Old Feb 10, 2015, 04:52 PM
PWJClub78 is offline
Find More Posts by PWJClub78
Joined Nov 2013
Question
DLG Glider Scratch Build Plans anyone?
Hey does anyone have a link to a DLG scratch build with plans already ? Balsa or Foamie doesn't matter just no composite. There is no way on earth my wife is going to let me cook carbon fiber in the oven.
PWJClub78 is offline Find More Posts by PWJClub78
Old Feb 10, 2015, 11:55 PM
Rusty Nail is online now
Find More Posts by Rusty Nail
Rusty
Rusty Nail's Avatar
Auckland, New Zealand
Joined Feb 2006
Wrong forum: http://www.rcgroups.com/hand-launch-96/
Lots of entry level plans and kits available. Best to keep 1-1.2m for best compromise of ease of build, cost and performance for first scratch build:
* QFII (Mountain Models kit or free plans
* DL50 (Mountain Models kit) Only foam wing entry kit
* Gambler kit
* HK balsa kit (also prebuilt)
* Drela Apogee and Supergee
* Icarus
* Mimi
* German
* More German
* And
Many many more I do not have bookmarked...
Good place to start is the Mimi semi-solid, or the larger QFII.
Rusty Nail is online now Find More Posts by Rusty Nail
Old Feb 11, 2015, 01:36 AM
slebetman is offline
Find More Posts by slebetman
slebetman's Avatar
Malaysia, Selangor, Kajang
Joined Jun 2009
Look at the DL50 building technique. It's composite but easily doable at home. It uses WBPU or Minwax Polycrylic if you don't have or don't want to work with epoxy. Instead of vacuum bagging you simply paint on the glass cloth with a brush and then scrape away excess varnish with a piece of plastic (credit card etc.)
Or if you want to try old-school, check out Drela's Apogee instead of the larger SuperGee. The Apogee comes in two versions - composite hotwire cut foam core + fiberglass wing or sanded solid balsa wing. The solid balsa wing uses a special variant of the AG airfoil that was designed to be tolerant to impercise building and has a much flatter trailing edge to aid sanding.
The Apogee was very successful back in the days before DLG (when hand launch meant javelin throws) and was one of the early birds used to experiment with DLG throwing. It's where the venerable AG series airfoils used in most early (and some contemporary) DLGs got its name.
The Mimi is also a good design. It used to win contests when flown against commercially bought DLGs.
slebetman is offline Find More Posts by slebetman
Old Feb 11, 2015, 01:38 AM
Joined Nov 2013
thanks guys exactly what I was looking for
Old Feb 11, 2015, 01:42 AM
slebetman's Avatar
Joined Jun 2009
Another thing you may want to try if you don't want to invest in a lot of balsa or composites is to build an Alula clone. There are several on here but most don't come with plans (it's a fairly simple planform so you can just use the good old TLAR method).
Old Feb 11, 2015, 01:45 AM
slebetman's Avatar
Joined Jun 2009
Here's the build manual for the DL-50 which discusses the brush-on fiberglass technique: http://www.mountainmodels.com/images/manuals/dl50.pdf
Also useful for hints on other building/design techniques.
Build Log "Fusion", Scratch built, high performance, light lift aerobatic glider, plans leadfeather Slope 552 Apr 16, 2015 10:26 AM
Discussion CreativeRCutah scratch build dollar store foam board plans creativercutah Hot Online Deals 1 Feb 06, 2015 08:54 AM
Discussion Unbelievably Fantastic Scratch Build Plans FREE ! Chophop The Builders Workshop 23 Nov 27, 2014 12:02 PM
Doesn't anyone scratch build, plans or kits?? sa-woody Electric Plane Talk 54 Feb 06, 2005 05:45 PM
