28, 2012, 10:21 PM
United States, SD
Joined Aug 2010
I can get a long reach plug too, I just thought a short would be better. I want to go with the adaptor just for the fact of being able to go to the LHS when I need a plug fast, because I don't always have one on hand.
Kyler1 is offline Find More Posts by Kyler1
Old Sep 29, 2012, 10:12 AM
Rocky Mountain High and Higher
PROACE's Avatar
Joined Jan 2002
those Norvels like 15% or better of glow fuel and will help with idle.
PROACE is offline Find More Posts by PROACE
Old Oct 03, 2012, 07:59 AM
Closed Account
Joined Feb 2006
Originally Posted by mjd View Post
If it looks like this it is a Cox Queen Bee .074 (assuming I attached the photo correctly..).
For the life of me, I could never get my Bee .074 to properly run. Joe Wagner, the venerable engine guru suggested possibly removing the intake screen, which I tried. Left us both scratching our heads (through E-mails).
Then I found in Yahoo .049 Collector's Group that this was not an unusual occurrence. Didn't mean to derail this thread; the Cub with .074 Norvel engine is gorgeous.
Just curious, but did any have any luck with this engine? BTW, given its low power output equivalent roughly to a Tee Dee .049, its weight by comparison makes it a boat anchor.
OkiThumper is offline Find More Posts by OkiThumper
Old Oct 03, 2012, 08:49 AM
Canada, ON, Cottam
Joined Jan 2012
I took the muffler off my Queen Bee and it runs better, pretty good as reedies go. Remember TD's usually have no muffler as a comparison. If you need a muffler at your club maybe a bigger outlet size may help if there is no noise limit. I don't think they are that loud compared to like an older .40.
aspeed is offline Find More Posts by aspeed
Old Oct 03, 2012, 12:06 PM
Closed Account
Joined Feb 2006
I have an old .10 OS Max R/C baffle piston engine with only an articulated exhaust baffle plate connected in sync with the carb. At full throttle, its noise was the same as a reed valve .049. At half throttle or less, it sounded like it was muffled because of the exhaust restrictor plate. (It provided back pressure in absence of a muffler during idle.) I imagine the .074 Bee's unmuffled noise at full bore is about the same as a .049, as you say, certainly not like an unmuffled .40 engine.
Thanks for the tip; I may try it next time around and see if it will run reliably w/o the muffler.
Old Oct 03, 2012, 08:20 PM
United States, SD
Joined Aug 2010
I haven't tried with the engine much anymore. I want to try it again tomorrow, but I don't know if I will get to it. I did order the adaptor, I know it was said that it might effect the performance, but I don't need that much power and I really want to be able to use my glow starters. Thanks for the comment on the plane "okithumper".
Old Oct 16, 2012, 10:44 PM
United States, SD
Joined Aug 2010
Got the adaptor and the engine runs great. Went and flew it tonight and I love the way it flies. It is nice to have a floating plane.
Old Oct 17, 2012, 01:37 AM
surfer_kris's Avatar
Sweden
The Queen Bee will spin a 6x3 at about 18000rpm, so it certainly beats a regular .049; RCUvideo
It is the regular glow plug that is the main problem, the low end can also bee improved upon by adding an airbleed hole.
The throttle also goes past full throttle, so that needs to be fixed too, or set with the servo throw (screen needs to be off to se this).
surfer_kris is offline Find More Posts by surfer_kris
Old Oct 17, 2012, 01:43 PM
United States, SD
Joined Aug 2010
Can I just take that screen off. I hate it being on there.
Old Oct 17, 2012, 03:47 PM
Sweden
Yes, it snaps right off and you don't need it.
In the video above you can hear it actually accelerates a little when I turn the throttle down, that was because the throttle can turn "beyond" full throttle. A bit of JB weld on the groove in the throttle barrel will fix it (done after that video s´was taken).
Old Oct 25, 2012, 05:26 PM
United States, SD
Joined Aug 2010
Got a set of floats now!!!!!
I got these Hz super cub floats in the mail from jalee7902 yesterday. I am super excited to get this thing on the water, maybe saturday.
Old Oct 25, 2012, 06:34 PM
Closed Account
Joined Feb 2006
Originally Posted by surfer_kris View Post
The Queen Bee will spin a 6x3 at about 18000rpm, so it certainly beats a regular .049; RCUvideo It is the regular glow plug that is the main problem, the low end can also bee improved upon by adding an airbleed hole.
That is a good suggestion, I try a couple different plugs to see if there is one that works. I think it came with a plug. I'll replace it with another and see.
I'll keep this in mind, thanks.
Old Oct 31, 2012, 09:04 AM
United States, SD
Joined Aug 2010
So I need a little more power out of the little norvel .074. What size of prop should I go with, it has a 7x4 on it right now.
Old Oct 31, 2012, 12:01 PM
Sweden
A 7x4 is too large, an APC 7x3 is about maximum. I prefer the APC 6.3x4 for regular sport usage, and you should get +17000rpm.
Old Oct 31, 2012, 02:30 PM
United States, SD
Joined Aug 2010
Ok thanks.
Discussion What is a used Hexacopter with WKM and GPS worth? lazer155 Multirotor Talk 1 Sep 01, 2012 09:38 PM
Question What might it be worth? 600Bob Fuel Plane Talk 18 Jul 27, 2012 06:44 AM
Discussion what is it worth? RCSwitz18 Trader Talk 4 Jul 23, 2012 12:32 PM
Discussion What's A Name Worth - ParkZone or Small Company? vcaruso Electric Sailplanes 5 Jun 27, 2012 10:08 PM
Discussion What is a Bridi Kit (all wood) Dirty Birdy .40 worth? bpink43 Classic Pattern Flying 5 Jun 18, 2012 01:35 PM
