Old May 23, 2015, 07:26 AM
imrm is offline
Find More Posts by imrm
United States, MA, Braintree
Joined Apr 2005
LET Ventus with SLS Compensation Question.
I have two questions regarding the need for elevator compensation associated with the SLS system operation of this glider:
1. At this time the glider is properly balanced with the SLS in the down (stored) position. As expected, the CG moves a significant amount forward when the SLS is raised. Is it necessary to program in up elevator compensation when the SLS is raised? Or is the effect of raising and lowering the SLS insignificant on flight performance?
2. Is it necessary to program in either up or down elevator compensation on throttle up? Is there a tendency for the model to nose over under power?
Input from anyone who has flown this model ( or similar class of model) would be most appreciated.
imrm is offline Find More Posts by imrm
Old May 26, 2015, 10:26 AM
h.eberbach is offline
Find More Posts by h.eberbach
Bremen/Germany
Joined Apr 2004
@ 1: You will have to find out by trial and error if the C.G. shift (motor OFF!!!) will have a significant effect for the flight performance, however this is of minor importance as you won`t glide around with the SLS extended and motor off.
Much more important is your question 2:
With the motor ON, the long lever of the SLS will produce a strong nose-down effect which you might want to compensate for with elevator trim. While mounting your SLS in the fuselage, take care to set the motor axis such that the prop blast is directed directly towards the elevator (the angle with reference to the fuselage axis is not relevant - against common believe ... !). However, as the nose down effect will start faster than the counter effect of the elevator and the up trim (after a brisk motor start) be prepared at the elevator control. A slow motor run up will help.
If possible, also add an aero tow hook and make you first flight on aero tow and try the SLS well up in the air ...
Happy landings
Herbert
h.eberbach is offline Find More Posts by h.eberbach
Old May 26, 2015, 03:51 PM
imrm is offline
Joined Apr 2005
Ventus Elevator Compensation Question
Thank you Herbert for posting your reply, your comments will be helpful. This is a friends Ventus and we expect to fly it within a couple of weeks. i did the radio programming for him and he requested that I post the question, looking to get some guidance. i will let you know how it goes. Marty
Old Yesterday, 07:46 AM
Antonia Gigg is online now
Find More Posts by Antonia Gigg
United Kingdom, Witney
Joined Aug 2012
Hi,
I have two throttle- elevator mixes on all my up 'n' go SLS gliders (5 now), from foamy DG1000 and Arcus to my glass jobs, DG1001M, DG808, ASH 25, on a three position switch, up position is no mix, middle position is approx 5% up elevator, and the lower position is approx 10% up elevator, with a 1/2 second delay on the mixes. Thus you switch in the most appropriate on your climb-outs, it can be difficult sometimes to get the right up elavator freehand. I set these mixes as seperate modes with the trims as being seperate not global as well, therefore you can trim more up on the power climb-out in positions 2 and three, (remebering to go back position 1 after your climb) you can then adjust the mix on the ground to take into account your fine adjustments from in the air.
Another point is to have the pylon not vertical to the gliders horizontal centreline, between 5 to 15 degrees aft is about the right angle, have a look most full size up 'n' go gliders they all have a lean back on the pylon to counteract pitching forward when under power.
Hope this helps.
Antonia
Antonia Gigg is online now Find More Posts by Antonia Gigg
Old Yesterday, 03:20 PM
imrm is offline
Joined Apr 2005
Hi Antonia
Thank you for your suggestions, I will pass them onto my buddy for his consideration. I like the idea of setting up non-common trim on the three position switch for the elevator compensation.
Regards - Marty
Gallery SLS (Self Launching System) 4.5m Ventus 2CX & Dolly Trolley Wagon paulywood Scale Sailplanes 21 Apr 02, 2014 09:41 AM
Gallery SLS (Self Launching System) 4.5m Ventus 2CX & Dolly Trolley Wagon paulywood Electric Sailplanes 11 Mar 31, 2014 10:49 PM
Video ROG of LET 6m ventus SLS balsabozo Sailplane Talk 1 Aug 03, 2009 02:40 PM
Build Log Assembly of an HF Modell Ventus 2cxM with JK SLS guillaume83 Scale Sailplanes 127 Dec 05, 2008 10:22 AM
Discussion EMS 4.8 M Ventus 2C with SLS question GNX430 Scale Sailplanes 6 Jul 15, 2007 03:50 AM
