Building has commenced!
Started with the tail feathers, since they are reasonably simple to do, and I hate hinging, so now I have the majority of it done. Decided to add the counter balances to the rudders. Drilled and inserted a 1/8" dowel in the counter balance to keep them from getting broken off. Also added the triangle stock and 1/16" plywood doublers to the boom sides. I increased the tri-stock from 3/8" to 1/2" so I can round out the slab sides a bit more that designed. Won't be true oval cross sections, but close. Plan to get the booms framed up and the retracts installed today, maybe. Still trying to decide on a scheme. I do really like the racers, but have done a few racers in the past, and my fleet needs a good warbird right now. May just go with one of the schemes, that Callie already has grafics for. |
Could the spinners be what are sold under the "Radioactive" brand in Europe?
http://www.sussex-model-centre.co.uk...xd.asp?id=1508. 2-1/2" 3-balde about halfway down the page... T |
Latest blog entry: HK Canary HLG glider mini review
Try some nice ones from Tru-turn or Dave Brown products. You get what you pay for in spinners...
Even Eflite might have the right shape/size. I try to shy away from plastic, if I can. http://www.truturn.com/Spinners/By_S..._shape_p38.htm Mark |
Main retracts in the booms worked out. Now need to frame the other boom, and do the same set-up. Had to work all this out as the plans show firewall mount style 90 degree gear, with small wheels. Scale size on wheels should be about 1/2" larger, but these will look OK, I think.
| Thread Tools | |
| Off Site ~closed~ | WINDSHEAR II | Aircraft - Fuel - Airplanes (FS/W) | 3 | Oct 18, 2011 12:02 PM |
| For Sale Wing mfg. P-38 Kit | wrmbrnr | Aircraft - Fuel - Airplanes (FS/W) | 1 | Jun 04, 2006 10:36 AM |
| For Sale Wing Mfg P-38 w/fg cowls | wrmbrnr | Aircraft - Electric - Airplanes (FS/W) | 0 | Jun 04, 2006 10:30 AM |
| For Sale Wing Mfg P-38 w/fg cowls price cut | wrmbrnr | Aircraft - Fuel - Airplanes (FS/W) | 0 | Apr 16, 2006 02:51 PM |
| Sold Wing Mfg P-38 Lighting Short Kit | re3626 | Aircraft - Fuel - Airplanes (FS/W) | 0 | Dec 27, 2005 11:41 AM |
