Old Jan 12, 2015, 10:28 AM
Raphael is offline
Find More Posts by Raphael
Switzerland
Joined Jul 2004
Build Log
Knecht Ruprecht - flying wing by Peter Wick & me
Hey guys
I think I'm finally able to start my own build thread here about a new flying wing, designed to my specifications by "Mr. Flying Wing" Peter Wick.
It all started about 2 years ago when I finished my so far last "Fräulein Rottenmeier" (a 2.7m fully molded slope/DS-plane also from the Logo Team) and I noticed once again, that this incredible planes has 2 major flaws:
1. The wing is 1-piece, and although that's stil a manageable size, it's big
2. It has a fuselage, and I hate building fuselages
So what could be better than asking Peter to help me design a fully molded wing, of course in 2 pieces, and of course without any fuselages. A great fellow as Peter is, he not only helped, but created the whole aerodynamic side of the project for the plane from the ground up. I'm sure he will chime in and explain from his own point of view.
So we bought some Necuron, cast to size, and milled the molds negative. Me and my girlfriend (!) then spent over 200h of sanding & polishing them until they were perfect.
However, my motivation almost left me completely when I tried to join the mold-halves for the first time, only to notice that the dowel pins do not align on the 2 sides...
I think everybody can comprehend how bad I was feeling in that very moment!
The guy doing the CAD (neither me nor Peter) found the error quickly - he had realigned the pins after setting their initial position, but only on the lower halve...
So what to do? Already spent quite some money on the material and milling, and - even more valuable - a lot of time sanding & polishing, I was about to give up.
But I had the rudder-mold already lying around - it was built from milled positives. So Peter, the CAD-guy and I discussed the possibilities, and we agreed that milling the wing-molds again does not make sense. Instead, we milled positives like on the rudder I then built molds on.
So that's where I currently am with the project. As I've read the build-thread from @timbuck and his Gizmo (which is also a PW-design) I thought I also need to contribute to this small world of maniacs
So if you are interested, I will post pictures of the progress on the project. I hope that 2 months from now, the first prototype will be flying.
Oh, not to forget some data...
Wingspan: 2.2m
Area: 43.49dm2
Cheers!
Raphael
Raphael is offline Find More Posts by Raphael
Site Sponsor
Raphael is offline
Switzerland
Joined Jul 2004
Pictures of finished parts
In this post, I will gradually attach pictures of finished parts and their making...
Site Sponsor
Old Jan 12, 2015, 10:30 AM
Raphael is offline
Switzerland
Joined Jul 2004
reserved 2
Site Sponsor
Old Jan 13, 2015, 12:39 AM
Swoopdown is offline
Find More Posts by Swoopdown
C'mon more Energy
Swoopdown's Avatar
Melbourne, Australia
Joined Mar 2005
Very cool.
I'll be watching with interest!
What is the intent of the model. Speed/DS/across/all round sloper? I love to look of it. Keep up the good work. Hope you sort out your alignment problem soon
Swoopdown is offline Find More Posts by Swoopdown
Old Jan 13, 2015, 03:02 AM
depronator is offline
Find More Posts by depronator
I´ll be back
depronator's Avatar
near by Frankfurt (Germany)
Joined Nov 2006
very unusual vacuum design.
do you think it works reliably?
what about nose and CG?
wbr
Juri
depronator is offline Find More Posts by depronator
Old Jan 13, 2015, 03:34 AM
Raphael is offline
Switzerland
Joined Jul 2004
@Swoopdown: Thanks
It's an allround sloper - I wanted a plane that could easily fit everywhere when travelling since I'm prone to transporting problems with the Fräulein Rottenmeier!
It will be fast with good turning / thermal capabilities, so it should also DS adequate.
I hope Peter will chime in and tell a bit more about the aerodynamic concept.
The alignment problems are already solved (see above): we had to do the molds again from scratch! I am a perfectionist and therefore we had to start again.
@depronator: It is unusual, but I don't see why it shouldn't work (even better than usual). It's absolutely leak-free, the foil can be laid perfectly flat on top of the mold and I only need to make sure no resin is sucked into the tubes - so don't mess around with resin (I usually don't) and apply generous amounts of vacuum-fleece. Where do you see the problems?
There will be no nose, it's really only the wing and the rudder. So I have to build light in the back and heavy in the front (doesn't hurt anyway for toughness ). Peter can explain the benefits of the design better than me, but in the end it may lead to a slightly heavier, but better turning plane. It's in fact comparable to the shorter noses on DLGs these days: You could probably achieve a lower AUW with a longer nose, but it hurts launch performance.
I always build a CoG-"simulation" in Excel where I enter all the parts, weight & distribution before building, so I can calculate the impact & end weight in advance.
Site Sponsor
Old Jan 13, 2015, 04:10 AM
Stupot46 is offline
Find More Posts by Stupot46
I don't like your altitude
Stupot46's Avatar
Joined Sep 2011
Subbed!
Here's another noseless design
MCZ Batteriekopf, pente ouest 4°c vent 45-65km/h (1 min 8 sec)
Stupot46 is offline Find More Posts by Stupot46
Old Jan 13, 2015, 05:16 AM
C'mon more Energy
Swoopdown's Avatar
Joined Mar 2005
Cool Rapheal.
Sounds like a great all rounder. My sort of ship!
Old Jan 13, 2015, 02:38 PM
Raphael is offline
Switzerland
Joined Jul 2004
This week I can't show many build pics as I am waxing the molds. Maybe I'll have time for a usable (=not too heavy) rudder on saturday...
@Swoopdown: I hope so! With that plane I could even visit Australia
Site Sponsor
Old Jan 13, 2015, 04:50 PM
Tail Saw is offline
Find More Posts by Tail Saw
a wing is enough
Tail Saw's Avatar
Germany
Joined Aug 2010
And here too, a small one, ~ 36" :
Soft-DS Versuche mit dem Bow...2/3 (4 min 24 sec)
http://www.thermik-board.de/viewtopi...tart=30#p39956
I hope the other examples motivate......hopp, hopp Raphael
Regards,
Uwe.
Tail Saw is offline Find More Posts by Tail Saw
Old Jan 13, 2015, 05:27 PM
Stupot46 is offline
Stupot46's Avatar
Joined Sep 2011
Old Jan 13, 2015, 05:30 PM
Stupot46 is offline
Stupot46's Avatar
Joined Sep 2011
http://vimeo.com/110052953
Regards,
Uwe.
17kmph wind? Who needs hills
(Btw linked your build on Nurflugal)
Old Jan 15, 2015, 03:29 PM
Raphael is offline
Switzerland
Joined Jul 2004
As I wrote above, this week it's waxing time
As the first rudder-molds were not perfectly straight, I have mad new ones a few weeks ago.
The molds look great now!
Site Sponsor
Old Jan 15, 2015, 08:56 PM
timbuck is online now
Find More Posts by timbuck
Bigger is better
timbuck's Avatar
gold coast australia
Joined Aug 2008
Great to see you have a new build thread Rapheal. This thing will be a great all rounder. And yes you should come to australia
Tim
timbuck is online now Find More Posts by timbuck
Old Jan 16, 2015, 12:44 AM
Mason W. is offline
Find More Posts by Mason W.
You know our motto, We deliver
Texas
Joined Nov 2010
wow! slick looking mold!
Mason W. is offline Find More Posts by Mason W.
Help! Please help me identify 20 inch Flying wing! rvillegachapa Flying Wings 4 Feb 21, 2015 07:14 AM
Help! flying wing hurt me AORai Foamies (Scratchbuilt) 8 May 17, 2014 09:41 AM
Discussion Wicked Jr Powered 24" Flying Wing roo_ster Don's RC 3 Jul 22, 2012 11:14 PM
Sold Wicked 2700KV and Wicked 3000KV motor sale, great for flying wings and pusher jets The Don Aircraft - Electric - Power Systems (FS/W) 2 Jun 07, 2010 09:54 PM
